Voyager
Voyager
performance timer in linux?
whats the correct timer to use in us, for measure code performance?
clock()  or  gettimeofday?  I use both, but result are different.  This is for zc706
 gettimeofday(&(program_timer.perf_start),NULL);
start=clock();
//some process
diff=clock() - start ;
     usec = diff * 1000000 / CLOCKS_PER_SEC;
gettimeofday(&(program_timer.perf_stop),NULL);
       perf_diff=(uint32_t)((program_timer.perf_stop.tv_usec)  -( program_timer.perf_start.tv_usec));
         printf( "start=%d, stop==%d, Performance time=%d us, Time clk %d us\n", (uint32_t)program_timer.perf_start.tv_usec, (uint32_t)program_timer.perf_stop.tv_usec, perf_diff
           ,usec);
Scholar hbucher
Re: performance timer in linux?
@s002wjhw
So the short answer to your question is - gettimeofday() is the right solution for your purpose.
Long answer - they are radically different. clock() measures "process time", ie the amount of time the process itself netted running plus its children. It is based in kernel's "rusage" - or process book keeping. I believe the result is given in seconds, which is not really the most precise unit to measure time.
gettimeofday() is wall clock. It is usually a VDSO (ie userspace) call that (usually) does not require a kernel switch, which would make the call return very fast, thus making it more precise. However gettimeofday() can be affected by time shifts that occur from time keeping (ie NTP/PTP), especially if there is a time warp (ie when the difference between network time and local time is so big, the OS will not even attempt to adjust the clock smoothly). So from time to time you can get a completely wrong measure.
The best way to compute time is reading the clock ticks from the CPU. On standalone you can use Xtime_GetTime() which will encapsulate these calls for you. On Linux, you have to do it in assembly - but you have to enable the PMU with a custom kernel module, which is a more involved solution.
Voyager
Voyager
thx, though I read online some recommend using clock() because its the CPU clk?
as for gettimeofday()  I guess occasionally there is wrap around time which give wrong result?
Scholar hbucher
@s002wjhw
clock() wraps around every 72 minutes on a system where CLOCKS_PER_SEC is defined as 1,000,000 (most Linux)
gettimeofday() wraps around every 68 years - next in 2038.
That said, none are suitable to be used as a "performance" clock. You should really use processor clock ticks (ARM) or an AXI Timer.
Voyager
Voyager
k thanks is there an example on using ARM processor ticks or guide?? don't planning add an axi timmer in fpga right now
Scholar hbucher
@s002wjhw Use XTime_GetTime()
You have to include "xtime_l.h"
On Linux this module works - the code attached is for the Beaglebone but it is pretty much the same processor
Visitor wicky_waka
Hello @hbucher,
Thanks for the code as it save me a lot of time.
Did you write this code or if you can tell me about the source of this code so that I can add an acknowledgment for it in my thesis report.
