petalinux 10G/25G ethernet subsystem clock configuration
I've problems to setting the clocks of the SI5328. In the system-user file I added these lines:
&i2c1{
	status = "okay";
	i2c-mux@74 {
		i2c@2 {
			si570_1: clock-generator@5d { /* USER SI570 - u42 */
				#clock-cells = <0>;
				compatible = "silabs,si570";
				reg = <0x5d>;
				temperature-stability = <50>;
				factory-fout = <300000000>;
				clock-frequency = <156250000>;
				clock-output-names = "si570_user";
		i2c@3 {
			si570_2: clock-generator@5d { /* USER MGT SI570 - u56 */
				#clock-cells = <0>;
				reg = <0x5d>;
				temperature-stability = <50>; /* copy from zc702 */
				factory-fout = <156250000>;
				clock-output-names = "si570_mgt";
		i2c@4 {
			#address-cells = <1>;
			#size-cells = <0>;
			reg = <4>;
			si5328: clock-generator@69 {/* SI5328 - u20 */
				compatible = "silabs,si5328";
				reg = <0x69>;
				clock-output-names = "si5328";
but at the boot of petalinux I have this error " xilinx_axienet a0042000.ethernet eth0: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration ", but if I use the program "zcu106 SCUI" the clocks are setted correctly:
At this point if I write the si5328 clock to 156.25MHz using the zcu106 SCUI I get the 10G/25G eth subsystem working (disconnecting and reconnecting the fiber cable). why doesn't it work without using the scui tool to set the si5328 clock?
Thanks, Andrea
Not sure if this will solve your problem, but I noticed that you have Si5328 at 0x69 but the user guide (UG1244 pg. 66) shows it as 0x68
https://www.xilinx.com/support/documentation/boards_and_kits/zcu106/ug1244-zcu106-eval-bd.pdf
Fixed by setting 0x68, the error message continues to appear.
You might want to check out this post. You'll need to patch it into the FSBL.
https://forums.xilinx.com/t5/Processor-System-Design-and-AXI/Programming-the-Si5382-on-the-ZCU111/m-p/952785
