Visitor jdmairs
petalinux 2016.4 question on how to deploy a cmake c++ self extracting installer as prebuilt app
Folks,
I use cmake with petalinux cross compiler gcc 5.2.1 and successfully build my project.  I then use cmake/cpack to build the self extracting .sh installer.
I then:
petalinux-create -t apps --template install --name installer --enable
rm project-spec/meta-user/recipes-apps/installer/files/installer and copy in the real deal
petalinx-build -c installer
petalinux-build
petalinux-boot --qemu --kernel
It boots fine, it self-extracts and installs fine, but when I run an app it cannot find the libstdc++ dynamic libs.
Previously I noticed that if follow the same as above but substitute in an actual C++ Hello World executable called CompilerDeploymentTest (cdt) by some magic petalinux must scan the app and it adds in the libs for me.
So then I try and combine the 2 prebuilt apps (cdt and installer) and boot that.
No luck.  The boot freezes after the following lines.  I have repeated this over and over.
NOTICE: ATF running on ZCZUUNKN/QEMU v1/RTL0.0
NOTICE: BL31: Secure code at 0x60000000
NOTICE: BL31: Non Secure code at 0x8000000
NOTICE: BL31: v1.3 (release)
NOTICE: BL31: Built : 10:27:25 May 18 2018
So my current and untested plan is to go back to just the installer and configure rootfs to add in libgcc via
petalinux-config -c rootfs
any thoughts?
thanks,
John
Visitor jdmairs
Re: petalinux 2016.4 question on how to deploy a cmake c++ self extracting installer as prebuilt app
Filesystem Packages
     libs
          libgcc-xilinx
               * libgcc
Did not do the trick.
Now trying:
misc
     gcc-runtime-xilinx
          libstdc++
looks more promising doesn't it!
