petalinux 2017.2, uvc.h is missing
Need to build an application to run on ZCU 102 ES2. It needs uvc.h. Looked through Petalinux 2017.2 files and it wasn't there. Has this file been replaced/removed? Should I use something else?
Re: petalinux 2017.2, uvc.h is missing
Hey @rail.shafigulin,
Your UVC gadget test application seems to use the uvc.h from the Linux Kernel (drivers/usb/gadget/function/uvc.h) which requires the kernel source to be built.
Just checked and it is still in the Kernel Source where it belongs.
No, probably all you need to do is add the kernel source to your build and/or use the kernel source for building it.
(actually the uvc.h itself should suffice)
Hope this helps,
Herbert
@hpoetzl
Can you point me to its location? I looked through Petalinux 2017.2 source and didn't see it.
How does one add the kernel source to the build? I've never done this. Any help is appreciated.
