Visitor sephamorr
petalinux 2017.3 fails to build in etc/scripts_py/deploy.py
I'm on a fresh install of ubuntu 16.04 + vivado 2017.3 + petalinux 2017.3.
Building petalinux fails with the following:
$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Loading cache: 100% |##############################################################################| Time: 0:00:00
Loaded 3256 entries from dependency cache.
Parsing recipes: 100% |############################################################################| Time: 0:00:01
Parsing of 2466 .bb files complete (2433 cached, 33 parsed). 3259 targets, 226 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |#########################################################################| Time: 0:00:06
Checking sstate mirror object availability: 100% |#################################################| Time: 0:00:07
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 2439 tasks of which 2434 didn't need to be rerun and all succeeded.
INFO: Copying Images from deploy to images
Traceback (most recent call last):
  File "/opt/Xilinx/petalinux/etc/scripts_py/deploy.py", line 235, in <module>
    parse_args(sys.argv[1:])
  File "/opt/Xilinx/petalinux/etc/scripts_py/deploy.py", line 230, in parse_args
    main_func(proot,machine_name)
  File "/opt/Xilinx/petalinux/etc/scripts_py/deploy.py", line 205, in main_func
    copy_rootfs(proot,machine_name,machine_conf)
  File "/opt/Xilinx/petalinux/etc/scripts_py/deploy.py", line 148, in copy_rootfs
    for _file in os.listdir(source_folder):
OSError: [Errno 2] No such file or directory: '/opt/fra/petalinux/build/tmp/deploy/images/plnx_arm'
ERROR: Failed to copy images from deploy directory
ERROR: Failed to build project
Diffing deploy.py between petalinux 2017.2 and 2017.3 shows that the copy_rootfs function changed, and now breaks the build. I'm just upgrading from 2017.2, so still had a copy of the files on my old image.
Replacing the function with the old copy_rootfs and adding get_image_fstypes (helper function) appears to fix things. See old (functional) code below:
def get_image_fstypes(machine_conf):
  image_fstypes = []
  serch_str = re.escape("IMAGE_FSTYPES")
  for e in machine_conf:
    e_str = str(e)
    if re.search(serch_str,e_str):
      fstypes = e_str.split('=')[1]
      fstypes = re.sub(' ','',fstypes,1)
      fstypes = re.sub("\"",'',fstypes)
      fstypes = fstypes.split(' ')
      image_fstypes += fstypes
  return image_fstypes
def copy_rootfs(proot,machine_name,machine_conf):
  image_fstypes=get_image_fstypes(machine_conf)
  for e in image_fstypes:
    rfs_image = "petalinux-user-image-" + machine_name + '.' + str(e)
    dest_name = "rootfs." + str(e)
    copy_file(proot,machine_name,rfs_image,dest_name)
Has anyone else seen this / have a better workaround?
Re: petalinux 2017.3 fails to build in etc/scripts_py/deploy.py
Are you using Virtual machine for this experiment? Make sure you have more than 16GB VM RAM allocated.
I believe you have installed all the required packages mentioned in "Installation requirements" of UG1144 petalinux guide
Best Regards
Shabbir
