petalinux 2018.2 install errors on Ubuntu 18.04 LTS x64
f
I see these error below on just the installations of arm and microblaze.  And while the /components/yocto/source/aarch64 directory DOES get created and filled it appears that the arm and microblaze directories are NOT created. And so those contents are all being installed on top of one another in /components/yocto/source.
When I run petalinux-config in my project directory it fails with "ERROR: Failed to source bitbake" etc.  Looking into ./build/config.log I see:
environment: line 224: /home/dan/petalinux-v2018.2-final/components/yocto/source/arm/environment-setup-cortexa9hf-neon-xilinx-linux-gnueabi: No such file or directory
And of course this is true because /components/yocto/source/arm is never being created during petalinux install.
Is anyone else seeing this?
PetaLinux Extensible SDK installer version 2018.2
You are about to install the SDK to "/home/dan/petalinux-v2018.2-final/components/yocto/source/aarch64". Proceed[Y/n]? Y
Extracting SDK................................done
Setting it up...
Extracting buildtools...
done
SDK has been successfully set up and is ready to be used.
Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
$ . /home/dan/petalinux-v2018.2-final/components/yocto/source/aarch64/environment-setup-aarch64-xilinx-linux
INFO: Installing Yocto SDK to "/home/dan/petalinux-v2018.2-final//./components/yocto/source/"...
You are about to install the SDK to "/home/dan/petalinux-v2018.2-final/components/yocto/source". Proceed[Y/n]? Y
Extracting SDK..............................done
Setting it up...
done
$ . /home/dan/petalinux-v2018.2-final/components/yocto/source/environment-setup-cortexa9hf-neon-xilinx-linux-gnueabi
environment: line 277: locked_signs: bad array subscript
We are not sure about petalinux functionality on ubuntu 18.04 as we are still recommending to use ubuntu 16.04 as this verified distro
as per our UG1144
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf
Make sure to have the prebuilt packages in place, before installing petalinux. In your case, try re-installing the petalinux
Best Regards
Shabbir
Hi @danwwright,
2018.x petalinux release version doesn't support Ubuntu-18.04
Sandeep
Please try:
1. create a fold in $PETALINUX/components/yocto/source/
2. COPY all the files and folds in $PETALINUX/components/yocto/source to $PETALINUX/components/yocto/source/arm
sourcing bitbake prablem might be solved.
~/petalinux/components/yocto/source/arm$ ls
bitbake-cookerdaemon.log
buildtools
conf
downloads
layers
site-config-cortexa9hf-neon-xilinx-linux-gnueabi
sstate-cache
sysroots
version-cortexa9hf-neon-xilinx-linux-gnueabi
workspace
Note: copy the files, not remove them!
I have the same problem with the 2018.2 installer on Debian Stretch.  Solved it by (temporarily) downgrading Bash to 4.3.
The problem with Ubuntu 18.04 was predicted in this thread:
https://forums.xilinx.com/t5/Embedded-Linux/Peta-Linux-2018-1-install-failure/td-p/853223
That worked..  Thank you..
