petalinux 2019.2 dtc upgrade
I would like to share how to upgrade dtc utility
In petalinux 2019.2,  the version of dtc is 1.4.7
The dtc  causes the segmentation fault generating empty file  when  it convert /proc/device-tree into dts on petalinux installed system like this
root@ultra96v2_test:~$ dtc -I fs -O dts -o system.dts /proc/device-tree
Segmentation fault
I upgraded dtc to version 1.5.1 with the attached file to avoid the problem
The file should be extracted  under <project-dir>/project-spec/meta-user/recipes-kernel
And you should add the following to <project-dir>/project-spec/meta-user/conf/petalinuxbsp.conf
SIGGEN_UNLOCKED_RECIPES += "dtc-native"
PREFERRED_VERSION_dtc = "1.5.1"
