jimcox
petalinux 2021.1 tar and gzip errors. Unable to get through a basic build on Ubuntu 20.04 LTS for ZCU102.
I'm trying to follow the guide on this page:
https://github.com/Xilinx/Embedded-Design-Tutorials/blob/master/docs/Introduction/ZynqMPSoC-EDT/6-build-linux-sw-for-ps.md
I've run the following commands:
petalinux-create -t project -s <path to the xilinx-zcu102-v2021.1-final.bsp>
cd xilinx-zcu102-2021.1
petalinux-config --get-hw-description=<path containing edt_zcu102_wrapper.xsa>
petalinux-build
I end up with various gzip and tar errors during the build process.  Such as:
NOTE: recipe base-files-soc-2021.1-r0: task do_package_qa_setscene: Started
NOTE: recipe libffi-3.3-r0: task do_package_qa_setscene: Succeeded
ERROR: gmp-6.2.0-r0 do_package_write_rpm_setscene: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
     0001:
 *** 0002:do_package_write_rpm_setscene(d)
     0003:
File: '/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/core/meta/classes/package_rpm.bbclass', lineno: 738, function: do_package_write_rpm_setscene
     0734:# but we need to stop the rootfs/solver from running while we do...
     0735:do_package_write_rpm[sstate-lockfile-shared] += "${DEPLOY_DIR_RPM}/rpm.lock"
     0736:
     0737:python do_package_write_rpm_setscene () {
 *** 0738:    sstate_setscene(d)
     0739:}
     0740:addtask do_package_write_rpm_setscene
     0741:
     0742:python do_package_write_rpm () {
File: '/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/core/meta/classes/sstate.bbclass', lineno: 751, function: sstate_setscene
     0747:            pass
     0748:
     0749:def sstate_setscene(d):
     0750:    shared_state = sstate_state_fromvars(d)
 *** 0751:    accelerate = sstate_installpkg(shared_state, d)
     0752:    if not accelerate:
     0753:        bb.fatal("No suitable staging package found")
     0754:
     0755:python sstate_task_prefunc () {
File: '/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/core/meta/classes/sstate.bbclass', lineno: 380, function: sstate_installpkg
     0376:    d.setVar('SSTATE_FIXMEDIR', ss['fixmedir'])
     0377:
     0378:    for f in (d.getVar('SSTATEPREINSTFUNCS') or '').split() + ['sstate_unpack_package']:
     0379:        # All hooks should run in the SSTATE_INSTDIR
 *** 0380:        bb.build.exec_func(f, d, (sstateinst,))
     0381:
     0382:    return sstate_installpkgdir(ss, d)
     0383:
     0384:def sstate_installpkgdir(ss, d):
File: '/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/core/bitbake/lib/bb/build.py', lineno: 256, function: exec_func
     0252:    with bb.utils.fileslocked(lockfiles):
     0253:        if ispython:
     0254:            exec_func_python(func, d, runfile, cwd=adir)
     0255:        else:
 *** 0256:            exec_func_shell(func, d, runfile, cwd=adir)
     0257:
     0258:    try:
     0259:        curcwd = os.getcwd()
     0260:    except:
File: '/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/core/bitbake/lib/bb/build.py', lineno: 503, function: exec_func_shell
     0499:    with open(fifopath, 'r+b', buffering=0) as fifo:
     0500:        try:
     0501:            bb.debug(2, "Executing shell function %s" % func)
     0502:            with open(os.devnull, 'r+') as stdin, logfile:
 *** 0503:                bb.process.run(cmd, shell=False, stdin=stdin, log=logfile, extrafiles=[(fifo,readfifo)])
     0504:        except bb.process.ExecutionError as exe:
     0505:            # Find the backtrace that the shell trap generated
     0506:            backtrace_marker_regex = re.compile(r"WARNING: Backtrace \(BB generated script\)")
     0507:            stdout_lines = (exe.stdout or "").split("\n")
File: '/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/core/bitbake/lib/bb/process.py', lineno: 184, function: run
     0180:        if not stderr is None:
     0181:            stderr = stderr.decode("utf-8")
     0182:
     0183:    if pipe.returncode != 0:
 *** 0184:        raise ExecutionError(cmd, pipe.returncode, stdout, stderr)
     0185:    return stdout, stderr
Exception: bb.process.ExecutionError: Execution of '/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/gmp/6.2.0-r0/temp/run.sstate_unpack_package.565102' failed with exit code 2:
deploy-rpms/
deploy-rpms/cortexa72_cortexa53/
deploy-rpms/cortexa72_cortexa53/libgmp-lic-6.2.0-r0.0.cortexa72_cortexa53.rpm
deploy-rpms/cortexa72_cortexa53/libgmp-dbg-6.2.0-r0.0.cortexa72_cortexa53.rpm
deploy-rpms/cortexa72_cortexa53/libgmpxx4-6.2.0-r0.0.cortexa72_cortexa53.rpm
deploy-rpms/cortexa72_cortexa53/libgmp-dev-6.2.0-r0.0.cortexa72_cortexa53.rpm
deploy-rpms/cortexa72_cortexa53/libgmp-doc-6.2.0-r0.0.cortexa72_cortexa53.rpm
deploy-rpms/cortexa72_cortexa53/libgmp-src-6.2.0-r0.0.cortexa72_cortexa53.rpm
deploy-rpms/cortexa72_cortexa53/libgmp10-6.2.0-r0.0.cortexa72_cortexa53.rpm
gzip: stdin: invalid compressed data--format violated
tar: Unexpected EOF in archive
tar: Error is not recoverable: exiting now
WARNING: /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/gmp/6.2.0-r0/temp/run.sstate_unpack_package.565102:153 exit 2 from 'tar -xvzf /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/sstate-cache/c0/55/sstate:gmp:cortexa72-cortexa53-xilinx-linux:6.2.0:r0:cortexa72-cortexa53:3:c0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz'
WARNING: Backtrace (BB generated script):
	#1: sstate_unpack_package, /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/gmp/6.2.0-r0/temp/run.sstate_unpack_package.565102, line 153
	#2: main, /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/gmp/6.2.0-r0/temp/run.sstate_unpack_package.565102, line 163
Backtrace (metadata-relative locations):
	#1: sstate_unpack_package, /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/core/meta/classes/sstate.bbclass, line 852
ERROR: Logfile of failure stored in: /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/gmp/6.2.0-r0/temp/log.do_package_write_rpm_setscene.565102
NOTE: recipe gmp-6.2.0-r0: task do_package_write_rpm_setscene: Failed
NOTE: Running setscene task 566 of 1413 (/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/meta-petalinux/recipes-core/base-files/base-files-soc.bb:do_package_write_rpm_setscene)
WARNING: Setscene task (/home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/components/yocto/layers/core/meta/recipes-support/gmp/gmp_6.2.0.bb:do_package_write_rpm_setscene) failed with exit code '1' - real task will be run instead
ERROR: db-1_5.3.28-r1 do_package_write_rpm_setscene: Error executing a python function in exec_python_func() autogenerated:
and
sysroot-destdir/usr/include/boost/fusion/container/deque/detail/cpp03/preprocessed/deque_keyed_values30.hpp
sysroot-destdir/usr/include/boost/fusion/container/deque/detail/cpp03/preprocessed/as_deque.hpp
tar: Skipping to next header
tar: A lone zero block at 211255
tar: Exiting with failure status due to previous errors
WARNING: /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/boost/1.74.0-r0/temp/run.sstate_unpack_package.424904:144 exit 2 from 'tar -xvzf /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/sstate-cache/c5/93/sstate:boost:cortexa72-cortexa53-xilinx-linux:1.74.0:r0:cortexa72-cortexa53:3:c5930586d824b57e82b36a901625b32ce90df4d104594e0efc0d055438777295_populate_sysroot.tgz'
	#1: sstate_unpack_package, /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/boost/1.74.0-r0/temp/run.sstate_unpack_package.424904, line 144
	#2: main, /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/boost/1.74.0-r0/temp/run.sstate_unpack_package.424904, line 154
ERROR: Error executing a python function in exec_python_func() autogenerated:
I'm running on a native Linux machine (not a VM).  I started with the files on a shared network drive but found many reports of that not working (now using local home directory).  I initially copied the xilinx-zcu102-2021.1 directory from the shared drive but found reports of copied files not working so I started from scratch on my local drive.
I have all of the petalinux packages installed.
I have my shell set to bash.
I've tried reinstalling petalinux.
I've tried deleting the "xilinx-zcu102-2021.1/build" and "xilinx-zcu102-2021.1/components" folders and rebuilding.
I've tried using "petalinux-build -x mrproper"
I've run out of things to try.
There are dozens of forum threads discussing petalinux installation and usage problems.  Unfortunately, a few users that "solved" the issue are not really sure what fixed the problems:
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2020-2-Build-Error-Vitis-AI-custom-platform-creation/td-p/1258530
https://forums.xilinx.com/t5/Embedded-Linux/Bizarre-Python-errors/td-p/777385
Any other suggestions?
hokim
Your error message means the following sstate file is corrupted
 At first of all, you should figure out where it comes, i.e. whether it comes from petalinux site or local directory  using the following command
$ petalinux-build -c '-e petalinux-image-minimal' | grep ^SSTATE_MIRRORS=
I confirmed the tgz file on petalinux site is correct
http://petalinux.xilinx.com/sswreleases/rel-v$%7bPETALINUX_VER%25%25.*%7d/aarch64/sstate-cache/c0/55/
In such case, I can build gmp packages without error message
build/tmp/work/cortexa72-cortexa53-xilinx-linux/gmp/6.2.0-r0/temp/log.do_package_write_rpm_setscene:
DEBUG: Fetcher accessed the network with the command /usr/bin/env wget -t 2 -T 30 --passive-ftp --no-check-certificate -O /home/hokim/Downloads/xilinx-zcu102-2021.1/build/sstate-cache/c0/55/sstate:gmp:cortexa72-cortexa53-xilinx-linux:6.2.0:r0:cortexa72-cortexa53:3:c0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz -P /home/hokim/Downloads/xilinx-zcu102-2021.1/build/sstate-cache 'http://petalinux.xilinx.com/sswreleases/rel-v%24%7BPETALINUX_VER%25%25.%2A%7D/aarch64/sstate-cache/c0/55/sstate%3Agmp%3Acortexa72-cortexa53-xilinx-linux%3A6.2.0%3Ar0%3Acortexa72-cortexa53%3A3%3Ac0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz'
DEBUG: Executing shell function sstate_unpack_package
deploy-rpms/
DEBUG: Shell function sstate_unpack_package finished
DEBUG: Executing python function sstate_hardcode_path_unpack
DEBUG: Python function sstate_hardcode_path_unpack finished
DEBUG: Executing python function uninative_changeinterp
DEBUG: Python function uninative_changeinterp finished
DEBUG: Staging files from /home/hokim/Downloads/xilinx-zcu102-2021.1/build/tmp/work/cortexa72-cortexa53-xilinx-linux/gmp/6.2.0-r0/deploy-rpms to /home/hokim/Downloads/xilinx-zcu102-2021.1/build/tmp/deploy/rpm
DEBUG: Python function do_package_write_rpm_setscene finished
jimcox
Here's the output of that command:
SSTATE_MIRRORS="\nfile://.* file:///proj/yocto/2021.1/stable/daily-sstatecache_2021/aarch64/PATH\n  file://.* http://petalinux.xilinx.com/sswreleases/rel-v\${PETALINUX_VER%%.*}/aarch64/sstate-cache/PATH;downloadfilename=PATH \n "
jimcox
I manually downloaded http://petalinux.xilinx.com/sswreleases/rel-v2021/aarch64/sstate-cache/c0/55/sstate:gmp:cortexa72-cortexa53-xilinx-linux:6.2.0:r0:cortexa72-cortexa53:3:c0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz  and was able to use tar -xvf without issues.  However, when I try to expand the existing file in the petalinux build/sstate-cache/c0/55 directory I get this error:
tar: Cannot connect to sstate: resolve failed
Oddly, comparing the two files with "cmp -l" shows no differences and they have the same number of bytes.
The only difference appears to the filename itself.
vs.
sstate-gmp-cortexa72-cortexa53-xilinx-linux-6.2.0-r0-cortexa72-cortexa53-3-c0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz
The version in the local sstate-cache directory has several colons in the name.  I copied the file with the colons to "new_file.tgz" and then tar could open it without any issues.
This also works:
tar -xvf sstate:gmp:cortexa72-cortexa53-xilinx-linux:6.2.0:r0:cortexa72-cortexa53:3:c0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz --force-local
Note the "--force-local" option.  Apparently, tar sees the colons and expects to be accessing a remote tape drive.
Why does the local copy of the .tgz file have colons in the name when the version on the petalinux web site does not?
jimcox
As a workaround, I added an alias for tar:
alias tar='tar --force-local'
The petalinux-build process got a lot further this time.  Unfortunately, I ran into some ERROR 404 issues later in the process:
/usr/bin/env wget -t 2 -T 30 --passive-ftp --no-check-certificate -P /home/MY_USER/Development/Tutorials/petalinux/xilinx-zcu102-2021.1/build/downloads 'http://downloads.yoctoproject.org/mirror/sources/git2_github.com.Xilinx.linux-xlnx.git.tar.gz'
--2021-07-28 09:11:46--  http://downloads.yoctoproject.org/mirror/sources/git2_github.com.Xilinx.linux-xlnx.git.tar.gz
Resolving downloads.yoctoproject.org (downloads.yoctoproject.org)... 198.145.29.63
Connecting to downloads.yoctoproject.org (downloads.yoctoproject.org)|198.145.29.63|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2021-07-28 09:11:46 ERROR 404: Not Found.
I used a web browser to see what was available at that URL and, sure enough, there are no Xilinx files.
sandeepg
Hi @jimcox ,
Can you try using build tools under Yocto settings? Also can you share the minor version of Ubuntu-20.04? 20.04.x
$ petalinux-build -x mrproper
$ petalinux-config
$ cat project-spec/configs/config | grep -i buildtools
CONFIG_YOCTO_BUILDTOOLS_EXTENDED=y
$ petalinux-build
Sandeep
jimcox
@sandeepg
Here's the output:
# CONFIG_YOCTO_BUILDTOOLS_EXTENDED is not set
That variable is commented out in the config file.  That appears to be the default as I did not make any changes.
The Linux machine just ran some updates so it's on 20.04.02 LTS.
I was able to avoid the ERROR 404 issues by installing the SSTATE-CACHE files locally.  I followed the guide on this page: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842475/PetaLinux+Yocto+Tips#PetaLinuxYoctoTips-HowtoreducebuildtimeusingSSTATECACHE
I checked http://downloads.yoctoproject.org/mirror/sources/ again and there are no Xilinx files available.
hokim
Could you check the md5sum of the tgz file and tar output after you reproduce original error message?
$ cd <peta-proj-dir>
$ md5sum ./build/sstate-cache/c0/55/sstate\:gmp\:cortexa72-cortexa53-xilinx-linux\:6.2.0\:r0\:cortexa72-cortexa53\:3\:c0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz
725e33c69a2bb4b813790757a265b4e9  ./build/sstate-cache/c0/55/sstate:gmp:cortexa72-cortexa53-xilinx-linux:6.2.0:r0:cortexa72-cortexa53:3:c0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz
$ tar tvzf ./build/sstate-cache/c0/55/sstate\:gmp\:cortexa72-cortexa53-xilinx-linux\:6.2.0\:r0\:cortexa72-cortexa53\:3\:c0553a2128001be7d21392fad8c4617d107cc3720895da1fe5208bc29bdfb677_package_write_rpm.tgz
drwxr-xr-x 64843/100         0 2021-06-09 11:36 deploy-rpms/
drwxr-xr-x 64843/100         0 2021-06-09 11:36 deploy-rpms/cortexa72_cortexa53/
-rw-r--r-- 64843/100     24696 2021-06-09 11:36 deploy-rpms/cortexa72_cortexa53/libgmp-lic-6.2.0-r0.0.cortexa72_cortexa53.rpm
-rw-r--r-- 64843/100    585560 2021-06-09 11:36 deploy-rpms/cortexa72_cortexa53/libgmp-dbg-6.2.0-r0.0.cortexa72_cortexa53.rpm
-rw-r--r-- 64843/100     14384 2021-06-09 11:36 deploy-rpms/cortexa72_cortexa53/libgmpxx4-6.2.0-r0.0.cortexa72_cortexa53.rpm
-rw-r--r-- 64843/100     35180 2021-06-09 11:36 deploy-rpms/cortexa72_cortexa53/libgmp-dev-6.2.0-r0.0.cortexa72_cortexa53.rpm
-rw-r--r-- 64843/100    119220 2021-06-09 11:36 deploy-rpms/cortexa72_cortexa53/libgmp-doc-6.2.0-r0.0.cortexa72_cortexa53.rpm
-rw-r--r-- 64843/100    401684 2021-06-09 11:36 deploy-rpms/cortexa72_cortexa53/libgmp-src-6.2.0-r0.0.cortexa72_cortexa53.rpm
-rw-r--r-- 64843/100    206212 2021-06-09 11:36 deploy-rpms/cortexa72_cortexa53/libgmp10-6.2.0-r0.0.cortexa72_cortexa53.rpm
jimcox
md5sum output is the same.
I can only get the tar command to work when adding the "--force-local" option.  The colons in the filename confuse tar.
remydruyer
Hello jimcox,
Did you found a solution? I have exactly the same problem as you when trying to run petalinux-build for a ZCU102.
Best regards
jimcox
I was able to find a couple of workarounds.  Look at my two responses above:
https://forums.xilinx.com/t5/Embedded-Linux/petalinux-2021-1-tar-and-gzip-errors-Unable-to-get-through-a/m-p/1270008/highlight/true#M51818
https://forums.xilinx.com/t5/Embedded-Linux/petalinux-2021-1-tar-and-gzip-errors-Unable-to-get-through-a/m-p/1270117/highlight/true#M51830
remydruyer
Thanks a lot!
