Visitor rocco.brandi
petalinux add I2C support to U-boot
Hi all,
I am trying to add I2C support to U-boot, in order to acces an EEPROM where are stored some boot information.
I have seen that I2C support is enabled in zynq-common.h (line 186):
#define CONFIG_SYS_I2C_ZYNQ
/* I2C */
#if defined(CONFIG_SYS_I2C_ZYNQ)
# define CONFIG_CMD_I2C
# define CONFIG_SYS_I2C
# define CONFIG_SYS_I2C_ZYNQ_SPEED 100000
# define CONFIG_SYS_I2C_ZYNQ_SLAVE 0
#endif
zynq-common.h is included in zynq_zc70x.h file. but it seems that when I build u-boot through petalinux, the configuration header file zynq_zc70x.h is replaced by platform-top.h file that contains only the enviroment settings.
here the line from the verbose (in red the specific command):
[ALL  ] if [ -f "/home/user/petalinux_projetcs/Software_337/Software/zynq/dtx_a350/subsystems/linux/configs/u-boot/platform-top.h" ]; then rsync "/home/user/petalinux_projetcs/Software_337/Software/zynq/dtx_a350/subsystems/linux/configs/u-boot"/*.h "/home/user/petalinux_projetcs/Software_337/Software/zynq/dtx_a350/build/linux/u-boot/src/u-boot-plnx_ORIG/include/configs"/; mv "/home/user/petalinux_projetcs/Software_337/Software/zynq/dtx_a350/build/linux/u-boot/src/u-boot-plnx_ORIG/include/configs/platform-top.h"  "/home/user/petalinux_projetcs/Software_337/Software/zynq/dtx_a350/build/linux/u-boot/src/u-boot-plnx_ORIG/include/configs/zynq_zc70x.h"; fi
after that, the configuration files are called :
[INFO ] generate linux/u-boot configuration files
[ALL ] make O=/home/user/petalinux_projetcs/Software_337/Software/zynq/dtx_a350/build/linux/u-boot/u-boot-plnx_ORIG -C /home/user/petalinux_projetcs/Software_337/Software/zynq/dtx_a350/build/linux/u-boot/src/u-boot-plnx_ORIG -j2 zynq_zc70x_config || exit 255
but where are the settings from the configuration header file if it has been replaced?
I have attached all the log file when building u-boot
Rocco
Re: petalinux add I2C support to U-boot
just to let you know,
I have managed to enable I2C in U-boot.
I have noticed that zynq_zc70x.h is replaced by platform-top.h
this file is stored in <$PETALINUX-PROJECT-DIRECTORY>/subsystems/linux/configs/u-boot.
so I have added  the following settings from file <$U-BOOT-SOURCE-DIRECTORY>/include/configs/zynq-common.h to file  <$PETALINUX-PROJECT-DIRECTORY>/subsystems/linux/configs/u-boot/platform-top.h:
/* I2C */
#endif
and it worked! Of course to have acces to the I2C buses, the bitsream file must be loaded before u-boot.
I hope it could help someone else.
Best Regards,
Rocco
@roccobrandi
Thanks for updating the thread with the solution. I will have this updated into answer record.
Achutha
Scholar vanmierlo
That is of course only when you're using a MicroBlaze or route I2C through EMIO to PL pins on a Zynq. If I2C is routed through MIO pins on a Zynq this should not be required.
