Newbie hankk
petalinux-build error on petalinux-2017.4 with TRD-2017.4
I am trying to excute the TRD-2017.4 with petalinux-2017.4 on Ubuntu 16.04 installed in paralleles(a virtual machine) on Macbook.
-I downloaded TRD-2017.4 for ZCU-102 version 1.1
-Now I am following the link http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2017.4+-+Design+Module+1 exactly step by step, but when I execute petalinux-build command I get an error(text file attatched) on the terminal.
Scholar austin
Re: petalinux-build error on petalinux-2017.4 with TRD-2017.4
Check that you have internet access in your VM,
Also, sometimes the open sources repositories undergo maintenance (their websites are down).  Try later.
Austin Lesea
Principal Engineer
Xilinx San Jose
Newbie hankk
Thankyou so much! It finally worked. I tried it this morning and it finally worked. So I guess it was the server issue, because I had a good internet connection then and now.
Thankyou.
