sudipdatta10
petalinux-build failing for u-boot (for custom zynq 7000 board)
I could configure a project for a zynq board with custom peripherals using:
petalinux-config --get-hw-description=hwdesc/
however when trying to build u-boot for the board, I get:
| make[1]: Leaving directory '/home/user/xilinx/PcocPoc/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+git999-r0/u-boot-xlnx-v2016.07-xilinx+git999'
| Makefile:150: recipe for target 'sub-make' failed
| make: *** [sub-make] Error 2
| make: Leaving directory '/home/user/xilinx/u-boot-xlnx'
| ERROR: oe_runmake failed
| ERROR: Function failed: do_compile (log file is located at /home/user/xilinx/PcocPoc/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+git999-r0/temp/log.do_compile.30098)
ERROR: Task 5 (/home/user/xilinx/petalinuxInstallation/components/yocto/source/arm/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2016.07.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 954 tasks of which 715 didn't need to be rerun and 1 failed.
No currently running tasks (954 of 964)
I did take care to bring u-boot-xlnx to release corresponding to 'xilinx-v2016.4', but that didn't help.
Any insights on what might be going wrong and/or how to fix it will be great.
shabbirk
Can you try sourcing the toolchain path and try again:
source /opt/Xilinx/SDK/2016.4/settings64.sh (or .csh based on shell)
Best Regards
Shabbir
sudipdatta10
Hi Shabbir,
I tried with that as well, but same error message.
Sorry for this newbie question, but am very new to this domain - where should I be looking to find the 954th task?
debrajr
Have you made any changes in the the fields: u-boot Configuration -> or Linux Component Selections -> u-boot in petalinux-config? Can you also let us know which OS are you using?
Debraj
shabbirk
You can find the failing task in the below path :
Best Regards
Shabbir
sudipdatta10
@debrajr am on Ubuntu 16.04.2 LTS. I made no changes to `u-boot configuration`. It's set to PetaLinux u-boot config. In `Linux Component Selection` I just pointed u-boot to ext-local-src (and the local src was brought to release 'xilinx-v2016.4'). `First stage bootloader` and `Auto update ps7_init` were pre-selected.
@shabbirk I did look at this log file but all I could infer from it is that there is some issue with `u-boot-xlnx_2016.07.bb` but not much beyond that. I am attaching the log file. Please let me know if it shows any other issues.
Thanks a lot.
Sudip
jborden
I am having a similar problem.
I am attaching the build log but notice this:
"default_bootcmd=echo No boot method defined!!!\0"
before the compile fails:
ERROR: u-boot-xlnx-v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0 do_compile: oe_runmake failed
ERROR: u-boot-xlnx-v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0 do_compile: Function failed: do_compile (log file is located at /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/temp/log.do_compile.11810)
ERROR: Logfile of failure stored in: /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/temp/log.do_compile.11810
I have tried different config options, but am not sure what I am doing wrong.
Jonathan
debrajr
As you are using ext-local-src for U-boot, please re-check if you have done the following:
a) Copied the downloaded U-boot source from git  to <plnx-proj-root>/components/ext_sources/<MY-U-BOOT>
b) Run petalinux-build -x mrproper and re-try petalinux-build to check.
Debraj
shabbirk
Hi sudipdatta10 &  jborden
Lets follow this way and get back to me, if still it doesnt compile for you. Atleast this is what is working at my end:
1. Create an ext_sources directory under <petalinux/>/components/
2. cd <petalinux/>/components/ext_sources
3. git clone https://github.com/Xilinx/u-boot-xlnx.git
4. Apply the attached uboot patch (use command  git apply PATCH_NAME)
5. petalinux-config ---> Linux Components selection ---> External u-boot local source settings ---> ENTER external uboot local source path.
6. petalinux-build
Attached the patch below and config option snapshot
Shabbir
sudipdatta10
Hi Shabbir,
No luck with this either. However, when I did try creating the uboot file using the ZC702 BSP downloaded from Petalinux site, it built without any issues. I guess, this indicates either an issue with how I am creating the project or with the hdf file I am using.
For the former I just did:
petalinux-create --type project --template zynq --name PcocPoc
and followed the instructions you posted.
I also sourced components/yocto/source/arm/environment-setup-cortexa9hf-neon-xilinx-linux-gnueabi, after installing petalinux tools.
For the latter, the hdf file is at https://www.dropbox.com/sh/uv5xqa0900gfjk4/AADbT4ebuCuSTLrN8zHl5RGWa?dl=0 . It'll be great if you could have a look at it, if its not a lot of trouble, and point out if there are any glaring errors.
Thanks a lot.
Sudip
jborden
Hi, that didn't work for me either, got error in same place:
I'm pasting where I think the problem starts but could be totally wrong ...
| /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/include/configs/platform-auto.h:137:53: warning: backslash and newline separated by space
|   "default_bootcmd=echo No boot method defined!!!\0" \
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/fpga
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/hwmon
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/mtd/onenand
|    arm-linux-gnueabihf-ld.bfd     -r -o cmd/built-in.o cmd/boot.o cmd/bootm.o cmd/help.o cmd/version.o cmd/source.o cmd/bdinfo.o cmd/bootefi.o cmd/cache.o cmd/clk.o cmd/console.o cmd/echo.o cmd/elf.o cmd/exit.o cmd/ext4.o cmd/fdt.o cmd/fpga.o cmd/fs.o cmd/itest.o cmd/load.o cmd/mem.o cmd/misc.o cmd/pcmcia.o cmd/sf.o cmd/spi.o cmd/test.o cmd/ximg.o cmd/nvedit.o cmd/disk.o
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/mtd/spi
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/net
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/input
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/mailbox
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/net/phy
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/memory
| /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/common/board_f.c: In function 'init_baud_rate':
| /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/common/board_f.c:144:46: error: 'CONFIG_BAUDRATE' undeclared (first use in this function)
|   gd->baudrate = getenv_ulong("baudrate", 10, CONFIG_BAUDRATE);
| /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/common/board_f.c:144:46: note: each undeclared identifier is reported only once for each function it appears in
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/misc
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/pcmcia
|    rm -f drivers/net/phy/built-in.o; arm-linux-gnueabihf-ar rcs drivers/net/phy/built-in.o
| /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build:280: recipe for target 'common/board_f.o' failed
| make[2]: *** [common/board_f.o] Error 1
| /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/Makefile:1210: recipe for target 'common' failed
| make[1]: *** [common] Error 2
| make[1]: *** Waiting for unfinished jobs....
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/pwm
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/reset
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/rtc
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/soc
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/sound
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/spmi
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/thermal
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/timer
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/tpm
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/twserial
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/video
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/video/bridge
| make -f /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git/scripts/Makefile.build obj=drivers/watchdog
| make[1]: Leaving directory '/home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/build'
| make: Leaving directory '/home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/git'
| WARNING: /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/temp/run.do_compile.24736:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/jon/petalinux/JABR_DAC/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+gitAUTOINC+0b94ce5ed4-r0/temp/log.do_compile.24736)
ERROR: Task 84 (/home/jon/petalinux/components/yocto/source/arm/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2016.07.bb, do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2297 tasks of which 2286 didn't need to be rerun and 1 failed.
Waiting for 0 running tasks to finish:
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
shabbirk
PFA BOOT.bin
shabbirk
PFA image.ub
Test these binaries once, which has been build with your HDF?
heaventong
i have same question
i use exter kernel  and  u-boot file
can't config use tools petalinux-config -c kernel and same with u-boot
error is follow :
NOTE: Executing RunQueue Tasks
linux-xlnx-4.6-xilinx+git999-r0 do_compile: NOTE: linux-xlnx: compiling from external source tree /home/heavenong/Documents/Xilinx_code/test_fifo/arm/components/ext_sources/linux-Digilent-Dev-master
ERROR: u-boot-xlnx-v2016.07-xilinx+git999-r0 do_configure: oe_runmake failed
ERROR: u-boot-xlnx-v2016.07-xilinx+git999-r0 do_configure: Function failed: do_configure (log file is located at /home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+git999-r0/temp/log.do_configure.23795)
ERROR: Logfile of failure stored in: /home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+git999-r0/temp/log.do_configure.23795
Log data follows:
| DEBUG: Executing python function externalsrc_configure_prefunc
| DEBUG: Python function externalsrc_configure_prefunc finished
| DEBUG: Executing python function sysroot_cleansstate
| DEBUG: Python function sysroot_cleansstate finished
| DEBUG: Executing shell function do_configure
| NOTE: make CROSS_COMPILE=arm-linux-gnueabihf- CC=arm-linux-gnueabihf-gcc --sysroot=/home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/sysroots/plnx_arm V=1 HOSTCC=gcc -isystem/home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -L/home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/sysroots/x86_64-linux/usr/lib -L/home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath-link,/home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath-link,/home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath,/home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath,/home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/sysroots/x86_64-linux/lib -Wl,-O1 -C /home/heavenong/Documents/Xilinx_code/test_fifo/arm/components/ext_sources/u-boot-Digilent-Dev-master O=
| make: Entering directory '/home/heavenong/Documents/Xilinx_code/test_fifo/arm/components/ext_sources/u-boot-Digilent-Dev-master'
| make: *** No rule to make target `zynq_zc702_config'. Stop.
| Makefile:838: recipe for target 'zynq_zc702_config' failed
| make: *** [zynq_zc702_config] Error 1
| make: Leaving directory '/home/heavenong/Documents/Xilinx_code/test_fifo/arm/components/ext_sources/u-boot-Digilent-Dev-master'
| WARNING: /home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+git999-r0/temp/run.do_configure.23795:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_configure (log file is located at /home/heavenong/Documents/Xilinx_code/test_fifo/arm/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2016.07-xilinx+git999-r0/temp/log.do_configure.23795)
ERROR: Task 76 (/home/heavenong/Downloads/Xilinx/Install/pkg/components/yocto/source/arm/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2016.07.bb, do_configure) failed with exit code '1'
NOTE: Tasks Summary: Attempted 1756 tasks of which 1331 didn't need to be rerun and 1 failed.
lucas_zyq
I have the same error when "petalinux-build"
ERROR: u-boot-xlnx-v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0 do_compile: oe_runmake failed
ERROR: u-boot-xlnx-v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0 do_compile: Function failed: do_compile (log file is located at /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/temp/log.do_compile.68742)
ERROR: Logfile of failure stored in: /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/temp/log.do_compile.68742
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8 CROSS_COMPILE=arm-xilinx-linux-gnueabi- CC=arm-xilinx-linux-gnueabi-gcc --sysroot=/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/plnx_arm V=1 HOSTCC=gcc -isystem/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/usr/include -O2 -pipe -L/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/usr/lib -L/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath-link,/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath-link,/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/lib -Wl,-rpath,/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/usr/lib -Wl,-rpath,/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/lib -Wl,-O1 -C /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git O=/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/build all EXT_DTB=/home/lucas/work/petalinux/my_7z020/build/tmp/deploy/images/plnx_arm/plnx_arm-system.dtb
| make: Entering directory '/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git'
| make -C /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/build KBUILD_src=/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git \
| -f /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/Makefile all
| make[1]: Entering directory '/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/build'
| make -f /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/Makefile silentoldconfig
| make -f /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/scripts/Makefile.build obj=scripts/basic
| ln -fsn /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git source
| /bin/sh /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/scripts/mkmakefile \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git . 2017 01
| rm -f .tmp_quiet_recordmcount
| GEN ./Makefile
| make -f /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/scripts/Makefile.build obj=scripts/kconfig silentoldconfig
| mkdir -p include/config include/generated
| scripts/kconfig/conf --silentoldconfig Kconfig
| make -f /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/scripts/Makefile.autoconf || \
| { rm -f include/config/auto.conf; false; }
| mkdir -p include/asm
| if [ -d /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/mach-zynq/include/mach ]; then \
| dest=arch/arm/mach-zynq/include/mach; \
| else \
| dest=arch/arm/include/asm/arch-zynq; \
| fi; \
| ln -fsn /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/$dest include/asm/arch
| set -e; : ' CHK include/config.h'; mkdir -p include/; (echo "/* Automatically generated - do not edit */"; for i in $(echo "" | sed 's/,/ /g'); do echo \#define CONFIG_$i | sed '/=/ {s/=/ /;q; } ; { s/$/ 1/; }'; done; echo \#define CONFIG_BOARDDIR board/xilinx/zynq; echo \#include \<config_defaults.h\>; echo \#include \<config_uncmd_spl.h\>; echo \#include \<configs/"platform-top".h\>; echo \#include \<asm/config.h\>; echo \#include \<config_fallbacks.h\>;) < /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/scripts/Makefile.autoconf > include/config.h.tmp; if [ -r include/config.h ] && cmp -s include/config.h include/config.h.tmp; then rm -f include/config.h.tmp; else : ' UPD include/config.h'; mv -f include/config.h.tmp include/config.h; fi
| arm-xilinx-linux-gnueabi-gcc --sysroot=/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/plnx_arm -E -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -O2 -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__KERNEL__ -D__UBOOT__ -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -Iinclude -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/include -include /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/linux/kconfig.h -nostdinc -isystem /home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-gnueabi/../../lib/arm-xilinx-linux-gnueabi/gcc/arm-xilinx-linux-gnueabi/6.2.1/include -DDO_DEPS_ONLY -dM /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/common.h > u-boot.cfg.tmp && { grep 'define CONFIG_' u-boot.cfg.tmp > u-boot.cfg; rm u-boot.cfg.tmp; } || { rm u-boot.cfg.tmp; false; }
| arm-xilinx-linux-gnueabi-gcc --sysroot=/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/plnx_arm -x c -DDO_DEPS_ONLY -M -MP -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -O2 -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__KERNEL__ -D__UBOOT__ -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -Iinclude -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/include -include /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/linux/kconfig.h -nostdinc -isystem /home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-gnueabi/../../lib/arm-xilinx-linux-gnueabi/gcc/arm-xilinx-linux-gnueabi/6.2.1/include -MQ include/config/auto.conf /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/common.h > include/autoconf.mk.dep || { rm include/autoconf.mk.dep; false; }
| sed -n -f /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/tools/scripts/define2mk.sed u-boot.cfg | while read line; do if [ -n "" ] || ! grep -q "${line%=*}=" include/config/auto.conf; then echo "$line"; fi done > include/autoconf.mk
| touch include/config/auto.conf
| set -e; : ' CHK include/config/uboot.release'; mkdir -p include/config/; echo "2017.01$(/bin/sh /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/scripts/setlocalversion /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git)" < include/config/auto.conf > include/config/uboot.release.tmp; if [ -r include/config/uboot.release ] && cmp -s include/config/uboot.release include/config/uboot.release.tmp; then rm -f include/config/uboot.release.tmp; else : ' UPD include/config/uboot.release'; mv -f include/config/uboot.release.tmp include/config/uboot.release; fi
| set -e; : ' CHK include/generated/timestamp_autogenerated.h'; mkdir -p include/generated/; (if test -n "${SOURCE_DATE_EPOCH}"; then SOURCE_DATE="@${SOURCE_DATE_EPOCH}"; DATE=""; for date in gdate date.gnu date; do ${date} -u -d "${SOURCE_DATE}" >/dev/null 2>&1 && DATE="${date}"; done; if test -n "${DATE}"; then LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_DATE "%b %d %C%y"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_TIME "%T"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_TZ "%z"'; LC_ALL=C ${DATE} -u -d "${SOURCE_DATE}" +'#define U_BOOT_DMI_DATE "%m/%d/%Y"'; else return 42; fi; else LC_ALL=C date +'#define U_BOOT_DATE "%b %d %C%y"'; LC_ALL=C date +'#define U_BOOT_TIME "%T"'; LC_ALL=C date +'#define U_BOOT_TZ "%z"'; LC_ALL=C date +'#define U_BOOT_DMI_DATE "%m/%d/%Y"'; fi) < /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/Makefile > include/generated/timestamp_autogenerated.h.tmp; if [ -r include/generated/timestamp_autogenerated.h ] && cmp -s include/generated/timestamp_autogenerated.h include/generated/timestamp_autogenerated.h.tmp; then rm -f include/generated/timestamp_autogenerated.h.tmp; else : ' UPD include/generated/timestamp_autogenerated.h'; mv -f include/generated/timestamp_autogenerated.h.tmp include/generated/timestamp_autogenerated.h; fi
| GEN ./Makefile
| if [ -f /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/.config -o -d /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/config ]; then \
| echo >&2 " /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git is not clean, please run 'make mrproper'"; \
| echo >&2 " in the '/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git' directory.";\
| /bin/false; \
| fi;
| set -e; : ' CHK include/generated/version_autogenerated.h'; mkdir -p include/generated/; (echo \#define PLAIN_VERSION \"2017.01\"; echo \#define U_BOOT_VERSION \"U-Boot \" PLAIN_VERSION; echo \#define CC_VERSION_STRING \"$(LC_ALL=C arm-xilinx-linux-gnueabi-gcc --sysroot=/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/plnx_arm --version | head -n 1)\"; echo \#define LD_VERSION_STRING \"$(LC_ALL=C arm-xilinx-linux-gnueabi-ld.bfd --version | head -n 1)\"; ) < include/config/uboot.release > include/generated/version_autogenerated.h.tmp; if [ -r include/generated/version_autogenerated.h ] && cmp -s include/generated/version_autogenerated.h include/generated/version_autogenerated.h.tmp; then rm -f include/generated/version_autogenerated.h.tmp; else : ' UPD include/generated/version_autogenerated.h'; mv -f include/generated/version_autogenerated.h.tmp include/generated/version_autogenerated.h; fi
| make -f /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/scripts/Makefile.build obj=.
| mkdir -p lib/
| mkdir -p arch/arm/lib/
| arm-xilinx-linux-gnueabi-gcc --sysroot=/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/plnx_arm -Wp,-MD,lib/.asm-offsets.s.d -nostdinc -isystem /home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-gnueabi/../../lib/arm-xilinx-linux-gnueabi/gcc/arm-xilinx-linux-gnueabi/6.2.1/include -Iinclude -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/include -include /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/linux/kconfig.h -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/. -I. -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/mach-zynq/include -DDO_DEPS_ONLY -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(asm_offsets)" -D"KBUILD_MODNAME=KBUILD_STR(asm_offsets)" -fverbose-asm -S -o lib/asm-offsets.s /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/lib/asm-offsets.c
| arm-xilinx-linux-gnueabi-gcc --sysroot=/home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/plnx_arm -Wp,-MD,arch/arm/lib/.asm-offsets.s.d -nostdinc -isystem /home/lucas/work/petalinux/my_7z020/build/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-gnueabi/../../lib/arm-xilinx-linux-gnueabi/gcc/arm-xilinx-linux-gnueabi/6.2.1/include -Iinclude -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/include -include /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/linux/kconfig.h -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/. -I. -D__KERNEL__ -D__UBOOT__ -Wall -Wstrict-prototypes -Wno-format-security -fno-builtin -ffreestanding -Os -fno-stack-protector -fno-delete-null-pointer-checks -g -fstack-usage -Wno-format-nonliteral -Werror=date-time -D__ARM__ -marm -mno-thumb-interwork -mabi=aapcs-linux -mword-relocations -fno-pic -mno-unaligned-access -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -msoft-float -pipe -march=armv7-a -D__LINUX_ARM_ARCH__=7 -I/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/mach-zynq/include -DDO_DEPS_ONLY -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(asm_offsets)" -D"KBUILD_MODNAME=KBUILD_STR(asm_offsets)" -fverbose-asm -S -o arch/arm/lib/asm-offsets.s /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/lib/asm-offsets.c
| In file included from /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-top.h:2:0,
| from include/config.h:5,
| from /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/common.h:18,
| from /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/lib/asm-offsets.c:15:
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:25:0: warning: "CONFIG_SYS_CACHELINE_SIZE" redefined
| #define CONFIG_SYS_CACHELINE_SIZE 32
| In file included from /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/linux/kconfig.h:4:0,
| from <command-line>:0:
| include/generated/autoconf.h:59:0: note: this is the location of the previous definition
| #define CONFIG_SYS_CACHELINE_SIZE 64
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:44:61: warning: backslash and newline separated by space
| #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_INIT_RAM_ADDR + \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:45:32: warning: backslash and newline separated by space
| CONFIG_SYS_INIT_RAM_SIZE - \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:71:0: warning: "CONFIG_MMC" redefined
| #define CONFIG_MMC
| include/generated/autoconf.h:117:0: note: this is the location of the previous definition
| #define CONFIG_MMC 1
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:158:15: warning: backslash and newline separated by space
| SERIAL_MULTI \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:159:14: warning: backslash and newline separated by space
| CONSOLE_ARG \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:160:12: warning: backslash and newline separated by space
| PSSERIAL0 \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:161:43: warning: backslash and newline separated by space
| "nc=setenv stdout nc;setenv stdin nc;\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:163:63: warning: backslash and newline separated by space
| "importbootenv=echo \"Importing environment from SD ...\"; " \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:164:51: warning: backslash and newline separated by space
| "env import -t ${loadbootenv_addr} $filesize\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:165:77: warning: backslash and newline separated by space
| "loadbootenv=load mmc $sdbootdev:$partid ${loadbootenv_addr} ${bootenv}\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:166:73: warning: backslash and newline separated by space
| "sd_uEnvtxt_existence_test=test -e mmc $sdbootdev:$partid /uEnv.txt\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:167:14: warning: backslash and newline separated by space
| "uenvboot=" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:168:43: warning: backslash and newline separated by space
| "if run sd_uEnvtxt_existence_test; then" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:169:21: warning: backslash and newline separated by space
| "run loadbootenv" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:170:46: warning: backslash and newline separated by space
| "echo Loaded environment from ${bootenv};" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:171:27: warning: backslash and newline separated by space
| "run importbootenv; \0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:172:110: warning: backslash and newline separated by space
| "sdboot=echo boot Petalinux; run uenvboot ; mmcinfo && fatload mmc 0 ${netstart} ${kernel_img} && bootm \0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:173:18: warning: backslash and newline separated by space
| "autoload=no\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:174:27: warning: backslash and newline separated by space
| "clobstart=0x10000000\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:175:26: warning: backslash and newline separated by space
| "netstart=0x10000000\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:176:29: warning: backslash and newline separated by space
| "dtbnetstart=0x11800000\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:177:26: warning: backslash and newline separated by space
| "loadaddr=0x10000000\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:178:24: warning: backslash and newline separated by space
| "boot_img=BOOT.BIN\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:179:50: warning: backslash and newline separated by space
| "load_boot=tftpboot ${clobstart} ${boot_img}\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:180:170: warning: backslash and newline separated by space
| "update_boot=setenv img boot; setenv psize ${bootsize}; setenv installcmd \"install_boot\"; run load_boot ${installcmd}; setenv img; setenv psize; setenv installcmd\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:181:82: warning: backslash and newline separated by space
| "install_boot=mmcinfo && fatwrite mmc 0 ${clobstart} ${boot_img} ${filesize}\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:182:26: warning: backslash and newline separated by space
| "kernel_img=image.ub\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:183:54: warning: backslash and newline separated by space
| "load_kernel=tftpboot ${clobstart} ${kernel_img}\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:184:180: warning: backslash and newline separated by space
| "update_kernel=setenv img kernel; setenv psize ${kernelsize}; setenv installcmd \"install_kernel\"; run load_kernel ${installcmd}; setenv img; setenv psize; setenv installcmd\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:185:86: warning: backslash and newline separated by space
| "install_kernel=mmcinfo && fatwrite mmc 0 ${clobstart} ${kernel_img} ${filesize}\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:186:71: warning: backslash and newline separated by space
| "cp_kernel2ram=mmcinfo && fatload mmc 0 ${netstart} ${kernel_img}\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:187:25: warning: backslash and newline separated by space
| "dtb_img=system.dtb\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:188:48: warning: backslash and newline separated by space
| "load_dtb=tftpboot ${clobstart} ${dtb_img}\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:189:160: warning: backslash and newline separated by space
| "update_dtb=setenv img dtb; setenv psize ${dtbsize}; setenv installcmd \"install_dtb\"; run load_dtb test_img; setenv img; setenv psize; setenv installcmd\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:190:117: warning: backslash and newline separated by space
| "sd_update_dtb=echo Updating dtb from SD; mmcinfo && fatload mmc 0:1 ${clobstart} ${dtb_img} && run install_dtb\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:191:101: warning: backslash and newline separated by space
| "fault=echo ${img} image size is greater than allocated place - partition ${img} is NOT UPDATED\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:192:108: warning: backslash and newline separated by space
| "test_crc=if imi ${clobstart}; then run test_img; else echo ${img} Bad CRC - ${img} is NOT UPDATED; fi\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:193:134: warning: backslash and newline separated by space
| "test_img=setenv var \"if test ${filesize} -gt ${psize}\\; then run fault\\; else run ${installcmd}\\; fi\"; run var; setenv var\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:194:58: warning: backslash and newline separated by space
| "netboot=tftpboot ${netstart} ${kernel_img} && bootm\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:195:61: warning: backslash and newline separated by space
| "default_bootcmd=run cp_kernel2ram && bootm ${netstart}\0" \
| /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/include/configs/platform-auto.h:163:2: error: expected identifier or '(' before string constant
| from /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/arch/arm/lib/asm-offsets.c:15:
| #define CONFIG_MMC
| SERIAL_MULTI \
| CONSOLE_ARG \
| PSSERIAL0 \
| "uenvboot=" \
| "run loadbootenv" \
| "autoload=no\0" \
| make[2]: *** [/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/./Kbuild:44: lib/asm-offsets.s] Error 1
| make[2]: *** Waiting for unfinished jobs....
| make[2]: *** [/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/./Kbuild:65: arch/arm/lib/asm-offsets.s] Error 1
| make[1]: *** [/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git/Makefile:1270: prepare0] Error 2
| make[1]: Leaving directory '/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/build'
| make: *** [Makefile:150: sub-make] Error 2
| make: Leaving directory '/home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/git'
| ERROR: Function failed: do_compile (log file is located at /home/lucas/work/petalinux/my_7z020/build/tmp/work/plnx_arm-xilinx-linux-gnueabi/u-boot-xlnx/v2017.01-xilinx-v2017.1+gitAUTOINC+92e3dd638b-r0/temp/log.do_compile.68742)
ERROR: Task (/home/lucas/Xilinx/components/yocto/source/arm/layers/meta-xilinx/recipes-bsp/u-boot/u-boot-xlnx_2017.01.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2366 tasks of which 1864 didn't need to be rerun and 1 failed.
patholden
Is there a resolution for this problem wrt external u-boot and linux source directories?  I cannot build or make changes to the config for u-boot when setting up an external source path for u-boot.  When I try to not use external source for u-boot, I cannot use petalinux-config -c u-boot at all (it's looking for a particular linux-kernel path but it's not honoring the linux external source path).
I've been dealing with petalinux tool problems for at least a week now.
stephenm
Can you do a petalinux-config and check the uboot settings to see what defconfig is being used? Then cross check this to see if the baud ( as it Is complaining of this in your log) is set correctly? You can use the zc702 defconfig as reference.
patholden
I am using the picozed defconfig file because that's the type of board I have with a XC7010 on board.  I got things building finally.  What I did was re-install PetaLinux tools, then I followed one of the tutorials verbatim (again) using the zynq_picozed_defconfig.  Now I am trying to program to see if Linux will come up.
patholden
I'm now able to change and update the u-boot configuration.  U-boot is coming up now, but it's not able to load the image file.  I get the following error message:
reading image.ub
8099700 bytes read in 763 ms (10.1 MiB/s)
Wrong Image Format for bootm command
ERROR: can't get kernel image!
patholden
I've tried using petalinux-package command with "--kernel MY-PROJ/images/linux/zImage" and "--kernel MY-PROJ/images/linux/image.ub" with no luck.  I keep getting the following error from u-boot no matter what I try for a kernel image:
....... TIMEOUT !
Device: sdhci@e0101000
Manufacturer ID: fe
OEM: 14e
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.4.1
High Capacity: Yes
Capacity: 3.5 GiB
Bus Width: 4-bit
Erase Group Size: 512 KiB
HC WP Group Size: 4 MiB
User Capacity: 3.5 GiB
Boot Capacity: 16 MiB ENH
RPMB Capacity: 128 KiB ENH
reading image.ub
Zynq>
stephenm
Is the bootm reading from the correct address? Has the kernel the correct uboot header info (created using mkimage)?
The zynq_picozed_defconfig uses the param below to boot:
CONFIG_BOOTCOMMAND="run $modeboot || run distro_bootcmd"
The modeboot can be seen here (242 to 322)
https://github.com/Xilinx/u-boot-xlnx/blob/41006dd91e3704b6a4be0d1623891335ebe1ceef/include/configs/zynq-common.h
So, depending on the mode pins on your board, uboot will know what option to use. So for example sdboot:
"sdboot=if mmcinfo; then " \
"run uenvboot; " \
"echo Copying Linux from SD to RAM... && " \
"load mmc 0 ${kernel_load_address} ${kernel_image} && " \
"load mmc 0 ${devicetree_load_address} ${devicetree_image} && " \
"load mmc 0 ${ramdisk_load_address} ${ramdisk_image} && " \
"bootm ${kernel_load_address} ${ramdisk_load_address} ${devicetree_load_address}; " \
"fi\0" \
Here, the uboot will copy the images from the bootable device into DDR. It will then use the bootm command
to boot the kernel.
You can try to do this manually to verify that everything is correct with your images
http://www.wiki.xilinx.com/U-boot
