in_peace
petalinux build roofs
why this happened?unable to start bitbale server
stephenm
ParseError in oofs. Not a bitbake file
What is this oofs recipe? Does you have the correct bb file for this recipe?
watari
Hi @in_peace
Would you share the following file to investigate the route cause ?
- bitbake-coockerdaemon.log
Best regards,
in_peace
thanks, the file is here.
in_peace
well, sometimes it workaround,sometimes occurs error,such as nothing provide"roofs"(it seems I do the same operation everytime).So, I am confused about that
watari
Hi @in_peace
Just ask you.
Do you execute petalinux on virtual machine ?
If yes, how many cpu and memory do you set on guest ?
Also how many cpu and memory does your host machine have ?
What kind of storage do you use on host ?
I guess it seems virtual machine or cpu/memory resource issue from your current message...
Best regards,
in_peace
yes,I execute petalinux on VM,also the VM is run on windows server;
8*CPU and 8GB memory in guest;16*CPUs and 64GB memory in host;
storage:SCSI
I do not know if my answer is clear?
watari
Hi @in_peace
Would you change memory size from 8GB to ex. 16GB in guest ?
Also I suggest you to set swap file or swap partition which size is ex. 8GB, if you didn't use swap.
And I suggest you to make sure hyper-vizer setting, too.
Best regards,
in_peace
I do follow your suggestion. And the hyper-vizer means hyper-v?since we run vm on win10 which includes hyper-v and be removed for it can not compatible with vm.
the error is still, what should I do?any other ways to config kernel?
[INFO] generating Kconfig for project
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] generating machine configuration
[INFO] configuring: -kernel
[INFO] bitbake -kernel -c menuconfig
ERROR: Unable to start bitbake server
ERROR: Server log for this session (/home/zlh/mini_sys_petalinux/build/bitbake-cookerdaemon.log):
--- Starting bitbake server pid 8649 at 2020-08-31 11:11:36.230681 ---
ERROR: ParseError in nel: not a BitBake file
ERROR: bitbake failed to configure -kernel
ERROR: Failed to config -kernel.
in_peace
oh,sorry. the command is petalinux-config -c kernel but not -kernel....
