petalinux-config doesn't include Yocto Settings
I am trying a project with Petalinux 2014.2. I have a Zedboard and i use Avnet-Digilent-ZedBoard-v2014.2-final bsp source. Everything is good. Also, ı am a newbie at Petalinux.
For example, I need a serial file transfer package for my device. I realize that my device has not lrzsz package. So ı know I can add this driver. But how?
I found that link about this issue. But this is not a solution for me. Because I don't have this  "<plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf " directory.
https://forums.xilinx.com/t5/Embedded-Linux/Is-there-rzsz-on-petalinux-for-serial-file-transfer/td-p/896544
Also, when ı entered petalinux-config command, I can't see Yocto Settings.
What is missing?
Re: petalinux-config doesn't include Yocto Settings
Please refer to the old user guides for the version you are using
https://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_2/ug976-petalinux-installation.pdf
https://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_2/ug977-petalinux-getting-started.pdf
