petalinux-config error while setting external search path
Hi All,
I need few apps (and libs) to be inside the petalinux project. ie, <petalinux>/components/apps
and few others outside the petalinux project( to share apps between two different projects). Path is <petalinux>/../../<common-directory>/components/apps
I found that this can be achieved using
petalinux-config --searchpath --append ../../<common-directory>/components/
Although this works fine in terms of final results(building the project and compiling on target), I get error whenever I use petalinux-config command.
find: ‘’: No such file or directory
I cant find petalinux-config source code to debug the issue. But I guess its somehow not using the CONFIG_PROJECT_ADDITIONAL_COMPONENTS_SEARCH_PATH variable which is in config.project file. I can just speculate the cause.
How can I fix this error?
Re: petalinux-config error while setting external search path
Is there a fix for this problem?  I ran into the following after using "petalinux-config --searchpath append" AND "petalinux-config --searchpath prepend":
petalinux-config: line 525: validate_searchpath_action: command not found
