Participant jonbacon
petalinux-config --get-hw-description not showing micoblaze processor 2015.4
I'm not sure what's going on but when I run petalinux-config --get-hw-description=/<location of hdf file> the resulting ncurses config doesn't give me the option to build for the microblaze processor that is in the design.
i've looked though the the hw-description.tcl file in \petalinux-v2015.4-final\components\subsystem\linux\hw-description and there's a rather confusing section of code in the plnx_gen_conf_processor function (function starts on line 133)
The code on line 166 seems to make it impossible to have two different processor architectures in a design.
if {[llength ${aarch64list}] > 0} {
	set armlist {}
	set mblist {}
} elseif {[llength ${armlist}] > 0} {
	set mblist {}
 In fact this makes it look impossible to add a microblaze to a Zynq (and run petalinux on the MB)
Any ideas what this code is for? If I comment it out I get the option of choosing the MB in the config window, but clearly someone put that code in for a reason ...
Jon
p.s. I've attached my hdf file incase I've done somethign stupid in the design. (It's just a test design anyway to get things working)
Scholar sampatd
Re: petalinux-config --get-hw-description not showing micoblaze processor 2015.4
Before importing the hdf file, when you created the petalinux project using the 'petalinux-create' command, what <CPU_TYPE> did you choose for '--template' ?
The command I used to create the project was:
petalinux-create --type project --template microblaze --name mtest
