petalinux-config in 2014.2 does not run correctly.
Re: petalinux-config in 2014.2 does not run correctly.
I couldnt run petalinux-config on redhat enterprise workstation v6.4 too? I think it is supported please see the problem here http://forums.xilinx.com/t5/Embedded-Linux/Petalinux-config-does-not-appear-to-work/m-p/491078/highlight/false#M9830
Thank you
Regarding the "pushd/popd" errors on "petalinux-config".
If you don't want to or are unable to change /bin/sh, you could alternatively change the makefiles such that it works for dash as well. (Tested with Petalinux 2014.2)
Open <petalinux-install-dir>/etc/build/plnx-common-functions.mk and modify the pushd/popd macros:
plnx_qpushd = \
        cd "$(1)" 1>/dev/null           #new version
        pushd "$(1)" 1>/dev/null    #old version
plnx_qpopd = \
        cd $(CURDIR) 1>/dev/null    #new version
        popd 1>/dev/null                       #old version
Replace the leading spaces with one tab!
This hack should work with dash for one level of pushing. I didn't tested it extensively, though.
Best, Sammey
I just got burned by this too as I did an update the other day trying to fix another issue I thought was Xilinx related...
My CentOS system updated to  grep-2.20-3.el6.x86_64 from 2.6.3 and broke the petalinux-config process...
So I went and downloaded grep-2.6.3-6.el6.x86_64.rpm and used "yum downgrade grep-2.6.3-6.el6.x86_64.rpm" to fix it.
Wow -- what a pain.
(seeing how old this thread is and that it just surprised me now... )
Was this a bug in grep or a bug in the usage of grep by the petalinux tools?
