petalinux error
Hi All,
I newbie on PetaLinux
I have succesfull install and running PetaLinux before but after I reinstall my Ubuntu I got problem below
when I running command
$petalinux-boot --qemu --prebuilt 3
I got error message
qemu-system-aarch64: unable to get size of device tree file '/tmp/tmp.lovd81MJJ0
qemu-system-aarch64: Error: unable to load Device Tree /tmp/tmp.lovd81MJJ0
I also have problem when run command $petalinux-boot --jtag --prebuilt 3
it show following error
ERROR: No load address provided for non-ELF file "/home/rofiq/Petalinux/Avnet-Digilent-Zedboard-2015.2/pre-built/linux/image/zynq_fsbl.elf"
I have no idea how to tackle this problem
any help and any solution to fix this?
thanks
Re: petalinux error
Hi thank you for the reply
I'm using petalinux 2015.2.1
My problem has solved by insall QEMU using command below
sudo apt-get install qemu-system-arm:i386
Re: petalinux error
@rofiq
What version of Petalinux are you using?
Are you using the Petalinux BSP for any reference board or using the custom BSP/hardware?
Can you please attach project to verify the details?
Achutha
Re: petalinux error
