petalinux failed when using Master branch of xlnx linux and u-boot on github source
i created a block design on vivado 2018.3 of Video test pattern generator (v8.0), frame buffer and zynq U+.
i am trying to build petalinux using linux-xlnx tags ( xlnx_rebase_v4.14) and its last modification was in november 2018, which means the driver of Video test pattern generator (v8.0) was not modified inside the previous driver for v7.0. it just includes the driver for 5.0 and 7.0 . So it is obvious it would not be probed and that what i am got.
recently, a modifiation of the driver 8.0 was added in the branch master and not in tags. also i tried to build petalinux using the master branch but when i wrote petalinux-build , i got this error :
Ready $ petalinux-build -c kernel
[INFO] building kernel
[INFO] sourcing bitbake
INFO: bitbake virtual/kernel
WARNING: Host distribution "rhel-7.6" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |####################################################################################################################################################################| Time: 0:00:00
Loaded 3459 entries from dependency cache.
Parsing recipes: 100% |##################################################################################################################################################################| Time: 0:00:04
Parsing of 2569 .bb files complete (2533 cached, 36 parsed). 3461 targets, 137 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |###############################################################################################################################################################| Time: 0:00:20
Checking sstate mirror object availability: 100% |#######################################################################################################################################| Time: 0:00:26
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: linux-xlnx-4.14-xilinx-v2018.3+git999-r0 do_populate_lic: QA Issue: linux-xlnx: The LIC_FILES_CHKSUM does not match for file://COPYING;md5=d7810fab7487fb0aad327b76f1be7cd7
linux-xlnx: The new md5 checksum is bbea815ee2795b2f4230826c0c6b8814
linux-xlnx: Here is the selected license text:
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
The Linux Kernel is provided under:
SPDX-License-Identifier: GPL-2.0 WITH Linux-syscall-note
Being under the terms of the GNU General Public License version 2 only,
according with:
LICENSES/preferred/GPL-2.0
With an explicit syscall exception, as stated at:
LICENSES/exceptions/Linux-syscall-note
In addition, other licenses may also apply. Please see:
Documentation/process/license-rules.rst
for more details.
linux-xlnx: Check if the license information has changed in /local2/is221877/user_face/dev/xilinx/mohamad/se120/linux/master/linux-xlnx/COPYING to verify that the LICENSE value "GPLv2" remains valid [license-checksum]
ERROR: linux-xlnx-4.14-xilinx-v2018.3+git999-r0 do_populate_lic: Fatal QA errors found, failing task.
ERROR: linux-xlnx-4.14-xilinx-v2018.3+git999-r0 do_populate_lic: Function failed: populate_lic_qa_checksum
ERROR: Logfile of failure stored in: /local2/is221877/user_face/dev/xilinx/mohamad/se120/linux/master/tpg_frbw_plnx/build/tmp/work/plnx_zynqmp-xilinx-linux/linux-xlnx/4.14-xilinx-v2018.3+git999-r0/temp/log.do_populate_lic.21776
ERROR: Task (/opt/pkg/petalinux/2018.3/components/yocto/source/aarch64/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2018.3.bb:do_populate_lic) failed with exit code '1'
NOTE: Tasks Summary: Attempted 133 tasks of which 113 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 3 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build kernel
it seems that it is a md5 checksum problem.
ANY SUGGESTIONS?
Mohamad
