Visitor micelic
petalinux-install-bsp license problem
Has anyone received the following error after installing Petalinux ... receive a license... moved the license in the .Xilinx directory and tried to install a bsp ?
petalinux-default-bsp
ERROR: No valid PetaLinux features! Typical causes for this error are
either that there is no license file or that license files, which were
found, do not contain a valid license with the required feature.
I also entered this  command with the bsp file after it ... no difference.
If I run XLCM the 3 petalinux licenses show up but hostid match show NO... But the area below the list shows the same hostid that is in my license file.
Any help would be greatly appreciated.
Carlo
Re: petalinux-install-bsp license problem
Check this AR: http://www.xilinx.com/support/answers/56505.htm
Visitor micelic
Thanks but problem solved.
Must have a eth0 interface... Petalinux license is looking for the MAC address for eth0.
Since I have a new dell computer and running Red Hat 6... Dell introduced a new way of naming their ethernet drivers based on pci bus number etc...
There is a dell document that describes how to put it back to the traditional way eth0,, Once I did this the license manager worked.
