petalinux_package
Hello, I want to combine boot.bin and image.ub into one BOOT.BIN file. So, i tried to use "petalinux-package --boot --fsbl   xxxx.fsbl --u-boot --kernel --force".  This command can include image.ub into the package of BOOT.BIN.
Then, I copy BOOT.BIN into SD card.  But, u-boot report an error "can not find kernel image". Do you know why?
One more question: Is it possible to use "petalinux-package --boot" to pack the .elf code for RPU(cortex r5) processor? I'm using Zynq ultrascale+ in which 2 cortex r5 cores are inlcuded.
Refer UG1157 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug1157-petalinux-tools-command-line-guide.pdf "petalinux-package --boot" section
petalinux-package --boot --format BIN --fsbl images/linux/zynqmp_fsbl.elf --u-boot images/linux/u-boot.elf --pmufw images/linux/pmufw.elf --fpga images/linux/download.bit --add images/linux/image.ub --force
If you are using bootgen the below is the bif content
# image.ub offset and load is for QSPI boot
the_ROM_image: { [fsbl_config] a53_x64 [bootloader] zynqmp_fsbl.elf [destination_cpu=pmu] pmufw.elf [destination_cpu=r5-0] r5-0.elf [destination_cpu=r5-1] r5-1.elf [destination_cpu=a53-0, exception_level=el-3, trustzone] bl31.elf [destination_cpu=a53-0, exception_level=el-2] u-boot.elf [offset=0x1E40000, load=0X10000000, destination_cpu=a53-0] image.ub }
Sandeep
@sandeepg,Thank you!
If I use bootgen to generate BOOT.BIN for SD card, what the offset and load address should be for image.ub?
By default in SD boot mode , the uboot tries to load the image.ub from SD card (autoboot)Now,
if this is not the case and you have provided some load address, which can be lets say 16M location ,
then from uboot prompt halt and give a bootm command
bootm 0x100000
load=0X1000000, destination_cpu=a53-0] image.ub
While booting, fsbl copies the image.ub to the load address which is a DDR location, so uboot has no role in copying from flash media
offset address is not required in case of SD boot
Hope that helps
Madhubala
