petalinux raw eth?
last time i try out the petalinux ethernet using socket etc, i can get around 400mbs.  is there anyway to run raw to increase the performance?  similar to raw in xapp1026 or other method to increase the performance of ethernet?
The solution for high speed ethernet is kernel level tcp, or zero-copy or using jumbo frames or a combination of these techniques. Another option is to use UDP instead of TCP which adds significant overhead too.
