petalinux root filesystem type
Hey,
I'm a bit stuck with petalinux running on my zynq 7000.
I'm able to run petalinux on it but when I reboot my processor all my files/changes are reset.
I use in petalinux-config the advanced bootable image storage settings and turned boot image/kernel image and drb image to primary sd. After this the files were still removed after reset. So I tried to use the petalinux-config and turn the root filesystem type to sd but then the petalinux doesnt run anymore (not even u-boot).
Any ideas how to fix this? thx!
Re: petalinux root filesystem type
I forgot to say that i run this petalinux on a single partition sd card with fat32 system
Scholar rfs613
In the default setup provide by Xilinx, the Zynq boots into a RAM disk. Thus any changes you make will be lost after rebooting.
There are many possible solutions. This is very much a FAQ, search the forum and you will find many discussion threads. In no particular order, your options include:
- Mount the SD card and store your data there
- Modify an existing ramdisk (on your PC) to include your files (http://www.wiki.xilinx.com/Build+and+Modify+a+Rootfs)
- Adjust petalinux so it include your programs/data into the ramdisk that it builds
- Don't use a ramdisk at all. Switch to a filesystem like JFFS2 or UBIFS instead. This would be for NOR or NAND flash, not so much for SD card.
