rdunkley
petalinux-util --update-sdcard support
Did Xilinx drop support for --update-sdcard in petalinux-util? I just upgraded from 2015.4 to 2016.4. I was using this command to copy the SD card root file system over to my SD card using a build script. The "--update-sdcard" is no longer recognized. Is there another way to do this easily. I am aware of rsync and all the other manual ways, but I liked running one command at the end of the build.
larshb
Did you figure this one out?
aravindb
Hi @rdunkley @larshb
This feature is obsoleted. You need to update SDCARD manually.
You can refer this link for obsolete features in 2016.4 page no:101
:https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf
Thanks & regards
Aravind
