lvaudoit
petalinux2020: plnx-zynqmp machine is invalid
we have a project building perfectly on petalinux 2019.1 and 2019.2.
now we have installed Vitis/Vivado/Petalinux 2020.1
Oour project does not build anymore.
We have the error plnx-zynqmp MACHINE is invalid
Indeed, we do not have the meta-plnx-generated  and so the machine does not exist (like on 2019)
Is there something we must change in our project? to be compliant with 2020.1?
Thanks in advance
Laurent
jeremy.gerdes
We are seeing the same error now with 2020.1
apacker
I have the same problem but for a zynq7 project, so the machine plnx-zynq7 is now undefined.
jrhtech
Voyager
Voyager
  I'm seeing the same thing.   I just tried changing the machine name to zynqmp-generic which is what is in build/conf/local.conf and it is building now so waiting to see if it will finish.  I don't have my dev board yet to see if image will boot.
  The other odd thing I see is the DTG name is "template" but the project built in 2019.2 so it must work but I'm not sure how.  This is for a Trenz SOM and they don't provide a BSP for the boards like other vendors so I'm trying to understand their whole process..
thanks,
jeff
evross
Any solution to this please?
I have just started to look at PetaLinux and have had success with 2019.2 version, but have this same issue with 2020.1.
Seems odd that I use the same process as with 2019.2, and simply do...
$ petalinux-create -t project -s ../zynq/mz7010_fmccc_2019_1/mz7010_fmccc_2019_1.bsp
$ cd mz7010_fmccc_2019_1/
$ touch project-spec/meta-user/conf/user-rootfsconfig
$ vi project-spec/meta-user/conf/layer.conf # changed "thud" to "zeus"
$ cp /windows-share/design_1_wrapper.xsa . # Use XSA from Vivado 2020.1
$ petalinux-config -c rootfs
$ petalinux-config --get-hw-description=.
$ petalinux-build
INFO: sourcing build tools
[INFO] building project
[INFO] sourcing build environment
[INFO] generating user layers
[INFO] generating workspace directory
INFO: bitbake petalinux-image-minimal
ERROR: OE-core's config sanity checker detected a potential misconfiguration.
Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
Following is the list of potential problems / advisories:
MACHINE=plnx-zynq7 is invalid. Please set a valid MACHINE in your local.conf, environment or other configuration file.
Hoping for some help please?
Dave
sandeepg
Hi All,
Yes plnx-zynqmp no more available you need to use https://github.com/Xilinx/meta-xilinx/blob/rel-v2020.1/meta-xilinx-bsp/conf/machine/zynqmp-generic.conf
CONFIG_YOCTO_MACHINE_NAME="zynqmp-generic"
For Zynq-7000 devices is https://github.com/Xilinx/meta-xilinx/blob/rel-v2020.1/meta-xilinx-bsp/conf/machine/zynq-generic.conf
CONFIG_YOCTO_MACHINE_NAME="zynq-generic"
Sandeep
evross
Thank you Sandeep,
The build now happens, however another error occurs:
| make -f /home/stanley/projects/mz7010_fmccc_2019_1/build/tmp/work/zynq_generic-xilinx-linux-gnueabi/u-boot-xlnx/v2020.01-xilinx-v2020.1+gitAUTOINC+86c84c0d0f-r0/git/scripts/Makefile.build obj=scripts/kconfig zynq_zc702_config
| scripts/kconfig/conf --defconfig=arch/../configs/zynq_zc702_defconfig Kconfig
| *** Can't find default configuration "arch/../configs/zynq_zc702_defconfig"!
I think this is the uBoot config, in 2019.2 build the config is the same, but this setting is not ignored anymore?
I think I need this for my microZed board:
https://github.com/buildroot/buildroot/blob/master/configs/zynq_microzed_defconfig
I cannot see a corresponding defconfig in the 2020.1 source.  Maybe I don't need a defconfig?
Thank you for you help, should I open a new ticket?
evross
If I do :
petalinux-config --get-hw-description=. --defconfig=~/git/buildroot/configs/zynq_microzed_defconfig
I still get :
Any ideas please?
Thank you
patocarr
Hi @evross
  Try using "xilinx_zynq_virt_defconfig" on U-Boot defconfig, and "zc702" on the machine name. See ug1144 page 118 & 134 for more details.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
evross
Thank you for replying @patocarr ,
I have been working with UG1144 for 2020.1.  On page 118 it states "For custom boards it is template. For Xilinx ® evaluation boards...", I am using an AVnet microzed, which is not included.
Also, even for zc702 there is no defconfig for this in the source (not even in the 2019.2 source I have) that I can see, but 2019.2 allows me to build and run on the microzed.
I am using 2020.1 because it supports XSA (only) and I have Vitis not SDK.
So I'm stuck at the moment,
Dave
patocarr
Hi @evross
  Given this is an Avnet board, you may want to start the Petalinux project with the board's BSP. You can usually find it in Avnet's site.
-Pat
evross
Hi @patocarr
Referring to my first message in this thread, I am using the AVNet BSP:
Thank you,
Dave
patocarr
Hi @evross
  The version of the BSP is important. The 2019.x version is not compatible with 2020.x. You will need to re-create the project with the new version.
-Pat
apacker
On http://zedboard.org/support/design/1519/10 there is no 2020.1 BSP yet unfortunately.  There is a thread about this in the MicroZed forum: https://www.element14.com/community/message/294215/l/petalinux-20201-bsp-for-microzed#294215
It looks like there have been significant delays getting the BSP posted, not clear why.
apacker
If you're feeling brave, it looks like there is 2020.1 work going on in https://github.com/Avnet/petalinux/tree/2020.1
I can't tell how close it is to release but maybe there are clues in there how we could tweak our settings to get things to build on 2020.1.  Unfortunately I don't have the time to dig into this any more right now.
evross
@apacker
Thanks for the info.  I pulled the tag "2020p1_mz_petalinux_MZ7010_FMCCC_20201104_065342" and managed to get it to build and boot the microzed board from the image produced, or at least I am assuming that doing "petalinux-boot --jtag --prebuilt 3" boots an image built by running "./make_mz7010_fmccc.sh".  In order to get the build to work I had to 1) remove the "check_git_tag" in the build script, and 2) add "ulimit -s 16384" to the vivado launch script.
Cheers.
