petaliunx build problem
The problems:
root@zynq-virtual-machine:/opt/pkg/petalinux/petalinux-v2016.2-final/zynq_test# petalinux-build
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] build linux/kernel
[INFO ] generate linux/u-boot configuration files
[INFO ] update linux/u-boot source
[INFO ] build linux/u-boot
[INFO ] build zynq_fsbl
[ERROR] make[3]: *** [xddrps_libs] Error 127
[ERROR] make[2]: *** [ps7_cortexa9_0/libsrc/ddrps_v1_0/src/make.libs] Error 2
[ERROR] make[1]: *** [build] Error 255
ERROR: Failed to build linux
The build log:
[ALL ] Compiling ddrps
[ALL ] make[3]: arm-none-eabi-ar: Command not found
[ALL ] Makefile:31: recipe for target 'xddrps_libs' failed
[ALL ] make[3]: Leaving directory '/opt/pkg/petalinux/petalinux-v2016.2-final/zynq_test/build/linux/bootloader/zynq_fsbl/zynq_fsbl_bsp/ps7_cortexa9_0/libsrc/ddrps_v1_0/src'
[ALL ] Makefile:27: recipe for target 'ps7_cortexa9_0/libsrc/ddrps_v1_0/src/make.libs' failed
[ALL ] make[2]: Leaving directory '/opt/pkg/petalinux/petalinux-v2016.2-final/zynq_test/build/linux/bootloader/zynq_fsbl/zynq_fsbl_bsp'
[ALL ] Makefile:106: recipe for target 'build' failed
petalinux info:
version: 2016.2
Settings.sh:
root@zynq-virtual-machine:/opt/pkg/petalinux/petalinux-v2016.2-final# source settings.sh
PetaLinux environment set to '/opt/pkg/petalinux/petalinux-v2016.2-final'
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
WARNING: No tftp server found - please refer to "PetaLinux SDK Installation Guide" for its impact and solution
No important missing component.
linux host info:
Ubuntu 16.04
The log indicated that "arm-none-eabi-ar: Command not found" in the period of fsbl compiling.
How to solve this problem?
Re: petaliunx build problem
Hi Jlynnc
you should install 32-bit libraries.
$sudo apt-get install lib32z1, lib32ncurses5, lib-32bz2-1.0, lib32stdc++6
and again
$petalinux-build
you can try below link to copy 32-bit library of  libselinux.so.1
https://forums.xilinx.com/t5/Embedded-Linux/2014-2-Image-Build-Processes-Error/td-p/476862/page/3
