08-29-2018 07:45 PM
I used petalinux 2018.2 build my project ,but the SD card can't be mounted when boot from the SD card. It works well in petalinux 2017.4. The log is attached below .Anyone can help?Thanks!
Xilinx Zynq MP First Stage Boot Loader
Release 2018.2 Aug 24 2018 - 10:59:43
NOTICE: ATF running on XCZU4CG/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v1.4(release):xilinx-v2018.1-4-g93a69a5a
NOTICE: BL31: Built : 09:30:17, Aug 25 2018
PMUFW: v1.0
U-Boot 2018.01 (Aug 25 2018 - 17:31:58 +0800) Xilinx ZynqMP ZCU102 rev1.0
I2C: ready
DRAM: 701 MiB
EL Level: EL2
Chip ID: zu4cg
MMC: sdhci@ff170000: 0 (SD)
SF: unrecognized JEDEC id bytes: 90, 8a, aa
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Board: Xilinx ZynqMP
Bootmode: SD_MODE1
U-BOOT for zcu4cg-pcie-1
Device: sdhci@ff170000
Manufacturer ID: 2
OEM: 544d
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
13905284 bytes read in 941 ms (14.1 MiB/s)
Using 'conf@system-top.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x10000104
Data Size: 6626808 Bytes = 6.3 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: be780ec6d97c5333c319f87118ad0a93435864b4
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-user-image
Type: RAMDisk Image
Data Start: 0x1065aa64
Data Size: 7241103 Bytes = 6.9 MiB
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: cf1228330f6cb2fa5ce456442366559fdb30deba
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x10652000
Data Size: 35230 Bytes = 34.4 KiB
Hash algo: sha1
Hash value: ffef372054826253597a94aaea71c2a02d74f62b
Booting using the fdt blob at 0x10652000
Uncompressing Kernel Image ... OK
Loading Ramdisk to 07918000, end 07fffd8f ... OK
Loading Device Tree to 000000000790c000, end 000000000791799d ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.0-xilinx-v2018.2 (oe-user@oe-host) (gcc version 7.2.0 (GCC)) #1 SMP Thu Aug 23 19:13:59 CST 2018
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: xlnx,zynqmp
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 256 MiB at 0x000000001bc00000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 21 pages/cpu @ffffffc02bca0000 s46488 r8192 d31336 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 177002
[ 0.000000] Kernel command line: earlycon clk_ignore_unused
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.000000] Memory: 416484K/717824K available (9468K kernel code, 632K rwdata, 2996K rodata, 512K init, 2164K bss, 39196K reserved, 262144K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff80089c0000 ( 9472 KB)
[ 0.000000] .rodata : 0xffffff80089c0000 - 0xffffff8008cb0000 ( 3008 KB)
[ 0.000000] .init : 0xffffff8008cb0000 - 0xffffff8008d30000 ( 512 KB)
[ 0.000000] .data : 0xffffff8008d30000 - 0xffffff8008dce200 ( 633 KB)
[ 0.000000] .bss : 0xffffff8008dce200 - 0xffffff8008feb4d8 ( 2165 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf00995800 ( 9 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc02bd00000 ( 701 MB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 33.33MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x7b0074340, max_idle_ns: 440795202884 ns
[ 0.000003] sched_clock: 56 bits at 33MHz, resolution 30ns, wraps every 2199023255543ns
[ 0.008259] Console: colour dummy device 80x25
[ 0.012515] console [tty0] enabled
[ 0.015881] bootconsole [cdns0] disabled
[ 0.019792] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332)
[ 0.019806] pid_max: default: 32768 minimum: 301
[ 0.019905] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.019918] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.020575] ASID allocator initialised with 65536 entries
[ 0.020630] Hierarchical SRCU implementation.
[ 0.020921] EFI services will not be available.
[ 0.020946] zynqmp_plat_init Platform Management API v1.0
[ 0.020955] zynqmp_plat_init Trustzone version v1.0
[ 0.021025] smp: Bringing up secondary CPUs ...
[ 0.021290] Detected VIPT I-cache on CPU1
[ 0.021323] CPU1: Booted secondary processor [410fd034]
[ 0.021378] smp: Brought up 1 node, 2 CPUs
[ 0.021394] SMP: Total of 2 processors activated.
[ 0.021403] CPU features: detected feature: 32-bit EL0 Support
[ 0.021414] CPU: All CPU(s) started at EL2
[ 0.021429] alternatives: patching kernel code
[ 0.021870] devtmpfs: initialized
[ 0.025308] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[ 0.025462] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.025483] futex hash table entries: 512 (order: 4, 65536 bytes)
[ 0.030639] xor: measuring software checksum speed
[ 0.067888] 8regs : 2303.000 MB/sec
[ 0.107917] 8regs_prefetch: 2053.000 MB/sec
[ 0.147949] 32regs : 2830.000 MB/sec
[ 0.187976] 32regs_prefetch: 2379.000 MB/sec
[ 0.187985] xor: using function: 32regs (2830.000 MB/sec)
[ 0.188064] pinctrl core: initialized pinctrl subsystem
[ 0.188384] random: fast init done
[ 0.188692] NET: Registered protocol family 16
[ 0.189381] cpuidle: using governor menu
[ 0.189742] vdso: 2 pages (1 code @ ffffff80089c6000, 1 data @ ffffff8008d34000)
[ 0.189760] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.190281] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.220307] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[ 0.220805] ARM CCI_400_r1 PMU driver probed
[ 0.237038] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.304276] raid6: int64x1 gen() 396 MB/s
[ 0.372303] raid6: int64x1 xor() 446 MB/s
[ 0.440416] raid6: int64x2 gen() 684 MB/s
[ 0.508445] raid6: int64x2 xor() 604 MB/s
[ 0.576487] raid6: int64x4 gen() 1039 MB/s
[ 0.644545] raid6: int64x4 xor() 742 MB/s
[ 0.712618] raid6: int64x8 gen() 979 MB/s
[ 0.780686] raid6: int64x8 xor() 738 MB/s
[ 0.848753] raid6: neonx1 gen() 723 MB/s
[ 0.916809] raid6: neonx1 xor() 853 MB/s
[ 0.984873] raid6: neonx2 gen() 1162 MB/s
[ 1.052911] raid6: neonx2 xor() 1206 MB/s
[ 1.121008] raid6: neonx4 gen() 1503 MB/s
[ 1.189050] raid6: neonx4 xor() 1440 MB/s
[ 1.257139] raid6: neonx8 gen() 1647 MB/s
[ 1.325167] raid6: neonx8 xor() 1527 MB/s
[ 1.325175] raid6: using algorithm neonx8 gen() 1647 MB/s
[ 1.325182] raid6: .... xor() 1527 MB/s, rmw enabled
[ 1.325191] raid6: using neon recovery algorithm
[ 1.326149] SCSI subsystem initialized
[ 1.326340] usbcore: registered new interface driver usbfs
[ 1.326378] usbcore: registered new interface driver hub
[ 1.326419] usbcore: registered new device driver usb
[ 1.326484] media: Linux media interface: v0.10
[ 1.326511] Linux video capture interface: v2.00
[ 1.326558] pps_core: LinuxPPS API ver. 1 registered
[ 1.326567] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.326587] PTP clock support registered
[ 1.326613] EDAC MC: Ver: 3.0.0
[ 1.327730] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[ 1.327891] FPGA manager framework
[ 1.328000] fpga-region fpga-full: FPGA Region probed
[ 1.328093] Advanced Linux Sound Architecture Driver Initialized.
[ 1.328357] Bluetooth: Core ver 2.22
[ 1.328382] NET: Registered protocol family 31
[ 1.328390] Bluetooth: HCI device and connection manager initialized
[ 1.328402] Bluetooth: HCI socket layer initialized
[ 1.328412] Bluetooth: L2CAP socket layer initialized
[ 1.328437] Bluetooth: SCO socket layer initialized
[ 1.328903] clocksource: Switched to clocksource arch_sys_counter
[ 1.328980] VFS: Disk quotas dquot_6.6.0
[ 1.329027] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.335393] NET: Registered protocol family 2
[ 1.335719] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.335783] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 1.335910] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.335989] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.336016] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.336111] NET: Registered protocol family 1
[ 1.336388] RPC: Registered named UNIX socket transport module.
[ 1.336397] RPC: Registered udp transport module.
[ 1.336405] RPC: Registered tcp transport module.
[ 1.336412] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.336520] Trying to unpack rootfs image as initramfs...
[ 1.624077] Freeing initrd memory: 7068K
[ 1.624391] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.624512] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.625205] audit: initializing netlink subsys (disabled)
[ 1.625756] audit: type=2000 audit(1.611:1): state=initialized audit_enabled=0 res=1
[ 1.625827] workingset: timestamp_bits=62 max_order=18 bucket_order=0
[ 1.626502] NFS: Registering the id_resolver key type
[ 1.626525] Key type id_resolver registered
[ 1.626533] Key type id_legacy registered
[ 1.626546] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.626569] jffs2: version 2.2. (NAND) (SUMMARY) ? 2001-2006 Red Hat, Inc.
[ 1.654187] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.654212] io scheduler noop registered
[ 1.654220] io scheduler deadline registered
[ 1.654241] io scheduler cfq registered (default)
[ 1.654250] io scheduler mq-deadline registered
[ 1.654258] io scheduler kyber registered
[ 1.654893] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.655337] nwl-pcie fd0e0000.pcie: Link is DOWN
[ 1.655381] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges:
[ 1.655405] OF: PCI: MEM 0xe0000000..0xefffffff -> 0xe0000000
[ 1.655417] OF: PCI: MEM 0x600000000..0x7ffffffff -> 0x600000000
[ 1.655541] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[ 1.655557] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.655567] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[ 1.655579] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[ 1.655853] pci 0000:00:00.0: ignoring class 0x058000 (doesn't match header type 01)
[ 1.657050] pci 0000:00:00.0: not setting up bridge for bus 0000:01
[ 1.657308] switchtec: loaded.
[ 1.658518] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 1.658670] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 1.658812] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 1.658956] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 1.659100] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 1.659253] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 1.659398] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 1.659543] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 1.659754] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 1.659895] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 1.660039] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 1.660180] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 1.660322] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 1.660464] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 1.660607] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 1.660752] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 1.687720] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.690780] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.696100] brd: module loaded
[ 1.700367] loop: module loaded
[ 1.701148] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.702923] m25p80 spi0.0: found w25m512jv, expected n25q512a
[ 1.712341] m25p80 spi0.0: w25m512jv (131072 Kbytes)
[ 1.712366] 3 ofpart partitions found on MTD device spi0.0
[ 1.712375] Creating 3 MTD partitions on "spi0.0":
[ 1.712388] 0x000000000000-0x000000100000 : "boot"
[ 1.712909] 0x000000100000-0x000000140000 : "bootenv"
[ 1.713384] 0x000000140000-0x000001740000 : "kernel"
[ 1.714718] libphy: Fixed MDIO Bus: probed
[ 1.715724] tun: Universal TUN/TAP device driver, 1.6
[ 1.718822] CAN device driver interface
[ 1.719579] usbcore: registered new interface driver asix
[ 1.719633] usbcore: registered new interface driver ax88179_178a
[ 1.719662] usbcore: registered new interface driver cdc_ether
[ 1.719691] usbcore: registered new interface driver net1080
[ 1.719720] usbcore: registered new interface driver cdc_subset
[ 1.719749] usbcore: registered new interface driver zaurus
[ 1.719791] usbcore: registered new interface driver cdc_ncm
[ 1.720530] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 1.720930] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.720941] ehci-pci: EHCI PCI platform driver
[ 1.721204] usbcore: registered new interface driver uas
[ 1.721244] usbcore: registered new interface driver usb-storage
[ 1.722175] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 1.722228] i2c /dev entries driver
[ 1.722818] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 30
[ 1.723251] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 31
[ 1.723515] IR NEC protocol handler initialized
[ 1.723523] IR RC5(x/sz) protocol handler initialized
[ 1.723531] IR RC6 protocol handler initialized
[ 1.723538] IR JVC protocol handler initialized
[ 1.723545] IR Sony protocol handler initialized
[ 1.723553] IR SANYO protocol handler initialized
[ 1.723561] IR Sharp protocol handler initialized
[ 1.723568] IR MCE Keyboard/mouse protocol handler initialized
[ 1.723576] IR XMP protocol handler initialized
[ 1.724547] usbcore: registered new interface driver uvcvideo
[ 1.724556] USB Video Class driver (1.1.1)
[ 1.725866] Bluetooth: HCI UART driver ver 2.3
[ 1.725880] Bluetooth: HCI UART protocol H4 registered
[ 1.725889] Bluetooth: HCI UART protocol BCSP registered
[ 1.725923] Bluetooth: HCI UART protocol LL registered
[ 1.725932] Bluetooth: HCI UART protocol ATH3K registered
[ 1.725940] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.726008] Bluetooth: HCI UART protocol Intel registered
[ 1.726017] Bluetooth: HCI UART protocol QCA registered
[ 1.726059] usbcore: registered new interface driver bcm203x
[ 1.726092] usbcore: registered new interface driver bpa10x
[ 1.726126] usbcore: registered new interface driver bfusb
[ 1.726161] usbcore: registered new interface driver btusb
[ 1.726170] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 1.726218] usbcore: registered new interface driver ath3k
[ 1.726365] EDAC MC: ECC not enabled
[ 1.726527] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 1.727299] sdhci: Secure Digital Host Controller Interface driver
[ 1.727308] sdhci: Copyright(c) Pierre Ossman
[ 1.727316] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.772899] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[ 1.772965] PLL: shutdown
[ 1.773052] PLL: enable
[ 1.779137] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.779283] usbcore: registered new interface driver usbhid
[ 1.779292] usbhid: USB HID core driver
[ 1.781291] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 1.783198] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 1.785347] Netfilter messages via NETLINK v0.30.
[ 1.785472] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.785604] Initializing XFRM netlink socket
[ 1.785676] NET: Registered protocol family 10
[ 1.786055] Segment Routing with IPv6
[ 1.786103] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.786212] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.786548] NET: Registered protocol family 17
[ 1.786564] NET: Registered protocol family 15
[ 1.786587] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.786601] Ebtables v2.0 registered
[ 1.786691] can: controller area network core (rev 20170425 abi 9)
[ 1.786727] NET: Registered protocol family 29
[ 1.786737] can: raw protocol (rev 20170425)
[ 1.786745] can: broadcast manager protocol (rev 20170425 t)
[ 1.786757] can: netlink gateway (rev 20170425) max_hops=1
[ 1.786932] Bluetooth: RFCOMM TTY layer initialized
[ 1.786945] Bluetooth: RFCOMM socket layer initialized
[ 1.786961] Bluetooth: RFCOMM ver 1.11
[ 1.786972] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.786980] Bluetooth: BNEP filters: protocol multicast
[ 1.786993] Bluetooth: BNEP socket layer initialized
[ 1.787001] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.787013] Bluetooth: HIDP socket layer initialized
[ 1.787127] 9pnet: Installing 9P2000 support
[ 1.787151] Key type dns_resolver registered
[ 1.787501] registered taskstats version 1
[ 1.787859] Btrfs loaded, crc32c=crc32c-generic
[ 1.793646] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 43, base_baud = 6249999) is a xuartps
[ 1.889643] mmc0: ADMA error
[ 1.889646] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 1.889649] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
[ 1.889651] mmc0: sdhci: Blk size: 0x00007008 | Blk cnt: 0x00000001
[ 1.889654] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 1.889656] mmc0: sdhci: Present: 0x01f70206 | Host ctl: 0x00000019
[ 1.889659] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 1.889661] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x0000fa07
[ 1.889663] mmc0: sdhci: Timeout: 0x00000004 | Int stat: 0x00000000
[ 1.889666] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 1.889668] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 1.889671] mmc0: sdhci: Caps: 0x31e8c881 | Caps_1: 0x00002007
[ 1.889673] mmc0: sdhci: Cmd: 0x0000333a | Max curr: 0x00000000
[ 1.889676] mmc0: sdhci: Resp[0]: 0x00000920 | Resp[1]: 0x001d177f
[ 1.889678] mmc0: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00400e00
[ 1.889680] mmc0: sdhci: Host ctl2: 0x00000000
[ 1.889683] mmc0: sdhci: ADMA Err: 0x00000001 | ADMA Ptr: 0x000000001bc40200
[ 1.889684] mmc0: sdhci: ============================================
[ 1.894913] mmc0: error -5 whilst initialising SD card
[ 2.124141] mmc0: ADMA error
[ 2.124142] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.124145] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
[ 2.124147] mmc0: sdhci: Blk size: 0x00007008 | Blk cnt: 0x00000001
[ 2.124149] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 2.124151] mmc0: sdhci: Present: 0x01f70206 | Host ctl: 0x00000019
[ 2.124154] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 2.124156] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00004e47
[ 2.124158] mmc0: sdhci: Timeout: 0x00000004 | Int stat: 0x00000000
[ 2.124160] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 2.124162] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 2.124165] mmc0: sdhci: Caps: 0x31e8c881 | Caps_1: 0x00002007
[ 2.124167] mmc0: sdhci: Cmd: 0x0000333a | Max curr: 0x00000000
[ 2.124169] mmc0: sdhci: Resp[0]: 0x00000920 | Resp[1]: 0x001d177f
[ 2.124171] mmc0: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00400e00
[ 2.124173] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.124175] mmc0: sdhci: ADMA Err: 0x00000001 | ADMA Ptr: 0x000000001bc40200
[ 2.124177] mmc0: sdhci: ============================================
[ 2.130885] mmc0: error -5 whilst initialising SD card
[ 2.326962] mmc0: ADMA error
[ 2.326963] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.326966] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
[ 2.326968] mmc0: sdhci: Blk size: 0x00007008 | Blk cnt: 0x00000001
[ 2.326970] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 2.326973] mmc0: sdhci: Present: 0x01f70206 | Host ctl: 0x00000019
[ 2.326975] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 2.326977] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x0000f447
[ 2.326979] mmc0: sdhci: Timeout: 0x00000004 | Int stat: 0x00000000
[ 2.326981] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 2.326984] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 2.326986] mmc0: sdhci: Caps: 0x31e8c881 | Caps_1: 0x00002007
[ 2.326988] mmc0: sdhci: Cmd: 0x0000333a | Max curr: 0x00000000
[ 2.326990] mmc0: sdhci: Resp[0]: 0x00000920 | Resp[1]: 0x001d177f
[ 2.326992] mmc0: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00400e00
[ 2.326994] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.326997] mmc0: sdhci: ADMA Err: 0x00000001 | ADMA Ptr: 0x000000001bc40200
[ 2.326998] mmc0: sdhci: ============================================
[ 2.330657] mmc0: error -5 whilst initialising SD card
[ 2.517318] mmc0: ADMA error
[ 2.517320] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.517322] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00001002
[ 2.517325] mmc0: sdhci: Blk size: 0x00007008 | Blk cnt: 0x00000001
[ 2.517327] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000013
[ 2.517329] mmc0: sdhci: Present: 0x01f70206 | Host ctl: 0x00000019
[ 2.517331] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 2.517333] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x0000e8c7
[ 2.517336] mmc0: sdhci: Timeout: 0x00000004 | Int stat: 0x00000000
[ 2.517338] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 2.517340] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 2.517342] mmc0: sdhci: Caps: 0x31e8c881 | Caps_1: 0x00002007
[ 2.517344] mmc0: sdhci: Cmd: 0x0000333a | Max curr: 0x00000000
[ 2.517346] mmc0: sdhci: Resp[0]: 0x00000920 | Resp[1]: 0x001d177f
[ 2.517349] mmc0: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00400e00
[ 2.517350] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.517353] mmc0: sdhci: ADMA Err: 0x00000001 | ADMA Ptr: 0x000000001bc40200
[ 2.517354] mmc0: sdhci: ============================================
[ 2.520552] mmc0: error -5 whilst initialising SD card
[ 3.843491] console [ttyPS0] enabled
[ 3.848443] dwc3-of-simple ff9e0000.usb1: dwc3_simple_set_phydata: Can't find usb3-phy
[ 3.857018] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.862439] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.870273] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
[ 3.878926] xhci-hcd xhci-hcd.0.auto: irq 48, io mem 0xfe300000
[ 3.885020] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.891733] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.898935] usb usb1: Product: xHCI Host Controller
[ 3.903793] usb usb1: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[ 3.910478] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 3.915615] hub 1-0:1.0: USB hub found
[ 3.919308] hub 1-0:1.0: 1 port detected
[ 3.923369] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.928784] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 3.936463] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.944566] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.951278] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.958483] usb usb2: Product: xHCI Host Controller
[ 3.963341] usb usb2: Manufacturer: Linux 4.14.0-xilinx-v2018.2 xhci-hcd
[ 3.970023] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 3.975116] hub 2-0:1.0: USB hub found
[ 3.978801] hub 2-0:1.0: 1 port detected
[ 3.983671] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01 00:00:07 UTC (7)
[ 3.991799] clk: Not disabling unused clocks
[ 3.996017] ALSA device list:
[ 3.998933] No soundcards found.
[ 4.002800] Freeing unused kernel memory: 512K
INIT: version 2.88 booting
Starting udev
[ 4.109895] udevd[1638]: starting version 3.2.2
[ 4.119549] udevd[1639]: starting eudev-3.2.2
Sat Aug 25 09:35:42 UTC 2018
Starting internet superserver: inetd.
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... Cannot find device "eth0"
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCwKJYOgyN5IacdNzlMglZBLOzt0C5xwDxmp+AER3qvUoClPxJNoqZCstMkx+LLdXhLmFsBSCvP3ddLUEL5aOibIjp9xe8jhjhPmh98hraXcpgn6b1PKdaYpnkj+68i0opWDrGHT/sHkVBlOXhrf7afs5Ry/Lwp3AxYV1I2k7FJ53uAdeUo+N1NxJ1KWplwxhcO2bRfQv5iSezl8i/uMcv+CJUI+2dk/m8DRztaJ30iHCJdWzZHjD78E295+TWmuH0AU/UML7+rB4qIe91h7K/4hprEA5jtIutAeWAl4bxmwPvqcjkkwVWmrOLx5lamcu5vxDi06EG3a6X5GB0gp6sz root@zcu4cg-pcie-1
Fingerprint: md5 1b:6f:5e:75:69:fd:da:ac:aa:75:f4:31:19:09:2f:08
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2018.2 zcu4cg-pcie-1 /dev/ttyPS0
zcu4cg-pcie-1 login: root
Password:
root@zcu4cg-pcie-1:~# mount /dev/mmcblk0p1 /mnt
mount: mounting /dev/mmcblk0p1 on /mnt failed: No such file or directory
09-06-2018 07:27 AM - edited 09-06-2018 07:28 AM
Hi @wenhaohuang,
Is it customer board or evaluation board?
What is the frequency you are operating at?
Can you append "no-1-8-v" in your mmc device tree is you are not using any level shifters?
Kranthi
09-06-2018 07:28 PM
Hi @gudishak,
It is customer board .
You mean the frequency of the SD card ? I just set it to the default.
Yeah! There is no level shifter in my design. I don't know how to add "no-1-8-v" in my device tree. Can you show me an exampel? Thank you !
09-10-2018 01:35 AM
Hi @gudishak,
I add the "no-1-8-v" in my device tree,but it doesn't work, same as before.
09-10-2018 02:58 AM
09-10-2018 03:10 AM
09-10-2018 07:28 PM
Thanks for your reply. I changed the device tree as you said,but it didn't work ,I tried changing card, and it didn't work.
it works well in petalinux 2017.4.The logs are below . And you can see some errors in 2018.2 like "[ 1.889643] mmc0: ADMA error"、 "[ 1.894913] mmc0: error -5 whilst initialising SD card".Will it be the SD card driver problem ?
Release 2017.3 Aug 18 2018 - 04:45:23
NOTICE: ATF running on XCZU4EV/silicon v4/RTL5.1 at 0xfffea000, with PMU firmware
NOTICE: BL31: v1.3(release):f9b244b
NOTICE: BL31: Built : 11:32:03, Aug 18 2018
U-Boot 2017.01 (Aug 18 2018 - 04:45:32 -0700) Xilinx ZynqMP ZCU102 revB
I2C: ready
DRAM: 701 MiB
EL Level: EL2
Chip ID: xczu4ev
zynqmp_qspi_ofdata_to_platdata: CLK 299999997
SF: unrecognized JEDEC id bytes: ef, 71, 19
*** Warning - spi_flash_probe() failed, using default environment
In: serial
Out: serial
Err: serial
Bootmode: SD_MODE1
U-BOOT for zu4cg_hdmi_t
Manufacturer ID: 2
OEM: 544d
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 3.6 GiB
Bus Width: 4-bit
reading image.ub
18673692 bytes read in 1257 ms (14.2 MiB/s)
Using 'conf@1' configuration
Trying 'kernel@0' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Data Start: 0x100000d8
Data Size: 12648960 Bytes = 12.1 MiB
OS: Linux
Hash algo: sha1
Hash value: bab418b75e4743fbf1475b62a9550cb643e4bb69
Trying 'ramdisk@0' ramdisk subimage
Description: ramdisk
Type: RAMDisk Image
Data Start: 0x10c18b08
Data Size: 5988637 Bytes = 5.7 MiB
OS: Linux
Hash algo: sha1
Hash value: d3c055e902ef627df0722c65fb93cd552a5a3b3f
Trying 'fdt@0' fdt subimage
Data Start: 0x10c103d0
Data Size: 34434 Bytes = 33.6 KiB
Hash algo: sha1
Hash value: 0f58c2a6546f9832e3c73377ff99e3ef466eaa1e
Booting using the fdt blob at 0x10c103d0
Loading Kernel Image ... OK
Loading Ramdisk to 07a49000, end 07fff11d ... OK
Loading Device Tree to 0000000007a3d000, end 0000000007a48681 ... OK
Starting kernel ...
[ 0.000000] Linux version 4.9.0-xilinx-v2017.3 (kleingrau@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP Sat Aug 18 04:37:40 PDT 2018
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] percpu: Embedded 21 pages/cpu @ffffffc02bca1000 s48152 r8192 d29672 u86016
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 177002
[ 0.000000] Memory: 420764K/717824K available (8508K kernel code, 576K rwdata, 2680K rodata, 512K init, 382K bss, 34916K reserved, 262144K cma-reserved)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff80088d0000 ( 8512 KB)
[ 0.000000] .rodata : 0xffffff80088d0000 - 0xffffff8008b80000 ( 2752 KB)
[ 0.000000] .init : 0xffffff8008b80000 - 0xffffff8008c00000 ( 512 KB)
[ 0.000000] .data : 0xffffff8008c00000 - 0xffffff8008c90200 ( 577 KB)
[ 0.000000] .bss : 0xffffff8008c90200 - 0xffffff8008cefb7c ( 383 KB)
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=2
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 33.33MHz (phys).
[ 0.008220] Console: colour dummy device 80x25
[ 0.012480] console [tty0] enabled
[ 0.015846] bootconsole [cdns0] disabled
[ 0.019754] Calibrating delay loop (skipped), value calculated using timer frequency.. 66.66 BogoMIPS (lpj=133332)
[ 0.019768] pid_max: default: 32768 minimum: 301
[ 0.019866] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.019876] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.020427] ASID allocator initialised with 65536 entries
[ 0.020901] zynqmp_plat_init Power management API v0.3
[ 0.020981] EFI services will not be available.
[ 0.021286] Detected VIPT I-cache on CPU1
[ 0.021317] CPU1: Booted secondary processor [410fd034]
[ 0.021361] Brought up 2 CPUs
[ 0.021376] SMP: Total of 2 processors activated.
[ 0.021384] CPU features: detected feature: 32-bit EL0 Support
[ 0.021395] CPU: All CPU(s) started at EL2
[ 0.021409] alternatives: patching kernel code
[ 0.021826] devtmpfs: initialized
[ 0.025897] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.031074] xor: measuring software checksum speed
[ 0.067860] 8regs : 2303.000 MB/sec
[ 0.107887] 8regs_prefetch: 2053.000 MB/sec
[ 0.147919] 32regs : 2830.000 MB/sec
[ 0.187943] 32regs_prefetch: 2379.000 MB/sec
[ 0.187957] xor: using function: 32regs (2830.000 MB/sec)
[ 0.188043] pinctrl core: initialized pinctrl subsystem
[ 0.188653] NET: Registered protocol family 16
[ 0.203989] cpuidle: using governor menu
[ 0.204224] Failed to initialise IOMMU /amba/smmu@fd800000
[ 0.204366] vdso: 2 pages (1 code @ ffffff80088d7000, 1 data @ ffffff8008c04000)
[ 0.204391] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.204915] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.215155] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[ 0.215665] ARM CCI_400_r1 PMU driver probed
[ 0.233817] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.300178] raid6: int64x1 gen() 404 MB/s
[ 0.368212] raid6: int64x1 xor() 443 MB/s
[ 0.436273] raid6: int64x2 gen() 669 MB/s
[ 0.504284] raid6: int64x2 xor() 600 MB/s
[ 0.572339] raid6: int64x4 gen() 982 MB/s
[ 0.640396] raid6: int64x4 xor() 740 MB/s
[ 0.708451] raid6: int64x8 gen() 1146 MB/s
[ 0.776500] raid6: int64x8 xor() 747 MB/s
[ 0.844552] raid6: neonx1 gen() 722 MB/s
[ 0.912570] raid6: neonx1 xor() 759 MB/s
[ 0.980632] raid6: neonx2 gen() 1164 MB/s
[ 1.048696] raid6: neonx2 xor() 1036 MB/s
[ 1.116753] raid6: neonx4 gen() 1508 MB/s
[ 1.184791] raid6: neonx4 xor() 1183 MB/s
[ 1.252857] raid6: neonx8 gen() 1586 MB/s
[ 1.320888] raid6: neonx8 xor() 1221 MB/s
[ 1.320900] raid6: using algorithm neonx8 gen() 1586 MB/s
[ 1.320911] raid6: .... xor() 1221 MB/s, rmw enabled
[ 1.320923] raid6: using intx1 recovery algorithm
[ 1.321740] SCSI subsystem initialized
[ 1.321923] usbcore: registered new interface driver usbfs
[ 1.321965] usbcore: registered new interface driver hub
[ 1.322003] usbcore: registered new device driver usb
[ 1.322075] media: Linux media interface: v0.10
[ 1.322110] Linux video capture interface: v2.00
[ 1.322142] pps_core: LinuxPPS API ver. 1 registered
[ 1.322154] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.322183] PTP clock support registered
[ 1.322213] EDAC MC: Ver: 3.0.0
[ 1.323295] FPGA manager framework
[ 1.323452] fpga-region fpga-full: FPGA Region probed
[ 1.323575] Advanced Linux Sound Architecture Driver Initialized.
[ 1.323891] Bluetooth: Core ver 2.22
[ 1.323922] NET: Registered protocol family 31
[ 1.323935] Bluetooth: HCI device and connection manager initialized
[ 1.323951] Bluetooth: HCI socket layer initialized
[ 1.323965] Bluetooth: L2CAP socket layer initialized
[ 1.323987] Bluetooth: SCO socket layer initialized
[ 1.324277] clocksource: Switched to clocksource arch_sys_counter
[ 1.324359] VFS: Disk quotas dquot_6.6.0
[ 1.324406] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.328977] NET: Registered protocol family 2
[ 1.329318] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 1.329385] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
[ 1.329516] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.329584] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.329616] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.329730] NET: Registered protocol family 1
[ 1.329943] RPC: Registered named UNIX socket transport module.
[ 1.329957] RPC: Registered udp transport module.
[ 1.329968] RPC: Registered tcp transport module.
[ 1.329979] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.330116] Trying to unpack rootfs image as initramfs...
[ 1.558968] Freeing initrd memory: 5848K (ffffffc007a49000 - ffffffc007fff000)
[ 1.559245] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.559924] futex hash table entries: 512 (order: 4, 65536 bytes)
[ 1.559973] audit: initializing netlink subsys (disabled)
[ 1.560015] audit: type=2000 audit(1.543:1): initialized
[ 1.560561] workingset: timestamp_bits=62 max_order=18 bucket_order=0
[ 1.561201] NFS: Registering the id_resolver key type
[ 1.561227] Key type id_resolver registered
[ 1.561239] Key type id_legacy registered
[ 1.561254] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.561281] jffs2: version 2.2. (NAND) (SUMMARY) ? 2001-2006 Red Hat, Inc.
[ 1.562542] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.562564] io scheduler noop registered
[ 1.562576] io scheduler deadline registered
[ 1.562592] io scheduler cfq registered (default)
[ 1.562943] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.562986] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 1.563373] nwl-pcie fd0e0000.pcie: Link is DOWN
[ 1.563418] OF: PCI: host bridge /amba/pcie@fd0e0000 ranges:
[ 1.563445] OF: PCI: MEM 0xe0000000..0xefffffff -> 0xe0000000
[ 1.563461] OF: PCI: MEM 0x600000000..0x7ffffffff -> 0x600000000
[ 1.563570] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[ 1.563588] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.563602] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[ 1.563617] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[ 1.563817] pci 0000:00:00.0: ignoring class 0x058000 (doesn't match header type 01)
[ 1.564895] pci 0000:00:00.0: not setting up bridge for bus 0000:01
[ 1.565527] Write failed gate address:1000f02
[ 1.565634] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 1.565767] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 1.565904] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 1.566032] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 1.566163] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 1.566294] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 1.566426] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 1.566558] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 1.566763] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 1.566896] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 1.567028] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 1.567158] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 1.567292] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 1.567424] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 1.567558] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 1.567691] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 1.567856] zynqmp_pm firmware: Power management API v0.3
[ 1.567952] xenfs: not registering filesystem on non-xen platform
[ 1.605781] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.607202] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 42, base_baud = 6249999) is a xuartps
[ 2.642037] console [ttyPS0] enabled
[ 2.645803] [drm] Initialized
[ 2.648973] Unable to detect cache hierarchy from DT for CPU 0
[ 2.659473] brd: module loaded
[ 2.665130] loop: module loaded
[ 2.668839] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.676093] m25p80 spi0.0: unrecognized JEDEC id bytes: ef, 71, 19
[ 2.682987] libphy: Fixed MDIO Bus: probed
[ 2.688032] tun: Universal TUN/TAP device driver, 1.6
[ 2.693010] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 2.699316] CAN device driver interface
[ 2.703709] usbcore: registered new interface driver asix
[ 2.709080] usbcore: registered new interface driver ax88179_178a
[ 2.715131] usbcore: registered new interface driver cdc_ether
[ 2.720946] usbcore: registered new interface driver net1080
[ 2.726587] usbcore: registered new interface driver cdc_subset
[ 2.732490] usbcore: registered new interface driver zaurus
[ 2.738060] usbcore: registered new interface driver cdc_ncm
[ 2.744061] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.750514] ehci-pci: EHCI PCI platform driver
[ 2.755163] usbcore: registered new interface driver uas
[ 2.760436] usbcore: registered new interface driver usb-storage
[ 2.766674] mousedev: PS/2 mouse device common for all mice
[ 2.772626] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 2.779812] i2c /dev entries driver
[ 2.783470] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 30
[ 2.789598] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 31
[ 2.796451] usbcore: registered new interface driver uvcvideo
[ 2.802116] USB Video Class driver (1.1.1)
[ 2.806577] Bluetooth: HCI UART driver ver 2.3
[ 2.810946] Bluetooth: HCI UART protocol H4 registered
[ 2.816064] Bluetooth: HCI UART protocol BCSP registered
[ 2.821358] Bluetooth: HCI UART protocol LL registered
[ 2.826479] Bluetooth: HCI UART protocol ATH3K registered
[ 2.831864] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 2.838148] Bluetooth: HCI UART protocol Intel registered
[ 2.843526] Bluetooth: HCI UART protocol Broadcom registered
[ 2.849136] Bluetooth: HCI UART protocol QCA registered
[ 2.854374] usbcore: registered new interface driver bcm203x
[ 2.860016] usbcore: registered new interface driver bpa10x
[ 2.865571] usbcore: registered new interface driver bfusb
[ 2.871040] usbcore: registered new interface driver btusb
[ 2.876478] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 2.882168] usbcore: registered new interface driver ath3k
[ 2.887700] EDAC MC: ECC not enabled
[ 2.891346] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 2.904186] sdhci: Secure Digital Host Controller Interface driver
[ 2.910288] sdhci: Copyright(c) Pierre Ossman
[ 2.914625] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.968289] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[ 2.976472] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.982526] usbcore: registered new interface driver usbhid
[ 2.988018] usbhid: USB HID core driver
[ 2.997480] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 3.005450] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 3.014166] Netfilter messages via NETLINK v0.30.
[ 3.018914] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.024205] Initializing XFRM netlink socket
[ 3.028455] NET: Registered protocol family 10
[ 3.033233] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.038594] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.044797] NET: Registered protocol family 17
[ 3.049169] NET: Registered protocol family 15
[ 3.053597] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.057945] mmc0: new high speed SDHC card at address 1234
[ 3.058202] mmcblk0: mmc0:1234 SA04G 3.64 GiB (ro)
[ 3.059578] mmcblk0: p1
[ 3.079272] Ebtables v2.0 registered
[ 3.082870] can: controller area network core (rev 20120528 abi 9)
[ 3.089035] NET: Registered protocol family 29
[ 3.093433] can: raw protocol (rev 20120528)
[ 3.097681] can: broadcast manager protocol (rev 20161123 t)
[ 3.103326] can: netlink gateway (rev 20130117) max_hops=1
[ 3.108841] Bluetooth: RFCOMM TTY layer initialized
[ 3.113658] Bluetooth: RFCOMM socket layer initialized
[ 3.118782] Bluetooth: RFCOMM ver 1.11
[ 3.122509] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.127801] Bluetooth: BNEP filters: protocol multicast
[ 3.133013] Bluetooth: BNEP socket layer initialized
[ 3.137956] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.143863] Bluetooth: HIDP socket layer initialized
[ 3.148970] 9pnet: Installing 9P2000 support
[ 3.153180] Key type dns_resolver registered
[ 3.157774] registered taskstats version 1
[ 3.162167] Btrfs loaded, crc32c=crc32c-generic
[ 3.176743] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.182177] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.190030] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x02010010
[ 3.198688] xhci-hcd xhci-hcd.0.auto: irq 221, io mem 0xfe300000
[ 3.204761] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.211475] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.218689] usb usb1: Product: xHCI Host Controller
[ 3.223535] usb usb1: Manufacturer: Linux 4.9.0-xilinx-v2017.3 xhci-hcd
[ 3.230132] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 3.235305] hub 1-0:1.0: USB hub found
[ 3.238997] hub 1-0:1.0: 1 port detected
[ 3.243046] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.248464] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 3.256145] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 3.264253] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 3.270966] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.278174] usb usb2: Product: xHCI Host Controller
[ 3.283027] usb usb2: Manufacturer: Linux 4.9.0-xilinx-v2017.3 xhci-hcd
[ 3.289625] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 3.294745] hub 2-0:1.0: USB hub found
[ 3.298436] hub 2-0:1.0: 1 port detected
[ 3.303232] rtc_zynqmp ffa60000.rtc: setting system clock to 1970-01-01 00:00:05 UTC (5)
[ 3.311365] clk: Not disabling unused clocks
[ 3.315593] ALSA device list:
[ 3.318509] No soundcards found.
[ 3.322428] Freeing unused kernel memory: 512K (ffffffc000b80000 - ffffffc000c00000)
Starting udev
[ 3.435991] udevd[1505]: starting version 3.2
[ 3.440637] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.447128] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.453549] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.459945] random: udevd: uninitialized urandom read (16 bytes read)
[ 3.470162] udevd[1506]: starting eudev-3.2
[ 3.512682] random: udevd: uninitialized urandom read (16 bytes read)
Populating dev cache
[ 4.218362] random: dd: uninitialized urandom read (512 bytes read)
Sat Aug 18 11:40:38 UTC 2018
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
Starting Dropbear SSH server: [ 4.386104] random: dropbearkey: uninitialized urandom read (32 bytes read)
[ 4.395671] random: dropbearkey: uninitialized urandom read (32 bytes read)
[ 11.326677] random: dropbearkey: uninitialized urandom read (32 bytes read)
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCU[ 11.341162] random: dropbear: uninitialized urandom read (32 bytes read)
2MgcujFvK0taPYxfPvINwfqzFEMSakVZTQLSJoBzKda6aCdjXbH0iPknjNHHL89Kf7itr5WnjjC8D+Pf2TytHDG1y0xbX9jQQCrTMWDNGeZFaf0z229yEWCfTFBVpsokeWtS5rxfwBCxoCAMFXhNB7lCeKa0PZKFehwrnRNJWmCfhhvysjFp2vgX6JRolyE1/qbswRIEUG8mWPtDIQgZazGUV0ndbOeVesxQ8G5lrMjVQMl7qr+aqEoFarxqqly3Fpw1V+6d9WwMJ0ZvJSf7hWdjyToD5rX/d3FkIXywOo7WL5ado25i+h99qMdXKtCQZ6KR5qd7kJQ1wn1P/aNV root@zu4cg_hdmi_t
Fingerprint: md5 3d:a8:52:46:4b:2f:92:2d:5f:33:2e:35:4c:e9:d7:fe
dropbear.
PetaLinux 2017.3 zu4cg_hdmi_t /dev/ttyPS0
zu4cg_hdmi_t login: root
Password:
root@zu4cg_hdmi_t:~# ls
root@zu4cg_hdmi_t:~# mount /dev/mmcblk0p1 /mnt
