platform data
I am trying to interface with mt9m001 camera. The i2c dts is as shown below
&i2c1 {
clock-frequency = <400000>;
status = "okay";
camera-sensor@5d {
compatible = "mt9m001";
reg = <0x5d>;
reset-gpios = <&gpio0 0 0>;
standby-gpios = <&gpio0 1 1>;
/*clocks = <&camera_clk>;*/
port {
mt9m001_out: endpoint {
remote-endpoint = <&vcap_demosaic_in>;
I get the this kernel messsage
mt9m001 1-005d: MT9M001 driver needs platform data
how do I pass platform data
JOTHI
Is this sensor at the address 0x5d as specified in your DT?
Can you share the vcap_demosaic_in node? is this correct?
the i2c sensor address is correct.
root@zynq:~# i2cdetect -y -r 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- 5d -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
2. Can you share the vcap_demosaic_in node? is this correct?
I am not sure about this.
The camera is connected like this Camera->VideoIn2AxisStream->demosaic->frmbuf->ddr.
Does this node exist?
vcap_demosaic_in
Yes. It exists.
can you point to me similar device tree pipeline?
