problem about opencv used petalinux 2017.4
hi:
  my test bord is zcu102,i want to read a image ,then use opencv lib to process and show it with dp port , i use the function imshow in opencv lib to show the result of the image ,when i run the code on the board,
Gtk-WARNING **: cannot open display:
my rootfs config in petalinux2017.4 is :
file-system-package--->
       misc--->
         packagegroup-petalinux-opecv-->
             [*]packagegroup-petalinux-opecv
             [*]packagegroup-petalinux-opecv-dev
             [] packagegroup-petalinux-opecv-dbg
         packagegroup-petalinux-qt-->
             [*]packagegroup-petalinux-qt
             [] packagegroup-petalinux-qt-dev
             [] packagegroup-petalinux-qt-dbg
         packagegroup-petalinux-x11-->
             [*]packagegroup-petalinux-x11
             [] packagegroup-petalinux-x11-dev
             [] packagegroup-petalinux-x11-dbg
my code is :
#include <iostream>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/imgproc.hpp>
using namespace std;
using namespace cv;
Mat rotate(Mat src, double angle)
Mat dst;
Point2f pt(src.cols/2., src.rows/2.);
Mat r = getRotationMatrix2D(pt, angle, 1.0);
warpAffine(src, dst, r, Size(src.cols, src.rows));
return dst;
int main(int argc, char *argv[])
cout << "Hello, Rotate Image!\n";
Mat src=imread("sample.jpg");
if(!src.data)
printf("No data!--Exiting the program \n");
return -1;
Mat dst;
dst = rotate(src, 10);
imshow("src", src);
imshow("dst", dst);
waitKey(0);
return 0;
Did you find a way to solve this problem?
