problems sourcing crosscompilation in ubuntu 16.04
hello,
I am using petalinux 2017.4 and SDSoC 2017.4 on Ubuntu 16.4.
arm-xilinx is not installed in my system.
source /opt/Xilinx/Vivado/2017.4/settings64.sh
source /opt/pkg/petalinux/settings.sh
user@machine:~/$ arm-
arm-linux-gnueabihf-addr2line   arm-linux-gnueabihf-ld.bfd      arm-none-eabi-gcc-6.2.1
arm-linux-gnueabihf-ar          arm-linux-gnueabihf-nm          arm-none-eabi-gcc-ar
arm-linux-gnueabihf-as          arm-linux-gnueabihf-objcopy     arm-none-eabi-gcc-nm
arm-linux-gnueabihf-c++         arm-linux-gnueabihf-objdump     arm-none-eabi-gcc-ranlib
arm-linux-gnueabihf-c++filt     arm-linux-gnueabihf-ranlib      arm-none-eabi-gcov
arm-linux-gnueabihf-cpp         arm-linux-gnueabihf-readelf     arm-none-eabi-gcov-tool
arm-linux-gnueabihf-elfedit     arm-linux-gnueabihf-size        arm-none-eabi-gdb
arm-linux-gnueabihf-g++         arm-linux-gnueabihf-strings     arm-none-eabi-gprof
arm-linux-gnueabihf-gcc         arm-linux-gnueabihf-strip       arm-none-eabi-ld
arm-linux-gnueabihf-gcc-6.2.1   arm-none-eabi-addr2line         arm-none-eabi-ld.bfd
arm-linux-gnueabihf-gcc-ar      arm-none-eabi-ar                arm-none-eabi-nm
arm-linux-gnueabihf-gcc-nm      arm-none-eabi-as                arm-none-eabi-objcopy
arm-linux-gnueabihf-gcc-ranlib  arm-none-eabi-c++               arm-none-eabi-objdump
arm-linux-gnueabihf-gcov        arm-none-eabi-c++filt           arm-none-eabi-ranlib
arm-linux-gnueabihf-gcov-tool   arm-none-eabi-cpp               arm-none-eabi-readelf
arm-linux-gnueabihf-gdb         arm-none-eabi-elfedit           arm-none-eabi-size
arm-linux-gnueabihf-gprof       arm-none-eabi-g++               arm-none-eabi-strings
arm-linux-gnueabihf-ld          arm-none-eabi-gcc               arm-none-eabi-strip
arm-xilinx- is missing.
this is my path:
echo $PATH
/opt/pkg/petalinux/tools/linux-i386/petalinux/bin
/opt/pkg/petalinux/tools/common/petalinux/bin
/opt/pkg/petalinux/tools/linux-i386/gcc-arm-none-eabi-r5/bin
/opt/pkg/petalinux/tools/linux-i386/microblaze-xilinx-elf/bin
/opt/pkg/petalinux/tools/linux-i386/microblazeel-xilinx-linux-gnu/bin
/opt/pkg/petalinux/tools/linux-i386/gcc-arm-none-eabi/bin
/opt/pkg/petalinux/tools/linux-i386/gcc-arm-linux-gnueabi/bin
/opt/pkg/petalinux/tools/linux-i386/aarch64-none-elf/bin
/opt/pkg/petalinux/tools/linux-i386/aarch64-linux-gnu/bin
/opt/Xilinx/SDK/2017.4/bin
/opt/Xilinx/SDK/2017.4/gnu/microblaze/lin/bin
/opt/Xilinx/SDK/2017.4/gnu/arm/lin/bin
/opt/Xilinx/SDK/2017.4/gnu/microblaze/linux_toolchain/lin64_le/bin
/opt/Xilinx/SDK/2017.4/gnu/aarch32/lin/gcc-arm-linux-gnueabi/bin
/opt/Xilinx/SDK/2017.4/gnu/aarch32/lin/gcc-arm-none-eabi/bin
/opt/Xilinx/SDK/2017.4/gnu/aarch64/lin/aarch64-linux/bin
/opt/Xilinx/SDK/2017.4/gnu/aarch64/lin/aarch64-none/bin
/opt/Xilinx/SDK/2017.4/gnu/armr5/lin/gcc-arm-none-eabi/bin
/opt/Xilinx/SDK/2017.4/tps/lnx64/cmake-3.3.2/bin
/opt/Xilinx/Vivado/2017.4/bin
/opt/Xilinx/DocNav
/opt/Xilinx/SDx/2017.4/bin
/home/m/bin
/home/m/.local/bin
/usr/local/sbin
/usr/local/bin
/usr/sbin
/usr/bin
/sbin
/bin
/usr/games
/usr/local/games
/snap/bin
petalinux is installed:
echo $PETALINUX
/opt/pkg/petalinux
here it says that SDx SDK does not install xilinx arm tools. So I run Software Development Kit Standalone WebInstall Client - 2017.4 Lightweight Installer
and installed SDK into /opt/Xilinx2/SDK without program group entry.
Now, I still cannot find arm-xilinx:
/opt/Xilinx2/SDK/2017.4/gnu/armr5/lin/gcc-arm-none-eabi/bin$ tree
├── armr5-none-eabi-addr2line
├── armr5-none-eabi-ar
├── armr5-none-eabi-as
├── armr5-none-eabi-c++
├── armr5-none-eabi-c++filt
├── armr5-none-eabi-cpp
├── armr5-none-eabi-elfedit
├── armr5-none-eabi-g++
├── armr5-none-eabi-gcc
├── armr5-none-eabi-gcc-6.2.1
├── armr5-none-eabi-gcc-ar
├── armr5-none-eabi-gcc-nm
├── armr5-none-eabi-gcc-ranlib
├── armr5-none-eabi-gcov
├── armr5-none-eabi-gcov-tool
├── armr5-none-eabi-gdb
├── armr5-none-eabi-gprof
├── armr5-none-eabi-ld
├── armr5-none-eabi-ld.bfd
├── armr5-none-eabi-nm
├── armr5-none-eabi-objcopy
├── armr5-none-eabi-objdump
├── armr5-none-eabi-ranlib
├── armr5-none-eabi-readelf
├── armr5-none-eabi-size
├── armr5-none-eabi-strings
└── armr5-none-eabi-strip
I don't know the path, though. Where can I find arm-xilinx?
It still does not work:
make CROSS_COMPILE=arm-xilinx-linux-gnueabi- zynq_zybo_config
make: arm-xilinx-linux-gnueabi-gcc: Command not found
I did not do this:
bash$ source <Xilinx Tools installation directory>/ISE_DS/settings64.sh
Re: problems sourcing crosscompilation in ubuntu 16.04
Can you please use this command.
make CROSS_COMPILE=arm-linux-gnueabihf- zynq_zybo_config
You can find the toolchain in petalinux installed  folder: petalinux-v2017.4-final/tools/linux-i386/gcc-arm-linux-gnueabi/bin/
xhdaravindb40:/aravind_working_dir/tmp/xilinx-zcu102-2017.4 $ ls /proj/petalinux/petalinux-v2017.4_daily_latest/petalinux-v2017.4-final/tools/linux-i386/gcc-arm-linux-gnueabi/bin/
arm-linux-gnueabihf-addr2line arm-linux-gnueabihf-gcc arm-linux-gnueabihf-gprof arm-linux-gnueabihf-size
arm-linux-gnueabihf-ar arm-linux-gnueabihf-gcc-6.2.1 arm-linux-gnueabihf-ld arm-linux-gnueabihf-strings
 Thanks & Regards
Aravind
 Thanks & Regards
Aravind
