sdk build error under petalinux2019.2
When I reproduce the LFAR: Porting the ResNet-50 CNN application to a ZedBoard  https://www.xilinx.com/Attachment/73058_Porting_a_ResNet-50_CNN_application_to_a_ZedBoard_2019_2.pdf
whene I try to build SDK(petalinux-build --sdk), met errors, the information as below, more details please refer to attachment.
ERROR: Task (/opt/petalinux/components/yocto/source/arm/layers/core/meta/recipes-devtools/gcc/gcc-crosssdk_8.2.bb:do_compile) failed with exit code '1'
