mcggoal
selected processor does not support ARM mode `isb'
hi, Experts
I am working on AVNET picozed following the https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841616/Zynq+Base+TRD+2015.4. The default operation is to generate uboot, kernel , dts, ramfs on SD card, but now I am trying to generate BOOT.bin & image.ub based on the demo petalinux project,  and boot up from SPI flash + EMMC mode.
What I have done are shown below:
  • petlinux-config -> ...-> boot image settings : choose primary flash
  • petlinux-config -> ... -> kernel image settings: choose primary SD
  • petalinux-config -> Auto config settings: select kernel auto config / rootfs auto config / u-boot auto config;
  • petalinux-config -> u-boot configuration -> u-boot config : choose petalinux u-boot config, also set proper netboot offset value;
  • adjust flash partition size, as the BOOT.bin is larger than default size.
Then I run petalinux-build, when building kernel, it reported as:
[ERROR] make[4]: *** [arch/arm/mach-zynq/lowlevel_init.o] Error 1
[ERROR] make[3]: *** [arch/arm/mach-zynq] Error 2
[ERROR] make[2]: *** [sub-make] Error 2
And the ./build/build.log file reported error:
[ALL ] /home/mcggoal/xlnx_project/pzfmc2_bgslib/petalinux/build/linux/u-boot/src/u-boot-plnx/arch/arm/mach-zynq/lowlevel_init.S: Assembler messages:
[ALL ] /home/mcggoal/xlnx_project/pzfmc2_bgslib/petalinux/build/linux/u-boot/src/u-boot-plnx/arch/arm/mach-zynq/lowlevel_init.S:18: Error: selected processor does not support ARM mode `isb'
[ALL ] /home/mcggoal/xlnx_project/pzfmc2_bgslib/petalinux/build/linux/u-boot/src/u-boot-plnx/scripts/Makefile.build:312: recipe for target 'arch/arm/mach-zynq/lowlevel_init.o' failed
Can anybody give suggestions on this ?
chaoz
Hi , @mcggoal
What are the commands you created this Petalinux project and get the HDF file with?
Maybe you created your project with zynqMP template but souced a zynq7000 HDF file?
Chao
如果帖子有帮助,别忘“接受为解决方案”或“奖励”。谢谢!
Don't forget to "Accept as solution" or "Kudo" if it helps. Thanks!
mcggoal
@chaoz  thanks for reply.
I did not create project using command , I just copied it from "petalinux folder" in DEMO package, then using petalinux-config --get-hw-description = ./hw-description, so it's sure to use the correct CPU.
What I want is just change options in petalinux-config window and build BOOT.bin and image.ub for QSPI+EMMC bootup.
mcggoal
@chaoz I have got thru this error, that is caused by the unnecessary environment variable setting, which is used for OPENCV cross-compilation.
But, the building process still fault at further step, the error log shows:
[ALL ] arch/arm/kernel/built-in.o: In function `cpu_resume':
[ALL ] arch/arm/kernel/hyp-stub.o:(.data+0x2fc): relocation truncated to fit: R_ARM_CALL against symbol `__hyp_stub_install_secondary' defined in .text section in arch/arm/kernel/built-in.o
[ALL ] /home/mcggoal/xlnx_project/pzfmc2_spi_emmc/petalinux/components/linux-kernel/xlnx-4.0-python/Makefile:933: recipe for target 'vmlinux' failed
[ERROR] make[4]: *** [vmlinux] Error 1
I think it maybe caused by large rootfs size, because my rootfs size is larger than 90MB.
Do you have any suggestion on this ? how can I build a large image ?
