taghlaoui
simpleImage.xilinx
  > make ARCH=microblaze simpleImage.xilinx
I have the problem:
make: microblaze-unknown-linux-gnu-gcc: Command not found
scripts/kconfig/conf --silentoldconfig Kconfig
CHK include/linux/version.h
CHK include/generated/utsrelease.h
CC kernel/bounds.s
/bin/sh: microblaze-unknown-linux-gnu-gcc: command not found
make[1]: *** [kernel/bounds.s] Error 127
make: *** [prepare0] Error 2
I don't know where I was wrong ? I did set the path to access tools and setup the environment variable for the Linux kernel build process with the following commands:
         export PATH=<dir where the tools are untarred>/microblaze-unknown-linux-gnu/bin:$PATH
        export CROSS_COMPILE=microblaze-unknown-linux-gnu-
Thanks for your help!
linnj
I don't see anything obviously wrong, did you try to run the tools from the command line to verify it works (>microblaze-unknown-linux-gnu-gcc)?
jmgrn
qwangku@qwangku-Inspiron-1545:~/linux-xlnx$ make ARCH=microblaze simpleImage.xilinx
  CHK     include/config/kernel.release
  CHK     include/generated/uapi/linux/version.h
  CC      kernel/bounds.s
/bin/sh: 1: microblaze-unknown-linux-gnu-gcc: not found
Kbuild:42: recipe for target 'kernel/bounds.s' failed
Makefile:990: recipe for target 'prepare0' failed
qwangku@qwangku-Inspiron-1545:~/linux-xlnx$ microblaze-unknown-linux-gnu-gcc
bash: /home/qwangku/microblaze-unknown-linux-gnu/bin/microblaze-unknown-linux-gnu-gcc: No such file or directory
Sir, I came accross the same problem.  But I am pretty sure "microblaze-unknown-linux-gnu-gcc" exists, and please see the attached picture:
I was wondering why I still get this error...
jmgrn
Although I am a newbie, I feel responsible for my own question. I figure out the solution to the above problem.
The solution can be found here
https://forums.xilinx.com/t5/Embedded-Development-Tools/bin-sh-mb-gcc-not-found-Xilinx-SDK-14-4/td-p/320727
