Participant mojtaba.ahmadi
startx turns LCD off
hello.
I am working on MYiR zturn board. I want to boot up linux with desktop environment. I designed my PL with vdma and axi4 lite video out and an LCD is connected to board with HDMI. and corresponding driver is written for linux.
when system boots, The LCD turns on and displays random colors, but when "startx" runs (that I expect desktop environment to be shown), LCD turns off and after a while this error is claimed:
cpufreq: __cpufreq_driver_target: Failed to change cpu frequency: -16
cpufreq_cpu0: failed to set clock rate: -16
what is the problem? does running server X harms cpu frequency? or the problem is with driver?
I have serache da lot but have not found any solution for my problem.
thank you.
Re: startx turns LCD off
Can you share the device-tree node for your LCD ip?
@stephenm
I have nothing about LCD in my device tree, but have something for my driver that is working with frame buffer of linux. device tree for LCD is not nedded becuase of my design.
design is in this way:
corresponding device tree is:
logicvc@43c10000 {
compatible = "fmr,logicvc-1.00.a";
interrupt-parent = <0x3>;
interrupts = <0x0 0x1e 0x4>;
reg = <0x43000000 0x10000>;
fmr,clk-baseaddr = <0x43c10000>;
fmr,clk-size = <0x10000>;
fmr,vtc-baseaddr = <0x43c00000>;
fmr,vtc-size = <0x10000>;
fmr,buffer-0-offset = <0x438>;
fmr,buffer-1-offset = <0x438>;
fmr,buffer-2-offset = <0x438>;
fmr,buffer-3-offset = <0x438>;
fmr,display-color-space = <0x0>;
fmr,buffer-4-offset = <0x400>;
fmr,display-interface = <0x0>;
fmr,layer-0-alpha-mode = <0x1>;
fmr,layer-0-data-width = <0x18>;
fmr,layer-0-offset = <0x0>;
fmr,layer-0-type = <0x0>;
fmr,layer-1-alpha-mode = <0x0>;
fmr,layer-1-data-width = <0x18>;
fmr,layer-1-offset = <0xfd2>;
fmr,layer-1-type = <0x0>;
fmr,layer-2-alpha-mode = <0x0>;
fmr,layer-2-data-width = <0x18>;
fmr,layer-2-offset = <0x0>;
fmr,layer-2-type = <0x0>;
fmr,layer-3-alpha-mode = <0x3>;
fmr,layer-3-data-width = <0x8>;
fmr,layer-3-offset = <0x32a0>;
fmr,layer-3-type = <0x0>;
fmr,layer-4-alpha-mode = <0x0>;
fmr,layer-4-data-width = <0x18>;
fmr,layer-4-offset = <0x2000>;
fmr,layer-4-type = <0x0>;
fmr,num-of-layers = <0x1>;
fmr,readable-regs = <0x1>;
fmr,row-stride = <0x800>;
fmr,vmem-baseaddr = <0x30000000>;
fmr,vmem-highaddr = <0x3fffffff>;
pixel-clock-source = <0x2>;
pixel-data-invert = <0x0>;
pixel-clock-active-high = <0x0>;
pixel-component-format = "ARGB";
pixel-component-layer = <0x0 0x1 0x2>;
fmr,use-background = <0x0>;
active-layer = <0x0>;
videomode = "1920x1080";
edid {
preffered-videomode = <0x1>;
display-data = <0x1>;
fmr-video-params {
640x480_LCD1 {
refresh = <0x3c>;
xres = <0x280>;
yres = <0x1e0>;
pixclock-khz = <0x61a8>;
left-margin = <0x10>;
right-margin = <0x30>;
upper-margin = <0xa>;
lower-margin = <0x21>;
hsync-len = <0x60>;
vsync-len = <0x2>;
sync = <0x0>;
vmode = <0x0>;
480x272_LCDV1 {
refresh = <0x3c>;
xres = <0x1e0>;
yres = <0x110>;
pixclock-khz = <0x2710>;
left-margin = <0x28>;
right-margin = <0x28>;
upper-margin = <0x1d>;
lower-margin = <0xd>;
hsync-len = <0x30>;
vsync-len = <0x3>;
sync = <0x0>;
vmode = <0x0>;
800x480_LCDV2 {
refresh = <0x3c>;
xres = <0x320>;
yres = <0x1e0>;
pixclock-khz = <0x8232>;
left-margin = <0xd2>;
right-margin = <0x2c>;
upper-margin = <0x16>;
lower-margin = <0x15>;
hsync-len = <0x2>;
vsync-len = <0x2>;
sync = <0x0>;
vmode = <0x0>;
1024x768 {
refresh = <0x3c>;
xres = <0x400>;
yres = <0x300>;
pixclock-khz = <0xfde8>;
left-margin = <0xa0>;
right-margin = <0x18>;
lower-margin = <0x3>;
hsync-len = <0x88>;
vsync-len = <0x6>;
sync = <0x1>;
vmode = <0x0>;
1280x720 {
refresh = <0x3c>;
xres = <0x500>;
yres = <0x2d0>;
pixclock-khz = <0x1220a>;
left-margin = <0xdc>;
right-margin = <0x6e>;
upper-margin = <0x14>;
lower-margin = <0x5>;
hsync-len = <0x28>;
vsync-len = <0x5>;
sync = <0x1>;
vmode = <0x0>;
1680x1050 {
refresh = <0x3c>;
xres = <0x690>;
yres = <0x41a>;
pixclock-khz = <0x1d0d8>;
left-margin = <0x50>;
upper-margin = <0x15>;
hsync-len = <0x20>;
vsync-len = <0x6>;
sync = <0x0>;
vmode = <0x0>;
1920x1080 {
refresh = <0x3c>;
xres = <0x780>;
yres = <0x438>;
pixclock-khz = <0x24414>;
left-margin = <0x94>;
right-margin = <0x58>;
upper-margin = <0x24>;
lower-margin = <0x4>;
hsync-len = <0x2c>;
vsync-len = <0x5>;
sync = <0x0>;
vmode = <0x0>;
I edit device tree in this way and the frequency error cleared. but the main problem about turning off the LCD after running startx exists yet.
logicvc@43c10000 {
			fmr,buffer-4-offset = <0x438>;
			fmr,layer-0-offset = <0x1c7a>;
			active-layer = <0x1>;
			edid {
			fmr-video-params {
				640x480_LCD1 {
					refresh = <0x3c>;
					xres = <0x280>;
					yres = <0x1e0>;
					hsync-len = <0x60>;
					vsync-len = <0x2>;
					sync = <0x0>;
					vmode = <0x0>;
				480x272_LCDV1 {
					refresh = <0x3c>;
					xres = <0x1e0>;
					yres = <0x110>;
					hsync-len = <0x30>;
					vsync-len = <0x3>;
					sync = <0x0>;
					vmode = <0x0>;
				800x480_LCDV2 {
					refresh = <0x3c>;
					xres = <0x320>;
					yres = <0x1e0>;
					hsync-len = <0x2>;
					vsync-len = <0x2>;
					sync = <0x0>;
					vmode = <0x0>;
				1024x768 {
					refresh = <0x3c>;
					xres = <0x400>;
					yres = <0x300>;
					hsync-len = <0x88>;
					vsync-len = <0x6>;
					sync = <0x1>;
					vmode = <0x0>;
				1280x720 {
					refresh = <0x3c>;
					xres = <0x500>;
					yres = <0x2d0>;
					hsync-len = <0x28>;
					vsync-len = <0x5>;
					sync = <0x1>;
					vmode = <0x0>;
				1680x1050 {
					refresh = <0x3c>;
					xres = <0x690>;
					yres = <0x41a>;
					hsync-len = <0x20>;
					vsync-len = <0x6>;
					sync = <0x0>;
					vmode = <0x0>;
				1920x1080 {
					refresh = <0x3c>;
					xres = <0x780>;
					yres = <0x438>;
					hsync-len = <0x2c>;
					vsync-len = <0x5>;
					sync = <0x0>;
					vmode = <0x0>;
start x after running, looks for xorg.conf and I did not have it. I create this file in /etc/X11/ directory and write this code in it:
Section "Screen"
        Identifier "Screen0"
        Device "/dev/fb0"
EndSection
now the screen stays at showing random pixels state.
but still I can not display the Desktop Environment.
