struct dma_pl330_platdata in pl330.c
Hi, all.
I'm reading the following pl330.c.
https://github.com/Xilinx/linux-xlnx/blob/master/drivers/dma/pl330.c
There is a struct called dma_pl330_platdata. I think this struct is created by another .c file.
So I searched all the linux kernel files, but cannot find it.
Can you tell me where is the dma_pl330_platdata created?
static int pl330_probe(struct amba_device *adev, const struct amba_id *id) { struct dma_pl330_platdata *pdat; struct pl330_config *pcfg; struct pl330_dmac *pl330; struct dma_pl330_chan *pch, *_p; struct dma_device *pd; struct resource *res; int i, ret, irq; int num_chan; struct device_node *np = adev->dev.of_node; pdat = dev_get_platdata(&adev->dev); ret = dma_set_mask_and_coherent(&adev->dev, DMA_BIT_MASK(32)); if (ret) return ret;
 Thanks in advance.
Feng
