qswsjs
test pcie on microblaze with petalinux
    Anyone test pcie(root complement) on Microblaze with petalinux ? Is it necessary ? I have no idea how to do . can you give me some suggestion or advices,thanks!
kotir
I just moved this post to Embedded liux board so that if any body tried petalinux with PCIe they would respond to this..
ryserp
We have some customers who are running PetaLinux on MicroBlaze and have configured the AXI2PCIe core as a root complex. So, yes, it has been successfully done.
I am not sure what you mean by asking "is it necessary?". Please clarify.
qswsjs
 The AXI bus support root complement mode for virtex6? I saw the info in axipcie v2_02_a IP library
IP Hardware Configuration The AXI PCIE IP supports only the endpoint for Virtex®-6 and Spartan®-6 families.
The AXI PCIE IP supports both the endpoint and Root Port for the Kintex® 7 devices.
shravan466
I am new to axipcie .
I need to test the axipcie in zc706 board.I had seen the dts file for zc706.
But i hadn't found any entry in dts file .
Can any one help me . How to make dts entry fro axipcie . With it base address.
madhu.mami60
Hi @ryserp,
Can you confirm, Is it necessory to have CDMA to implement AXI-PCIe in root complex mode with Microblaze to run Linux?
Madhu
