u-boot execute the standalone example hello_world
I have a xilinx Picozed devkit and am using Petalinux 2016.3
The source dirtectory of u-boot contains an example hello_world.c in build/linux/u-boot/src/u-boot-plnx/examples/standalone
Compilation goes through and even creates an appropriate .o and executable file.
But how is this in u-boot included?
And how can i execute it in u-boot.
The u-boot.map doesn't even show anything relating to example or hello_world.
Hi Paul
These examples are not specific or targeted to Xilinx's platforms. This is shipped with open source uboot also.
https://github.com/Xilinx/u-boot-xlnx/tree/master/examples/standalone
If you want to run this applications, you may give a try to load it through either tftp or serial loadb commands, and run it, which is explained in the above link.
These applications are not developed by Xilinx.
Best Regards
Shabbir
