u-boot will not built for custom board
Hi John,
I will grateful if you could help me/point me in the right direction, with regards to the following:
We have succesfully built u-boot for ml507, however when we try to built it for a custom board with the same fpga (v5fxt70t), we get an error:
 -Map u-boot.map -o u-boot
fs/fat/libfat.a(fat.o): In function `fat_register_device':
/opt/xilinx/u-boot-xlnx.git/fs/fat/fat.c:92: undefined reference to `get_partition_info'
We have replaced the original xparameters.h (under E:\AIDA_XH\linux\files_from_git_tree\u_boot\u-boot-xlnx.git\board\xilinx\ml507) with the new one from the xps project (under <proj name>\ppc440_0\include).
Is there any other changes we need to do for the u-boot to built succesfully for a custom board with v5fx70t?( regenate the config.mk and xparameters.mk?)
Thank you  Mos
Not to my knowledge is there anything else you should do. I'm assuming (don't remember) there's way to do a clean make, I would do that.
What's the differences between the xparameters as maybe there's something causing it to build differently.
make clean
make 507_config
make
and it builts fine, with new xparameters.h
Mos
