wangdeyou
uartlite Rx can't receive data
i have the zedboard development board,running Linux system (4.6.0)。Four uartlite IP cores are used in block design.in the /dev,we can see ttyUL1, ttyUL2, ttyUL3, ttyUL4, and ttyUL4.When I use the command echo 1 >/dev/ttyul1, I can receive data on the serial terminal. But when I send data using a serial termina,cat /dev/ttyUL1 receives no data.
cat /proc/interrupts
my devicetree
wangdeyou
I've solved this problem。because in the dts file ,uartlite interrupts num is not right.
Hello..
i am also facing same issue can you please let me know what chages you done it in dtsi file.
Hello..
Please help me with this i am also facing same problem like how you are getting .
i am attaching my dtsi file find an let help out of this ?
wangdeyou
can you speeak chinese?
兄弟,中国人吗?
Hello..
Thank you for replay back ?
Sorry i don't know chinese .please let help with this
wangdeyou
you can check inteerrupt num and irq id.
interrupt num= irq_id - 32.
IRQF2P[15:8] is ID#91:84
IRQF2P[7:0] is ID#68:61
reference linking:
https://www.xilinx.com/support/answers/51763.html#description
Hello ..
Please find the attached images . how i connected the interrupt's
i don't understand what you mention in the link below ?
can you help me with my dtsi file what done is correct are wrong
wangdeyou
please tell me which interrupt line in concat connect to uartlite interrupt.
Hello..
Please find the below image .the below line i connected for uartlite ip core.
Hello..
Please find the below attachment.shall I need to change anything in my devicetree file please let me help with this?
wangdeyou
In4, irq id is 65, interrupt num is 33;
In5, irq id is 66,  interrupt num is 34;
In6, irq id is 67, interrupt num is 35;
In7, irq id is 68, interrupt num is 36;
In10,irq id is 86,  interrupt num is 54;
Refer to the table below。
if your uartlite@42c40000 interrupt connect to In4, in dts file, node of uartlite@42c40000 should be
serial@42c40000 {
interrupts = <0x0 33 0x1>;
Hello..
My issue is resolved with uartlite's thank you very much.
One more issue i have with axi-gpio . in my design i have 17 gpio's. for this i need to connect interrupt's for GPIO.
i made my dtsi like how you spefied the interrupt connection table  .  But interrupts for the GPIO are not enabling is there any thing i need to do in .dtsi ?
Please find the attachements  ?
1.pps_in(0x4126_0000)
2.pps_out (0x4122_0000)
3.irnss_pps(0x4125_0000)
remaing Axi-gpio i connected without interrupt . can please help me with this ?
Shall i need to change any thing in kernal for this Gpio interrupt enableing ?
Hello..
Can you Please help me with GPIO interrupt enabling ?
wangdeyou
sorry,it's too long,i need some time to review.
You can refer to this link :
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841846/AXI+GPIO
Hello..
Can you get any idea on my issue ?
Please let me know where I am going wrong.help me with this
Hello ..
Please let me know whether you will get my problem or not
wangdeyou
sorry,i don't know yet
Hello..
Please let me know if you get any information regarding this
