valgrind on Petalinux 2017.1
Hi all,
I am trying to install valgrind on Petalinux 2017.1 for the zcu102 board. I am facing the same problems as in here
https://forums.xilinx.com/t5/Embedded-Linux/Valgrind-on-Petalinux-2016-4/m-p/764951#M19693
Unfortunately,  the solution provided by @tristan.gibson in the above post is not working for me. I still cannot find the valgrind option in the menuconfig ($petalinux-config)
Has anyone succeeded in doing so?
Thanx
Re: valgrind on Petalinux 2017.1
Hi @amatsaka
Try adding valgrind in project-spec/meta-user/recipes-core/images/petalinux-image.bbappend
And then select this user package from petalinux-config -c rootfs, and build
You will be able to see valgrind upon boot
Hi @amatsaka
Thanks @shabbirk
It worked!
so to get better understanding, does the valgrind comes with petalinux and only needs to be enabled through petalinux-image.bbappend and  /build/conf/local.conf  in order to build it and be available at the target system?
Or needs to be installed in the host PC and petalinux includes it in the image (after enabling it as above)?
