varun_shah Posts: 12 Registered: ‎03-25-2014 0 linux karnal uImage problam cant synchronize with .dtb file
I am using zynq ZC703 and i make a u-boot.elf ,Uimage and system.dts file.
1> i made a u-boot.elf file by following command
make zynq_zc70x_config
make all
cp u-boot u-boot.elf
2> i made a vivardo project and made export hardwear in SDK
in SDK Xilinx Toos-> Repositories i add device-tree-xlnx- (downloaded from git hub)
after that File->New->Board Support package i make devicetree system.dts file
i made system.dtb file by
dtc -I dts -O dtb -o system.dtb system.dts
3>i downloaded linux-xlnx from git hub and make uImage by
make ARCH=arm UIMAGE_LOADADDR=0x8000 uImage
bui i thing system.dts and uImage are not synchronize so i change uImage ,turned off the fixed device tree address in the kernel configuration by make ARCH=arm menuconfig
System Type->Xilinx Specific Features -> Device Tree At Fixed Address
But  terminal output is in attachment pls check that one
You seem to use an ancient version of Linux. I think it is too old to have any version of DTG working with it.
In general, you should update and you should probably take a look at Petalinux.
