where is the original linux kernel source located for petalinux (2017.3 or later) (not the build/tmp one) ?
I have simple question,
where is the linux kernel source code located on the disk after the installation of petalinux tool ? ( aka the exact source code from which the petalinux-build build kernel image )
I need to have access to the exact linux kernel code that was built for the image that was generated (even if I cannot build the code if it was edited).
I have searched a lot pages, seems (as I sees) the whole community is avoiding answering this question :(
The engineers either tells the output source code after build ( seems this sould be called dest code :p ) :
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-where-can-I-find-the-kernel-sources-in-a-Petalinux/td-p/811189
https://forums.xilinx.com/t5/Embedded-Linux/where-is-the-kernel-source-code-located-in-Petalinux2016-4/td-p/877589
or give the xilinx git repo:
https://forums.xilinx.com/t5/Embedded-Linux/Source-code-of-Petalinux-kernel/td-p/419449
or outdated location( $petalinux/components/linux-kernel)
or tells to do task in another way:
https://forums.xilinx.com/t5/Embedded-Linux/Making-changes-in-kernel-source-files/td-p/820424
https://forums.xilinx.com/t5/Embedded-Linux/Locating-uboot-amp-Linux-kernel-source-code-for-zc706-board/td-p/870124
or give tons of documents:
https://forums.xilinx.com/t5/Embedded-Linux/Where-is-the-correct-place-to-modify-source-of-the-Petalinux/td-p/724744
or directly ignores the question:
https://forums.xilinx.com/t5/Embedded-Linux/How-to-get-kernel-source-code-from-a-project-of-petalinux-2017-4/td-p/856187
I have searched the $petalinux directory, but seems the keyword "kernel" and "linux" does not filter out the kernel source.
I have filtered .c file but seems the kernel was not flattened into files.
I have filtered .gz and .zip and .7z files but with no luck.
So please tell where is the source code of the used kernel before running petalinux-build ?
Kang
Re: where is the original linux kernel source located for petalinux (2017.3 or later) (not the build/tmp one) ?
Hi @hu_kang,
I think you are asking where is the kernel source before the build. To answer to your question.
In Yocto/PetaLinux kernel source are fetched from recipes(using do_fetch task)
For 2017.3 release kernel commit id in github is https://github.com/xilinx/linux-xlnx/tree/xilinx-v2017.3 (https://github.com/Xilinx/linux-xlnx/commit/f1b1e077d641fc83b54c1b8f168cbb58044fbd4e)
and this commit id is wired up in kernel recipes
https://github.com/Xilinx/meta-xilinx/blob/rel-v2017.3/recipes-kernel/linux/linux-xlnx_4.9.bb#L3
Once you run petalinux-build then you can verify in logs from which location kernel sources are fetched.
The log file you need to check is
<plnx-proj-root>/build/tmp/work/plnx_aarch64-xilinx-linux/linux-xlnx/4.9-xilinx-v2017.3+gitAUTOINC+f1b1e077d6-r0/temp/log.do_fetch
If you look closely in log 4.9-xilinx-v2017.3+gitAUTOINC+f1b1e077d6-r0 this represents first 10 digit git commit id which matches above recipes.
Sandeep
Can you try <TMP DIR>/work-shared/plnx_aarch64/kernel_source?
TMP DIR can be found in petalinux-config -> yocto settings -> TMPDIR
Hi, @stephenm
I know I can find the source code there, but isn't it the output after the petalinux-build command ?
but where is the origin of  this source code ( aka before executing petalinux-build )?
I need the most original one which is untouched and uncopied from anywhere after the installation of petalinux tool.
Please note the difference.
I'm not looking for the $TMPDIR and anything in it. I know where to find the $TMPDIR.
Kang
Hi @hu_kang,
Sandeep
hi @sandeepg
I think this is the answer.
In fact I have already found the compressed git repository under
$petalinux/components/yocto/downloads/git2_github.com.Xilinx.linux-xlnx.git.tar.gz ,
by cloning it, I can checkout any version of commits now.
Kang
