zcu102 + GPU +PCIe
I have been trying to add a GPU card to the PCIe slot present in the zcu102.
I have built the nvidia.ko in the board and I am running Ubuntu created with the latest petalinux tools 2018.1.
When I try to insert the driver using insmod I get :
[ 3259.872635] NVRM: Can't find an IRQ for your NVIDIA card!
[ 3259.872636] NVRM: Please check your BIOS settings.
[ 3259.872637] NVRM: [Plug & Play OS] should be set to NO
[ 3259.872637] NVRM: [Assign IRQ to VGA] should be set to YES
[ 3259.872638] nvidia: probe of 0000:01:00.0 failed with error -1
[ 3259.872640] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 3259.872641] NVRM: None of the NVIDIA graphics adapters were initialized!
[ 3259.872643] NVRM: NVIDIA init module failed!
I was wondering if anybody had any suggestions for this ?
Re: zcu102 + GPU +PCIe
Looking at the driver code it looks like that the error message happens after the call:
pci_enable_device (dev)
The dev->irq after this call is set to 0 so then the message "can't get irq for card"
Since this is pci_enable_device is part of the Linux kernel should not assign some resources ?
lspci -v seems to be detecting the card correctly as it can be seen below  (there is a irq 53 Is this the same interrupt that should be collected by pci_enable_device ? )
Overall it looks like what I am trying to do is impossible but it would have been interesting to understand a bit better the problem.
01:00.0 VGA compatible controller: NVIDIA Corporation GK104 [GeForce GTX 680] (rev a1) (prog-if 00 [VGA controller])
Subsystem: eVga.com. Corp. GK104 [GeForce GTX 680]
Flags: fast devsel, IRQ 53
Memory at e0000000 (32-bit, non-prefetchable) [size=16M]
Memory at 600000000 (64-bit, prefetchable) [size=128M]
Memory at 608000000 (64-bit, prefetchable) [size=32M]
I/O ports at <unassigned> [disabled]
[virtual] Expansion ROM at e1000000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
