Observer shyamthella
zcu102 Modify rootfs when using OSL boot flow
Hey All,
I have been using Xilinx ZCU102 platform with Linux running on it. Compilation is as mentioned in the following page https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841722/ZCU102+Image+creation+in+OSL+flow.
I could use armramdisk.image.gz and boot up Linux till command prompt using prebuilt ramdisk image. Followed this page for it:https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842473/Build+and+Modify+a+Rootfs
Now if I want to add an executable or file into this ramdisk image, I followed stepes mentioned in the same link but after boot I couldnt execute my executable file added to ramdisk image.
Can someone tell me how do we add custom apps to prebuilt ramdisk for ZCU102?
Surprisingly few years ago I followed the same steps for modifying ramdisk for Zynq7000 and I could successfully do that. What could be different when it comes to ZCU102?
Shyam
Re: zcu102 Modify rootfs when using OSL boot flow
Hi @stephenm
Thanks for the help but I actually followed the link you suggested.
There was a typpo in my description nd I edited that now.
Even after followign that procedure when I am executing the application, it is not able to execute it.
Shyam
Can you post your boot log?
Xilinx Zynq MP First Stage Boot Loader
Release 2018.3 May 28 2019 - 22:52:24
NOTICE: ATF running on XCZU9EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v1.5(release):xilinx-v2018.3
NOTICE: BL31: Built : 18:20:48, Apr 1 2019
PMUFW: v1.1
U-Boot 2019.01-07032-g6cb094f-dirty (Jul 04 2019 - 21:27:26 +0530)
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
DRAM: 4 GiB
EL Level: EL2
Chip ID: zu9eg
MMC: mmc@ff170000: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Bootmode: LVL_SHFT_SD_MODE1
Reset reason: EXTERNAL
Net: ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
Warning: ethernet@ff0e0000 using MAC address from ROM
eth0: ethernet@ff0e0000
Loading Boot image to RAM:
22872520 bytes read in 1507 ms (14.5 MiB/s)
## Loading kernel from FIT Image at 03000000 ...
Using 'conf@1' configuration
Trying 'kernel@0' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x030000d8
Data Size: 16531968 Bytes = 15.8 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: 6db30616f03a7ed563b36365e88b1b3f77f667dd
## Loading ramdisk from FIT Image at 03000000 ...
Trying 'ramdisk@0' ramdisk subimage
Description: ramdisk
Type: RAMDisk Image
Compression: gzip compressed
Data Start: 0x03fce948
Data Size: 6296189 Bytes = 6 MiB
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: c054d36e32b9ad8c026c70a2bd8b88d7c9b96507
## Loading fdt from FIT Image at 03000000 ...
Trying 'fdt@0' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x03fc43d0
Data Size: 42179 Bytes = 41.2 KiB
Hash algo: sha1
Hash value: 2ec3239475ea48b0efdbdf17fcaf667ca36e46eb
Booting using the fdt blob at 0x3fc43d0
Loading Kernel Image ... OK
Loading Ramdisk to 0f9fe000, end 0ffff27d ... OK
Loading Device Tree to 000000000f9f0000, end 000000000f9fd4c2 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 4.19.0-54688-g80f1201281f0-dirty (vconnect@vconnect-H81M-S) (gcc version 7.3.1 20180314 (Linaro GCC 7.3-2018.04-rc3)) #13 SMP Fri Jul 5 20:44:54 IST 2019
[ 0.000000] Machine model: ZynqMP ZCU102 Rev1.0
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000040000000, size 512 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] random: get_random_bytes called from start_kernel+0xa8/0x41c with crng_init=0
[ 0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52504 r8192 d29416 u90112
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240
[ 0.000000] Kernel command line: root=/dev/ram0 rw console=ttyPS0,115200n8 earlycon clk_ignore_unused cpuidle.off=1
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB: mapped [mem 0x7bfff000-0x7ffff000] (64MB)
[ 0.000000] Memory: 3516984K/4194304K available (11260K kernel code, 656K rwdata, 3368K rodata, 832K init, 317K bss, 153032K reserved, 524288K cma-reserved)
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 99.99MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x170f8de2d3, max_idle_ns: 440795206112 ns
[ 0.000003] sched_clock: 56 bits at 99MHz, resolution 10ns, wraps every 4398046511101ns
[ 0.008267] Console: colour dummy device 80x25
[ 0.012391] Calibrating delay loop (skipped), value calculated using timer frequency.. 199.98 BogoMIPS (lpj=399960)
[ 0.022756] pid_max: default: 32768 minimum: 301
[ 0.027452] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.034012] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.041799] ASID allocator initialised with 32768 entries
[ 0.046508] rcu: Hierarchical SRCU implementation.
[ 0.051553] EFI services will not be available.
[ 0.055829] smp: Bringing up secondary CPUs ...
[ 0.060488] Detected VIPT I-cache on CPU1
[ 0.060518] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.060822] Detected VIPT I-cache on CPU2
[ 0.060842] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.061129] Detected VIPT I-cache on CPU3
[ 0.061148] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.061191] smp: Brought up 1 node, 4 CPUs
[ 0.095682] SMP: Total of 4 processors activated.
[ 0.100355] CPU features: detected: 32-bit EL0 Support
[ 0.106763] CPU: All CPU(s) started at EL2
[ 0.109535] alternatives: patching kernel code
[ 0.114840] devtmpfs: initialized
[ 0.122454] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.126921] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.143831] xor: measuring software checksum speed
[ 0.181152] 8regs : 2303.000 MB/sec
[ 0.221180] 8regs_prefetch: 2052.000 MB/sec
[ 0.261212] 32regs : 2831.000 MB/sec
[ 0.301242] 32regs_prefetch: 2379.000 MB/sec
[ 0.301271] xor: using function: 32regs (2831.000 MB/sec)
[ 0.305585] pinctrl core: initialized pinctrl subsystem
[ 0.311388] NET: Registered protocol family 16
[ 0.315482] audit: initializing netlink subsys (disabled)
[ 0.320612] audit: type=2000 audit(0.272:1): state=initialized audit_enabled=0 res=1
[ 0.328245] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[ 0.328249] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.343010] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.362286] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.430965] raid6: int64x1 gen() 446 MB/s
[ 0.498983] raid6: int64x1 xor() 438 MB/s
[ 0.566990] raid6: int64x2 gen() 679 MB/s
[ 0.635040] raid6: int64x2 xor() 601 MB/s
[ 0.703073] raid6: int64x4 gen() 1039 MB/s
[ 0.771143] raid6: int64x4 xor() 763 MB/s
[ 0.839159] raid6: int64x8 gen() 981 MB/s
[ 0.907238] raid6: int64x8 xor() 750 MB/s
[ 0.975252] raid6: neonx1 gen() 724 MB/s
[ 1.043316] raid6: neonx1 xor() 846 MB/s
[ 1.111344] raid6: neonx2 gen() 1161 MB/s
[ 1.179400] raid6: neonx2 xor() 1201 MB/s
[ 1.247447] raid6: neonx4 gen() 1510 MB/s
[ 1.315495] raid6: neonx4 xor() 1437 MB/s
[ 1.383558] raid6: neonx8 gen() 1665 MB/s
[ 1.451575] raid6: neonx8 xor() 1531 MB/s
[ 1.451602] raid6: using algorithm neonx8 gen() 1665 MB/s
[ 1.455571] raid6: .... xor() 1531 MB/s, rmw enabled
[ 1.460503] raid6: using neon recovery algorithm
[ 1.465487] ACPI: Interpreter disabled.
[ 1.469225] SCSI subsystem initialized
[ 1.472783] usbcore: registered new interface driver usbfs
[ 1.478095] usbcore: registered new interface driver hub
[ 1.483374] usbcore: registered new device driver usb
[ 1.488432] media: Linux media interface: v0.10
[ 1.492882] videodev: Linux video capture interface: v2.00
[ 1.498329] pps_core: LinuxPPS API ver. 1 registered
[ 1.503239] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.512331] PTP clock support registered
[ 1.516229] EDAC MC: Ver: 3.0.0
[ 1.519734] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[ 1.526807] FPGA manager framework
[ 1.530141] Advanced Linux Sound Architecture Driver Initialized.
[ 1.536364] Bluetooth: Core ver 2.22
[ 1.539586] NET: Registered protocol family 31
[ 1.543985] Bluetooth: HCI device and connection manager initialized
[ 1.550302] Bluetooth: HCI socket layer initialized
[ 1.555146] Bluetooth: L2CAP socket layer initialized
[ 1.560176] Bluetooth: SCO socket layer initialized
[ 1.565410] clocksource: Switched to clocksource arch_sys_counter
[ 1.571161] VFS: Disk quotas dquot_6.6.0
[ 1.574993] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.581865] pnp: PnP ACPI: disabled
[ 1.591608] NET: Registered protocol family 2
[ 1.592015] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes)
[ 1.598157] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.605549] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.612264] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.618416] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.624395] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.630880] NET: Registered protocol family 1
[ 1.635307] RPC: Registered named UNIX socket transport module.
[ 1.640938] RPC: Registered udp transport module.
[ 1.645608] RPC: Registered tcp transport module.
[ 1.650277] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.657049] Trying to unpack rootfs image as initramfs...
[ 1.662403] rootfs image is not initramfs (no cpio magic); looks like an initrd
[ 1.677741] Freeing initrd memory: 6148K
[ 1.678181] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.683289] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.691789] Initialise system trusted keyrings
[ 1.695310] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 1.702344] NFS: Registering the id_resolver key type
[ 1.706669] Key type id_resolver registered
[ 1.710809] Key type id_legacy registered
[ 1.714793] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.721460] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 2.803189] NET: Registered protocol family 38
[ 2.862508] Key type asymmetric registered
[ 2.862535] Asymmetric key parser 'x509' registered
[ 2.865845] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 2.873167] io scheduler noop registered
[ 2.877057] io scheduler deadline registered
[ 2.881315] io scheduler cfq registered (default)
[ 2.885969] io scheduler mq-deadline registered
[ 2.890466] io scheduler kyber registered
[ 2.929569] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.934047] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 2.940719] brd: module loaded
[ 2.944623] loop: module loaded
[ 2.945513] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 2.950190] libphy: Fixed MDIO Bus: probed
[ 2.954134] tun: Universal TUN/TAP device driver, 1.6
[ 2.958079] CAN device driver interface
[ 2.962780] usbcore: registered new interface driver asix
[ 2.967202] usbcore: registered new interface driver ax88179_178a
[ 2.973209] usbcore: registered new interface driver cdc_ether
[ 2.979005] usbcore: registered new interface driver net1080
[ 2.984628] usbcore: registered new interface driver cdc_subset
[ 2.990514] usbcore: registered new interface driver zaurus
[ 2.996058] usbcore: registered new interface driver cdc_ncm
[ 3.002467] usbcore: registered new interface driver uas
[ 3.006957] usbcore: registered new interface driver usb-storage
[ 3.014131] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 3.020134] i2c /dev entries driver
[ 3.025327] usbcore: registered new interface driver uvcvideo
[ 3.029244] USB Video Class driver (1.1.1)
[ 3.033804] Bluetooth: HCI UART driver ver 2.3
[ 3.037726] Bluetooth: HCI UART protocol H4 registered
[ 3.042829] Bluetooth: HCI UART protocol BCSP registered
[ 3.048123] Bluetooth: HCI UART protocol LL registered
[ 3.053206] Bluetooth: HCI UART protocol ATH3K registered
[ 3.058586] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 3.064841] Bluetooth: HCI UART protocol Intel registered
[ 3.070182] Bluetooth: HCI UART protocol QCA registered
[ 3.075382] usbcore: registered new interface driver bcm203x
[ 3.081001] usbcore: registered new interface driver bpa10x
[ 3.086539] usbcore: registered new interface driver bfusb
[ 3.091990] usbcore: registered new interface driver btusb
[ 3.097412] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 3.103078] usbcore: registered new interface driver ath3k
[ 3.108610] EDAC MC: ECC not enabled
[ 3.112277] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 3.124635] sdhci: Secure Digital Host Controller Interface driver
[ 3.130286] sdhci: Copyright(c) Pierre Ossman
[ 3.134609] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.140576] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.146247] zynqmp_firmware_probe Platform Management API v1.1
[ 3.152001] zynqmp_firmware_probe Trustzone version v1.0
[ 3.158184] reset_zynqmp firmware:zynqmp-firmware:reset-controller: Xilinx zynqmp reset driver probed
[ 3.168356] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[ 3.195774] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[ 3.195821] zynqmp_aes zynqmp_aes: AES Successfully Registered
[ 3.195821]
[ 3.203241] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[ 3.209367] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[ 3.214962] usbcore: registered new interface driver usbhid
[ 3.220277] usbhid: USB HID core driver
[ 3.226399] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 3.230863] usbcore: registered new interface driver snd-usb-audio
[ 3.237572] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 3.244521] Initializing XFRM netlink socket
[ 3.248472] NET: Registered protocol family 10
[ 3.253155] Segment Routing with IPv6
[ 3.256523] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.262645] NET: Registered protocol family 17
[ 3.266738] NET: Registered protocol family 15
[ 3.271152] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.284069] can: controller area network core (rev 20170425 abi 9)
[ 3.290199] NET: Registered protocol family 29
[ 3.294584] can: raw protocol (rev 20170425)
[ 3.298821] can: broadcast manager protocol (rev 20170425 t)
[ 3.304448] can: netlink gateway (rev 20170425) max_hops=1
[ 3.309954] Bluetooth: RFCOMM TTY layer initialized
[ 3.314746] Bluetooth: RFCOMM socket layer initialized
[ 3.319852] Bluetooth: RFCOMM ver 1.11
[ 3.323567] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.328840] Bluetooth: BNEP filters: protocol multicast
[ 3.334033] Bluetooth: BNEP socket layer initialized
[ 3.338961] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.344846] Bluetooth: HIDP socket layer initialized
[ 3.349899] 9pnet: Installing 9P2000 support
[ 3.354029] Key type dns_resolver registered
[ 3.358700] registered taskstats version 1
[ 3.362325] Loading compiled-in X.509 certificates
[ 3.367420] Btrfs loaded, crc32c=crc32c-generic
[ 3.377736] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 39, base_o 锟絩锟铰诧拷锟斤拷console [ttyPS0] enabled
[ 3.386688] console [ttyPS0] enabled
[ 3.390276] bootconsole [cdns0] disabled
[ 3.398326] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 40, base_baud = 6249999) is a xuartps
[ 3.411685] of-fpga-region fpga-full: FPGA Region probed
[ 3.417577] nwl-pcie fd0e0000.pcie: Link is DOWN
[ 3.422221] nwl-pcie fd0e0000.pcie: host bridge /amba/pcie@fd0e0000 ranges:
[ 3.429189] nwl-pcie fd0e0000.pcie: MEM 0xe0000000..0xefffffff -> 0xe0000000
[ 3.436411] nwl-pcie fd0e0000.pcie: MEM 0x600000000..0x7ffffffff -> 0x600000000
[ 3.443996] nwl-pcie fd0e0000.pcie: PCI host bridge to bus 0000:00
[ 3.450172] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 3.455653] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xefffffff]
[ 3.462519] pci_bus 0000:00: root bus resource [mem 0x600000000-0x7ffffffff pref]
[ 3.474774] pci 0000:00:00.0: PCI bridge to [bus 01-0c]
[ 3.480519] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[ 3.487101] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 3.494204] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 3.501308] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 3.508416] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 3.515515] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 3.522616] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 3.529717] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 3.536818] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 3.544055] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[ 3.554045] zynqmp_clk_divider_set_rate() set divider failed for pl1_ref_div1, ret = -13
[ 3.562554] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[ 3.573249] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[ 3.581303] xilinx-dp-snd-pcm zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[ 3.589938] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 3.602383] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 3.615074] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[ 3.625260] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[ 3.632271] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.638880] [drm] No driver support for vblank timestamp query.
[ 3.644853] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008c43558)
[ 4.729397] [drm] Cannot find any crtc or sizes
[ 4.734138] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[ 4.742245] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[ 4.751207] xilinx-psgtr fd400000.zynqmp_phy: Lane:3 type:3 protocol:2 pll_locked:yes
[ 4.759093] ahci-ceva fd0c0000.ahci: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl platform mode
[ 4.768046] ahci-ceva fd0c0000.ahci: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 4.778470] scsi host0: ahci-ceva
[ 4.782033] scsi host1: ahci-ceva
[ 4.785488] ata1: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x100 irq 37
[ 4.793401] ata2: SATA max UDMA/133 mmio [mem 0xfd0c0000-0xfd0c1fff] port 0x180 irq 37
[ 4.802028] m25p80 spi0.0: found n25q512a, expected m25p80
[ 4.807924] m25p80 spi0.0: n25q512a (131072 Kbytes)
[ 4.812819] 4 fixed-partitions partitions found on MTD device spi0.0
[ 4.819164] Creating 4 MTD partitions on "spi0.0":
[ 4.823949] 0x000000000000-0x000000100000 : "qspi-fsbl-uboot"
[ 4.830161] 0x000000100000-0x000000600000 : "qspi-linux"
[ 4.835868] 0x000000600000-0x000000620000 : "qspi-device-tree"
[ 4.842085] 0x000000620000-0x000002e20000 : "qspi-rootfs"
[ 4.849876] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 4.857241] libphy: MACB_mii_bus: probed
[ 4.861777] macb ff0e0000.ethernet eth0: Cadence GEM rev 0x50070106 at 0xff0e0000 irq 22 (08:c3:98:2f:b9:b1)
[ 4.871601] TI DP83867 ff0e0000.ethernet-ffffffff:0c: attached PHY driver [TI DP83867] (mii_bus:phy_addr=ff0e0000.ethernet-ffffffff:0c, irq=POLL)
[ 4.884936] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 4.891482] xilinx-axipmon fd0b0000.perf-monitor: Probed Xilinx APM
[ 4.897977] xilinx-axipmon fd490000.perf-monitor: Probed Xilinx APM
[ 4.904465] xilinx-axipmon ffa10000.perf-monitor: Probed Xilinx APM
[ 4.912210] dwc3 fe200000.dwc3: Failed to get clk 'ref': -2
[ 4.918055] xilinx-psgtr fd400000.zynqmp_phy: Lane:2 type:0 protocol:3 pll_locked:yes
[ 4.926128] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.931621] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 4.939604] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x0000000202010810
[ 4.949012] xhci-hcd xhci-hcd.0.auto: irq 55, io mem 0xfe200000
[ 4.955138] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 4.963402] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.970619] usb usb1: Product: xHCI Host Controller
[ 4.975490] usb usb1: Manufacturer: Linux 4.19.0-54688-g80f1201281f0-dirty xhci-hcd
[ 4.983137] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 4.988293] hub 1-0:1.0: USB hub found
[ 4.992058] hub 1-0:1.0: 1 port detected
[ 4.996169] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 5.001657] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 5.009317] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 5.016048] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[ 5.024309] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.031525] usb usb2: Product: xHCI Host Controller
[ 5.036394] usb usb2: Manufacturer: Linux 4.19.0-54688-g80f1201281f0-dirty xhci-hcd
[ 5.044042] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 5.049162] hub 2-0:1.0: USB hub found
[ 5.052928] hub 2-0:1.0: 1 port detected
[ 5.058035] pca953x 0-0020: 0-0020 supply vcc not found, using dummy regulator
[ 5.065280] pca953x 0-0020: Linked as a consumer to regulator.0
[ 5.072032] GPIO line 496 (sel0) hogged as output/low
[ 5.077420] GPIO line 497 (sel1) hogged as output/high
[ 5.082885] GPIO line 498 (sel2) hogged as output/high
[ 5.088356] GPIO line 499 (sel3) hogged as output/high
[ 5.093700] pca953x 0-0021: 0-0021 supply vcc not found, using dummy regulator
[ 5.100949] pca953x 0-0021: Linked as a consumer to regulator.0
[ 5.108267] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.115064] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.115571] ata1: SATA link down (SStatus 0 SControl 330)
[ 5.121857] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.126859] ata2: SATA link down (SStatus 0 SControl 330)
[ 5.133600] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.145335] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.152130] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.158916] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.165713] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.172502] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.179291] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.185668] i2c i2c-0: Added multiplexed i2c bus 3
[ 5.191086] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[ 5.197883] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.204668] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.211460] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.218249] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.225036] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.231824] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.238616] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[ 5.244993] i2c i2c-0: Added multiplexed i2c bus 4
[ 5.265509] random: fast init done
[ 5.286884] i2c i2c-0: Added multiplexed i2c bus 5
[ 5.291810] i2c i2c-0: Added multiplexed i2c bus 6
[ 5.296598] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[ 5.303922] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 24
[ 5.311625] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[ 5.318353] i2c i2c-1: Added multiplexed i2c bus 7
[ 5.323349] i2c i2c-1: Added multiplexed i2c bus 8
[ 5.330237] si570 9-005d: registered, current frequency 300000000 Hz
[ 5.336619] i2c i2c-1: Added multiplexed i2c bus 9
[ 5.355418] si570 10-005d: registered, current frequency 148500000 Hz
[ 5.361883] i2c i2c-1: Added multiplexed i2c bus 10
[ 5.366965] si5324 11-0069: si5328 probed
[ 5.429421] si5324 11-0069: si5328 probe successful
[ 5.434321] i2c i2c-1: Added multiplexed i2c bus 11
[ 5.439399] si5324 12-0068: si5324 probed
[ 5.497440] si5324 12-0068: unable to read from reg00
[ 5.503874] si5324 12-0068: si5324 probe successful
[ 5.508781] i2c i2c-1: Added multiplexed i2c bus 12
[ 5.513780] i2c i2c-1: Added multiplexed i2c bus 13
[ 5.518775] i2c i2c-1: Added multiplexed i2c bus 14
[ 5.523646] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[ 5.531559] i2c i2c-1: Added multiplexed i2c bus 15
[ 5.536562] i2c i2c-1: Added multiplexed i2c bus 16
[ 5.541559] i2c i2c-1: Added multiplexed i2c bus 17
[ 5.546559] i2c i2c-1: Added multiplexed i2c bus 18
[ 5.551559] i2c i2c-1: Added multiplexed i2c bus 19
[ 5.556559] i2c i2c-1: Added multiplexed i2c bus 20
[ 5.561566] i2c i2c-1: Added multiplexed i2c bus 21
[ 5.566574] i2c i2c-1: Added multiplexed i2c bus 22
[ 5.571450] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[ 5.579036] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 25
[ 5.585415] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at (____ptrval____) with timeout 60s
[ 5.626849] mmc0: SDHCI controller on ff170000.mmc [ff170000.mmc] using ADMA 64-bit
[ 5.642811] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 5.649832] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-06-17 23:39:17 UTC (1560814757)
[ 5.658706] of_cfs_init
[ 5.661156] of_cfs_init: OK
[ 5.664079] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.710971] mmc0: new high speed SDHC card at address aaaa
[ 5.716947] mmcblk0: mmc0:aaaa SL16G 14.8 GiB
[ 5.726657] mmcblk0: p1
[ 5.802117] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.808640] clk: Not disabling unused clocks
[ 5.812909] ALSA device list:
[ 5.815865] #0: DisplayPort monitor
[ 5.819843] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.828451] cfg80211: failed to load regulatory.db
[ 5.833341] RAMDISK: gzip image found at block 0
[ 5.885406] [drm] Cannot find any crtc or sizes
[ 6.120174] EXT4-fs (ram0): mounted filesystem without journal. Opts: (null)
[ 6.127252] VFS: Mounted root (ext4 filesystem) on device 1:0.
[ 6.133284] devtmpfs: mounted
[ 6.136427] Freeing unused kernel memory: 832K
[ 6.145470] Run /sbin/init as init process
Starting rcS...
++ Mounting filesystem
[ 6.168398] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
++ Setting up mdev
++ Starting telnet daemon
++ Starting http daemon
++ Starting ftp daemon
++ Starting ssh daemon
[ 6.371330] random: sshd: uninitialized urandom read (32 bytes read)
rcS Complete
zynq> pwd
zynq> cd /usr/bin
zynq> chmod 777 MyApp
zynq> chmod 666 MyApp
zynq> chmod 755 MyApp
zynq> ls -l
total 6065
-rwxr-xr-x 1 root root 3431640 Jul 25 2019 MyApp
lrwxrwxrwx 1 root root 17 Nov 27 2012 [ -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 [[ -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 add-shell -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 ar -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 arping -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 awk -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 basename -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 bunzip2 -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 bzcat -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 bzip2 -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 cal -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 chat -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 chpst -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 chrt -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 chvt -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 cksum -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 clear -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 cmp -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 comm -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 crontab -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 cryptpw -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 cut -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 dc -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 deallocvt -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 diff -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 dirname -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 dos2unix -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 du -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 dumpleases -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 env -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 envdir -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 envuidgid -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 ether-wake -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 expand -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 expr -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 fdformat -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 fgconsole -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 find -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 flock -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 fold -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 free -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 ftpget -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 ftpput -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 fuser -> ../../bin/busybox
-rwxr-xr-x 1 root root 177900 Nov 27 2012 gdbserver
lrwxrwxrwx 1 root root 17 Nov 27 2012 groups -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 hd -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 head -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 hexdump -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 hostid -> ../../bin/busybox
-rwxr-xr-x 1 root root 11288 Nov 27 2012 i2cdetect
-rwxr-xr-x 1 root root 14092 Nov 27 2012 i2cdump
-rwxr-xr-x 1 root root 11096 Nov 27 2012 i2cget
-rwxr-xr-x 1 root root 13100 Nov 27 2012 i2cset
lrwxrwxrwx 1 root root 17 Nov 27 2012 id -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 ifplugd -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 install -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 ipcrm -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 ipcs -> ../../bin/busybox
-rwxr-xr-x 1 root root 48060 Nov 27 2012 iperf
lrwxrwxrwx 1 root root 17 Nov 27 2012 kbd_mode -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 killall -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 killall5 -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 last -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 less -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 logger -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 logname -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 lsof -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 lspci -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 lsusb -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 lzcat -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 lzma -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 lzopcat -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 md5sum -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 mesg -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 microcom -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 mkfifo -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 mkpasswd -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 nc -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 nmeter -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 nohup -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 nslookup -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 od -> ../../bin/busybox
-rwxr-xr-x 1 root root 314516 Nov 27 2012 opannotate
-rwxr-xr-x 1 root root 240640 Nov 27 2012 oparchive
-rwxr-xr-x 1 root root 51646 Nov 27 2012 opcontrol
lrwxrwxrwx 1 root root 17 Nov 27 2012 openvt -> ../../bin/busybox
-rwxr-xr-x 1 root root 277568 Nov 27 2012 opgprof
-rwxr-xr-x 1 root root 36448 Nov 27 2012 ophelp
-rwxr-xr-x 1 root root 25356 Nov 27 2012 opjitconv
-rwxr-xr-x 1 root root 380896 Nov 27 2012 opreport
-rwxr-xr-x 1 root root 81812 Nov 27 2012 oprofiled
lrwxrwxrwx 1 root root 17 Nov 27 2012 passwd -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 patch -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 pgrep -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 pkill -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 pmap -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 printf -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 pscan -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 pstree -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 pwdx -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 readahead -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 readlink -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 realpath -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 remove-shell -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 renice -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 reset -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 resize -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 rpm2cpio -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 rtcwake -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 runsv -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 runsvdir -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 rx -> ../../bin/busybox
-rwxr-xr-x 1 root root 53252 Nov 27 2012 scp
lrwxrwxrwx 1 root root 17 Nov 27 2012 script -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 seq -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 setkeycodes -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 setsid -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 setuidgid -> ../../bin/busybox
-rwxr-xr-x 1 root root 88332 Nov 27 2012 sftp
lrwxrwxrwx 1 root root 17 Nov 27 2012 sha1sum -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 sha256sum -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 sha512sum -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 showkey -> ../../bin/busybox
lrwxrwxrwx 1 root root 5 Nov 27 2012 slogin -> ./ssh
lrwxrwxrwx 1 root root 17 Nov 27 2012 smemcap -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 softlimit -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 sort -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 split -> ../../bin/busybox
-rwxr-xr-x 1 root root 330048 Nov 27 2012 ssh
-rwxr-xr-x 1 root root 117868 Nov 27 2012 ssh-add
-rwxr-xr-x 1 root root 101720 Nov 27 2012 ssh-agent
-rwxr-xr-x 1 root root 157536 Nov 27 2012 ssh-keygen
-rwxr-xr-x 1 root root 191976 Nov 27 2012 ssh-keyscan
lrwxrwxrwx 1 root root 17 Nov 27 2012 strings -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 sum -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 sv -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 tac -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 tail -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 taskset -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 tcpsvd -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 tee -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 telnet -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 test -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 tftp -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 tftpd -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 time -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 timeout -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 top -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 tr -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 traceroute -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 traceroute6 -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 tty -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 ttysize -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 udpsvd -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 unexpand -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 uniq -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 unix2dos -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 unlzma -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 unlzop -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 unxz -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 unzip -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 uptime -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 users -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 uudecode -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 uuencode -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 vlock -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 wall -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 wc -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 wget -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 which -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 who -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 whoami -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 whois -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 xargs -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 xz -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 xzcat -> ../../bin/busybox
lrwxrwxrwx 1 root root 17 Nov 27 2012 yes -> ../../bin/busybox
zynq> ./MyApp
-/bin/ash: ./MyApp: not found
zynq
My application is present in Rootfs but could not execute it. It says no such file or directory.
@stephenmCould you please suggest me where I am wrong by looking a logs. Or point me to a procedure where we can use RFS and add applications into the RFS and boot on ZCU102 board.
Shyam
