Visitor loving33520-
zcu104 can not find mmcblk0 in /dev
My vivado project is :
Xilinx Zynq MP First Stage Boot Loader
Release 2018.1 Jan 10 2019 - 06:56:33
NOTICE: ATF running on XCZU7EV/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v1.4(release):xilinx-v2017.4-1351-gdf4a7e97
NOTICE: BL31: Built : 14:54:16, Jan 10 2019
PMUFW: v1.0
U-Boot 2018.01 (Jan 10 2019 - 06:52:19 -0800) Xilinx ZynqMP ZCU102 rev1.0
I2C: ready
DRAM: 4 GiB
usb dr_mode not found
EL Level: EL2
Chip ID: zu7ev
MMC: sdhci@ff170000: 0 (SD)
SF: Detected n25q512a with page size 256 Bytes, erase size 64 KiB, total 64 MiB
## Error: flags type check failure for "serverip" <= "AUTO" (type: i)
himport_r: can't insert "serverip=AUTO" into hash table
In: serial@ff000000
Out: serial@ff000000
Err: serial@ff000000
Board: Xilinx ZynqMP
Bootmode: LVL_SHFT_SD_MODE1
Net: ZYNQ GEM: ff0e0000, phyaddr ffffffff, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for zcu104gpioram
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT !
Device: sdhci@ff170000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
13352492 bytes read in 957 ms (13.3 MiB/s)
Using 'conf@system-top.dtb' configuration
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x10000104
Data Size: 6900665 Bytes = 6.6 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00080000
Entry Point: 0x00080000
Hash algo: sha1
Hash value: 9428d9f9443f8da5a39f407f1a93bbd9b41e0233
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-user-image
Type: RAMDisk Image
Data Start: 0x1069cd6c
Data Size: 6417200 Bytes = 6.1 MiB
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 84a9380cb18c1a20b2dabef8b5bc588d0ca1a2d5
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x10694dc4
Data Size: 32483 Bytes = 31.7 KiB
Hash algo: sha1
Hash value: cbf99711b6a37793a409622aeee9da2649d2e3ff
Booting using the fdt blob at 0x10694dc4
Uncompressing Kernel Image ... OK
Loading Ramdisk to 079e1000, end 07fffb30 ... OK
Loading Device Tree to 00000000079d6000, end 00000000079e0ee2 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.0-xilinx-v2018.1 (oe-user@oe-host) (gcc version 7.2.0 (GCC)) #1 SMP Thu Jan 10 05:18:40 PST 2019
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] Machine model: xlnx,zynqmp
[ 0.000000] earlycon: cdns0 at MMIO 0x00000000ff000000 (options '115200n8')
[ 0.000000] bootconsole [cdns0] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: fdt: Reserved memory: unsupported node format, ignoring
[ 0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] percpu: Embedded 21 pages/cpu @ffffffc87ff78000 s46488 r8192 d31336 u86016
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: enabling workaround for ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1034240
[ 0.000000] Kernel command line: earlycon clk_ignore_unused
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] software IO TLB [mem 0x6c000000-0x70000000] (64MB) mapped at [ffffffc06c000000-ffffffc06fffffff]
[ 0.000000] Memory: 3765244K/4194308K available (9916K kernel code, 638K rwdata, 2988K rodata, 512K init, 2166K bss, 166920K reserved, 262144K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008a30000 ( 9920 KB)
[ 0.000000] .rodata : 0xffffff8008a30000 - 0xffffff8008d20000 ( 3008 KB)
[ 0.000000] .init : 0xffffff8008d20000 - 0xffffff8008da0000 ( 512 KB)
[ 0.000000] .data : 0xffffff8008da0000 - 0xffffff8008e3fa00 ( 639 KB)
[ 0.000000] .bss : 0xffffff8008e3fa00 - 0xffffff800905d2b0 ( 2167 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf1dc00000 ( 476 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc880000000 ( 34816 MB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU event tracing is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 100.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024ee1c, max_idle_ns: 440795203561 ns
[ 0.000003] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
[ 0.008328] Console: colour dummy device 80x25
[ 0.012584] console [tty0] enabled
[ 0.015951] bootconsole [cdns0] disabled
[ 0.019861] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
[ 0.019874] pid_max: default: 32768 minimum: 301
[ 0.019977] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.019995] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.020592] ASID allocator initialised with 65536 entries
[ 0.020645] Hierarchical SRCU implementation.
[ 0.020915] EFI services will not be available.
[ 0.020939] zynqmp_plat_init Platform Management API v1.0
[ 0.020948] zynqmp_plat_init Trustzone version v1.0
[ 0.021048] smp: Bringing up secondary CPUs ...
[ 0.021296] Detected VIPT I-cache on CPU1
[ 0.021325] CPU1: Booted secondary processor [410fd034]
[ 0.021598] Detected VIPT I-cache on CPU2
[ 0.021616] CPU2: Booted secondary processor [410fd034]
[ 0.021879] Detected VIPT I-cache on CPU3
[ 0.021897] CPU3: Booted secondary processor [410fd034]
[ 0.021937] smp: Brought up 1 node, 4 CPUs
[ 0.021969] SMP: Total of 4 processors activated.
[ 0.021978] CPU features: detected feature: 32-bit EL0 Support
[ 0.021988] CPU: All CPU(s) started at EL2
[ 0.022004] alternatives: patching kernel code
[ 0.022722] devtmpfs: initialized
[ 0.025880] random: get_random_u32 called from bucket_table_alloc+0x108/0x260 with crng_init=0
[ 0.026032] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.026054] futex hash table entries: 1024 (order: 5, 131072 bytes)
[ 0.031501] xor: measuring software checksum speed
[ 0.067943] 8regs : 2303.000 MB/sec
[ 0.107972] 8regs_prefetch: 2053.000 MB/sec
[ 0.148004] 32regs : 2830.000 MB/sec
[ 0.188032] 32regs_prefetch: 2379.000 MB/sec
[ 0.188040] xor: using function: 32regs (2830.000 MB/sec)
[ 0.188110] pinctrl core: initialized pinctrl subsystem
[ 0.188294] random: fast init done
[ 0.188626] NET: Registered protocol family 16
[ 0.189232] cpuidle: using governor menu
[ 0.189543] vdso: 2 pages (1 code @ ffffff8008a36000, 1 data @ ffffff8008da4000)
[ 0.189560] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.190019] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.219462] reset_zynqmp reset-controller: Xilinx zynqmp reset driver probed
[ 0.220026] ARM CCI_400_r1 PMU driver probed
[ 0.224548] zynqmp-pinctrl ff180000.pinctrl: zynqmp pinctrl initialized
[ 0.231843] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.300297] raid6: int64x1 gen() 403 MB/s
[ 0.368259] raid6: int64x1 xor() 446 MB/s
[ 0.436301] raid6: int64x2 gen() 688 MB/s
[ 0.504329] raid6: int64x2 xor() 603 MB/s
[ 0.572423] raid6: int64x4 gen() 1043 MB/s
[ 0.640427] raid6: int64x4 xor() 742 MB/s
[ 0.708514] raid6: int64x8 gen() 980 MB/s
[ 0.776525] raid6: int64x8 xor() 745 MB/s
[ 0.844631] raid6: neonx1 gen() 727 MB/s
[ 0.912642] raid6: neonx1 xor() 853 MB/s
[ 0.980717] raid6: neonx2 gen() 1169 MB/s
[ 1.048732] raid6: neonx2 xor() 1207 MB/s
[ 1.116784] raid6: neonx4 gen() 1504 MB/s
[ 1.184842] raid6: neonx4 xor() 1441 MB/s
[ 1.252895] raid6: neonx8 gen() 1651 MB/s
[ 1.320949] raid6: neonx8 xor() 1533 MB/s
[ 1.320957] raid6: using algorithm neonx8 gen() 1651 MB/s
[ 1.320964] raid6: .... xor() 1533 MB/s, rmw enabled
[ 1.320972] raid6: using neon recovery algorithm
[ 1.321677] SCSI subsystem initialized
[ 1.321850] usbcore: registered new interface driver usbfs
[ 1.321888] usbcore: registered new interface driver hub
[ 1.321923] usbcore: registered new device driver usb
[ 1.321992] media: Linux media interface: v0.10
[ 1.322019] Linux video capture interface: v2.00
[ 1.322058] pps_core: LinuxPPS API ver. 1 registered
[ 1.322066] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.322089] PTP clock support registered
[ 1.322118] EDAC MC: Ver: 3.0.0
[ 1.322418] zynqmp-ipi ff9905c0.mailbox: Probed ZynqMP IPI Mailbox driver.
[ 1.322576] FPGA manager framework
[ 1.322686] fpga-region fpga-full: FPGA Region probed
[ 1.322776] Advanced Linux Sound Architecture Driver Initialized.
[ 1.323027] Bluetooth: Core ver 2.22
[ 1.323056] NET: Registered protocol family 31
[ 1.323064] Bluetooth: HCI device and connection manager initialized
[ 1.323075] Bluetooth: HCI socket layer initialized
[ 1.323085] Bluetooth: L2CAP socket layer initialized
[ 1.323102] Bluetooth: SCO socket layer initialized
[ 1.323561] clocksource: Switched to clocksource arch_sys_counter
[ 1.323633] VFS: Disk quotas dquot_6.6.0
[ 1.323678] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.327643] NET: Registered protocol family 2
[ 1.327941] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 1.328153] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 1.328564] TCP: Hash tables configured (established 32768 bind 32768)
[ 1.328641] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.328717] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 1.328866] NET: Registered protocol family 1
[ 1.329048] RPC: Registered named UNIX socket transport module.
[ 1.329058] RPC: Registered udp transport module.
[ 1.329065] RPC: Registered tcp transport module.
[ 1.329072] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.329170] Trying to unpack rootfs image as initramfs...
[ 1.581633] Freeing initrd memory: 6264K
[ 1.582034] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[ 1.582190] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.582868] audit: initializing netlink subsys (disabled)
[ 1.582947] audit: type=2000 audit(1.567:1): state=initialized audit_enabled=0 res=1
[ 1.583264] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 1.583980] NFS: Registering the id_resolver key type
[ 1.584006] Key type id_resolver registered
[ 1.584013] Key type id_legacy registered
[ 1.584026] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.584046] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 1.610611] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.610632] io scheduler noop registered
[ 1.610641] io scheduler deadline registered
[ 1.610662] io scheduler cfq registered (default)
[ 1.610670] io scheduler mq-deadline registered
[ 1.610678] io scheduler kyber registered
[ 1.611914] xilinx-dpdma fd4c0000.dma: Xilinx DPDMA engine is probed
[ 1.612308] xilinx-zynqmp-dma fd500000.dma: ZynqMP DMA driver Probe success
[ 1.612452] xilinx-zynqmp-dma fd510000.dma: ZynqMP DMA driver Probe success
[ 1.612593] xilinx-zynqmp-dma fd520000.dma: ZynqMP DMA driver Probe success
[ 1.612733] xilinx-zynqmp-dma fd530000.dma: ZynqMP DMA driver Probe success
[ 1.612874] xilinx-zynqmp-dma fd540000.dma: ZynqMP DMA driver Probe success
[ 1.613017] xilinx-zynqmp-dma fd550000.dma: ZynqMP DMA driver Probe success
[ 1.613158] xilinx-zynqmp-dma fd560000.dma: ZynqMP DMA driver Probe success
[ 1.613302] xilinx-zynqmp-dma fd570000.dma: ZynqMP DMA driver Probe success
[ 1.613511] xilinx-zynqmp-dma ffa80000.dma: ZynqMP DMA driver Probe success
[ 1.613654] xilinx-zynqmp-dma ffa90000.dma: ZynqMP DMA driver Probe success
[ 1.613793] xilinx-zynqmp-dma ffaa0000.dma: ZynqMP DMA driver Probe success
[ 1.613932] xilinx-zynqmp-dma ffab0000.dma: ZynqMP DMA driver Probe success
[ 1.614073] xilinx-zynqmp-dma ffac0000.dma: ZynqMP DMA driver Probe success
[ 1.614213] xilinx-zynqmp-dma ffad0000.dma: ZynqMP DMA driver Probe success
[ 1.614350] xilinx-zynqmp-dma ffae0000.dma: ZynqMP DMA driver Probe success
[ 1.614491] xilinx-zynqmp-dma ffaf0000.dma: ZynqMP DMA driver Probe success
[ 1.639369] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 1.642143] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.646367] brd: module loaded
[ 1.649781] loop: module loaded
[ 1.650580] ahci-ceva fd0c0000.ahci: ceva,p1-cominit-params property not defined
[ 1.650633] ahci-ceva: probe of fd0c0000.ahci failed with error -22
[ 1.650749] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.651192] zynqmp-qspi ff0f0000.spi: rx bus width not found
[ 1.651204] zynqmp-qspi ff0f0000.spi: tx bus width not found
[ 1.651817] m25p80 spi0.0: n25q512a (65536 Kbytes)
[ 1.651842] 3 ofpart partitions found on MTD device spi0.0
[ 1.651850] Creating 3 MTD partitions on "spi0.0":
[ 1.651863] 0x000000000000-0x000000100000 : "boot"
[ 1.652287] 0x000000100000-0x000000140000 : "bootenv"
[ 1.652665] 0x000000140000-0x000001740000 : "kernel"
[ 1.653901] libphy: Fixed MDIO Bus: probed
[ 1.654911] tun: Universal TUN/TAP device driver, 1.6
[ 1.655046] CAN device driver interface
[ 1.656118] macb ff0e0000.ethernet: Not enabling partial store and forward
[ 1.656495] libphy: MACB_mii_bus: probed
[ 1.660317] macb ff0e0000.ethernet eth0: Could not attach to PHY
[ 1.680611] usbcore: registered new interface driver asix
[ 1.680664] usbcore: registered new interface driver ax88179_178a
[ 1.680694] usbcore: registered new interface driver cdc_ether
[ 1.680723] usbcore: registered new interface driver net1080
[ 1.680752] usbcore: registered new interface driver cdc_subset
[ 1.680782] usbcore: registered new interface driver zaurus
[ 1.680826] usbcore: registered new interface driver cdc_ncm
[ 1.681117] xilinx-axipmon ffa00000.perf-monitor: Probed Xilinx APM
[ 1.681455] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.681466] ehci-pci: EHCI PCI platform driver
[ 1.681708] usbcore: registered new interface driver uas
[ 1.681745] usbcore: registered new interface driver usb-storage
[ 1.682206] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[ 1.682259] i2c /dev entries driver
[ 1.682602] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 33
[ 1.682798] IR NEC protocol handler initialized
[ 1.682807] IR RC5(x/sz) protocol handler initialized
[ 1.682814] IR RC6 protocol handler initialized
[ 1.682821] IR JVC protocol handler initialized
[ 1.682828] IR Sony protocol handler initialized
[ 1.682835] IR SANYO protocol handler initialized
[ 1.682842] IR Sharp protocol handler initialized
[ 1.682849] IR MCE Keyboard/mouse protocol handler initialized
[ 1.682857] IR XMP protocol handler initialized
[ 1.683533] usbcore: registered new interface driver uvcvideo
[ 1.683542] USB Video Class driver (1.1.1)
[ 1.684055] cdns-wdt fd4d0000.watchdog: Xilinx Watchdog Timer at ffffff80090ed000 with timeout 10s
[ 1.684227] Bluetooth: HCI UART driver ver 2.3
[ 1.684237] Bluetooth: HCI UART protocol H4 registered
[ 1.684245] Bluetooth: HCI UART protocol BCSP registered
[ 1.684274] Bluetooth: HCI UART protocol LL registered
[ 1.684283] Bluetooth: HCI UART protocol ATH3K registered
[ 1.684291] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.684332] Bluetooth: HCI UART protocol Intel registered
[ 1.684341] Bluetooth: HCI UART protocol QCA registered
[ 1.684376] usbcore: registered new interface driver bcm203x
[ 1.684409] usbcore: registered new interface driver bpa10x
[ 1.684445] usbcore: registered new interface driver bfusb
[ 1.684478] usbcore: registered new interface driver btusb
[ 1.684486] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 1.684534] usbcore: registered new interface driver ath3k
[ 1.684662] EDAC MC: ECC not enabled
[ 1.684809] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[ 1.685616] sdhci: Secure Digital Host Controller Interface driver
[ 1.685625] sdhci: Copyright(c) Pierre Ossman
[ 1.685633] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.731564] mmc0: SDHCI controller on ff170000.sdhci [ff170000.sdhci] using ADMA 64-bit
[ 1.731798] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.731933] usbcore: registered new interface driver usbhid
[ 1.731942] usbhid: USB HID core driver
[ 1.733680] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[ 1.735372] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 1.737600] Netfilter messages via NETLINK v0.30.
[ 1.737717] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.737845] Initializing XFRM netlink socket
[ 1.737910] NET: Registered protocol family 10
[ 1.738279] Segment Routing with IPv6
[ 1.738324] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.738437] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.738751] NET: Registered protocol family 17
[ 1.738767] NET: Registered protocol family 15
[ 1.738787] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 1.738801] Ebtables v2.0 registered
[ 1.738891] can: controller area network core (rev 20170425 abi 9)
[ 1.738923] NET: Registered protocol family 29
[ 1.738939] can: raw protocol (rev 20170425)
[ 1.738947] can: broadcast manager protocol (rev 20170425 t)
[ 1.738959] can: netlink gateway (rev 20170425) max_hops=1
[ 1.739137] Bluetooth: RFCOMM TTY layer initialized
[ 1.739150] Bluetooth: RFCOMM socket layer initialized
[ 1.739164] Bluetooth: RFCOMM ver 1.11
[ 1.739174] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.739185] Bluetooth: BNEP filters: protocol multicast
[ 1.739195] Bluetooth: BNEP socket layer initialized
[ 1.739203] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.739213] Bluetooth: HIDP socket layer initialized
[ 1.739323] 9pnet: Installing 9P2000 support
[ 1.739342] Key type dns_resolver registered
[ 1.739690] registered taskstats version 1
[ 1.740030] Btrfs loaded, crc32c=crc32c-generic
[ 1.745123] ff000000.serial: ttyPS0 at MMIO 0xff000000 (irq = 41, base_baud = 6249999) is a xuartps
[ 1.944396] mmc0: error -110 whilst initialising SD card
[ 3.346094] console [ttyPS0] enabled
[ 3.350082] ff010000.serial: ttyPS1 at MMIO 0xff010000 (irq = 42, base_baud = 6249999) is a xuartps
[ 3.359991] xilinx-psgtr fd400000.zynqmp_phy: Lane:1 type:8 protocol:4 pll_locked:yes
[ 3.368099] PLL: shutdown
[ 3.370750] PLL: shutdown
[ 3.373630] PLL: enable
[ 3.376127] PLL: shutdown
[ 3.379478] PLL: enable
[ 3.381943] xilinx-dp-snd-codec fd4a0000.zynqmp-display:zynqmp_dp_snd_codec0: Xilinx DisplayPort Sound Codec probed
[ 3.392511] xilinx-dp-snd-pcm fd4a0000.zynqmp-display:zynqmp_dp_snd_pcm0: Xilinx DisplayPort Sound PCM probed
[ 3.402539] xilinx-dp-snd-pcm fd4a0000.zynqmp-display:zynqmp_dp_snd_pcm1: Xilinx DisplayPort Sound PCM probed
[ 3.412637] xilinx-dp-snd-pcm fd4a0000.zynqmp-display:zynqmp_dp_snd_pcm1: ASoC: Failed to create component debugfs directory
[ 3.423952] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 3.436309] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: xilinx-dp-snd-codec-dai <-> xilinx-dp-snd-codec-dai mapping ok
[ 3.448923] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: Xilinx DisplayPort Sound Card probed
[ 3.459021] OF: graph: no port node found in /amba/zynqmp-display@fd4a0000
[ 3.465926] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 3.472460] [drm] No driver support for vblank timestamp query.
[ 3.478418] xlnx-drm xlnx-drm.0: bound fd4a0000.zynqmp-display (ops 0xffffff8008ae4268)
[ 4.563570] [drm] Cannot find any crtc or sizes
[ 4.568191] [drm] Initialized xlnx 1.0.0 20130509 for fd4a0000.zynqmp-display on minor 0
[ 4.576222] zynqmp-display fd4a0000.zynqmp-display: ZynqMP DisplayPort Subsystem driver probed
[ 4.585028] dwc3-of-simple ff9d0000.usb0: dwc3_simple_set_phydata: Can't find usb3-phy
[ 4.593771] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.599189] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 4.607023] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f625 hci version 0x100 quirks 0x22010010
[ 4.615673] xhci-hcd xhci-hcd.0.auto: irq 47, io mem 0xfe200000
[ 4.621656] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.628365] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.635566] usb usb1: Product: xHCI Host Controller
[ 4.640423] usb usb1: Manufacturer: Linux 4.14.0-xilinx-v2018.1 xhci-hcd
[ 4.647107] usb usb1: SerialNumber: xhci-hcd.0.auto
[ 4.652236] hub 1-0:1.0: USB hub found
[ 4.655930] hub 1-0:1.0: 1 port detected
[ 4.659993] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 4.665404] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 4.673085] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 4.681183] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.687888] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.695092] usb usb2: Product: xHCI Host Controller
[ 4.699951] usb usb2: Manufacturer: Linux 4.14.0-xilinx-v2018.1 xhci-hcd
[ 4.706634] usb usb2: SerialNumber: xhci-hcd.0.auto
[ 4.711731] hub 2-0:1.0: USB hub found
[ 4.715411] hub 2-0:1.0: 1 port detected
[ 4.719496] dwc3 fe200000.dwc3: couldn't register cable notifier
[ 4.725420] dwc3 fe200000.dwc3: failed to initialize dual-role
[ 4.731257] platform fe200000.dwc3: runtime PM trying to suspend device but active child
[ 4.739309] dwc3: probe of fe200000.dwc3 failed with error -22
[ 4.745874] rtc_zynqmp ffa60000.rtc: setting system clock to 2019-01-12 08:02:35 UTC (1547280155)
[ 4.754762] clk: Not disabling unused clocks
[ 4.758992] ALSA device list:
[ 4.761898] #0: DisplayPort monitor
[ 4.765957] Freeing unused kernel memory: 512K
INIT: version 2.88 booting
Starting udev
[ 4.873714] udevd[1697]: starting version 3.2.2
[ 4.882714] udevd[1698]: starting eudev-3.2.2
[ 4.947609] zgpio: loading out-of-tree module taints kernel.
[ 4.953646] start zgpio_cdev_init
[ 4.953856] zgpio a0000000.gpio: Device Tree Probing
[ 4.962138] zgpio a0000000.gpio: no IRQ found
[ 4.966528] zgpio_cdev_init can get major
[ 4.966535] zgpio a0000000.gpio: Registering cdev.
[ 4.975352] zgpio: can get major 244
[ 4.978896] zgpio a0000000.gpio: zgpio allocate cdev 244 0
Starting internet superserver: inetd.
Configuring packages on first boot....
(This may take several minutes. Please do not power off the machine.)
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
INIT: Entering runlevel: 5
Configuring network interfaces... Cannot find device "eth0"
Starting Dropbear SSH server: Generating key, this may take a while...
[ 5.843572] [drm] Cannot find any crtc or sizes
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDSyeUv00tvW2e3aeSJ3HWdCWz6BroyvK7E9V7Ne/svMe0tzyI5AX95mg70NcSBDRyMqHTUNmg11iLGzmOQNjp9Q6I8ypcp0Yt5N3QdyaIbbm8uncXgwZ07KvudTtdiHD11kBbI0Jyb1vfeBl7125T26EoNjQYpMdA7fS7m
Fingerprint: md5 d3:95:4b:ef:6f:49:27:a9:88:7d:b8:a2:43:2c:21:cd
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2018.1 zcu104gpioram /dev/ttyPS0
ls /dev/m*:
mem memory_bandwidth mtab mtd0 mtd0ro mtd1 mtd1ro mtd2 mtd2ro mtdblock0 mtdblock1 mtdblock2
cat /proc/devices:
Block devices:
1 ramdisk
7 loop
8 sd
31 mtdblock
65 sd
66 sd
67 sd
68 sd
69 sd
70 sd
71 sd
128 sd
129 sd
130 sd
131 sd
132 sd
133 sd
134 sd
135 sd
179 mmc
259 blkext
