zcu106 petalinux build error
I use vivado2018.3 & petalinux 2018.3 to build project, but failed, the error message is below, how about I can to fixed it?
$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image
Parsing recipes: 100% |###############################################################################| Time: 0:00:55
Parsing of 2571 .bb files complete (0 cached, 2571 parsed). 3463 targets, 137 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |############################################################################| Time: 0:00:17
Checking sstate mirror object availability: 100% |####################################################| Time: 0:00:18
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: device-tree-xilinx+gitAUTOINC+b7466bbeee-r0 do_compile: Function failed: do_compile (log file is located at /home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.13780)
ERROR: Logfile of failure stored in: /home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.13780
Log data follows:
| DEBUG: Executing shell function do_compile
| In file included from /home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/system-user.dtsi:13:0,
| from /home/sh-z440/TRD_HOME/zcu106_manual/build/../components/plnx_workspace/device-tree/device-tree/system-top.dts:32:
| /home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/design-fixes.dtsi:3:28: fatal error: vcap-hdmi_2.dtsi: No such file or directory
| compilation terminated.
| WARNING: /home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/run.do_compile.13780:1 exit 1 from 'gcc -E -nostdinc -Ulinux -x assembler-with-cpp -I/home/sh-z440/TRD_HOME/zcu106_manual/build/../components/plnx_workspace/device-tree/device-tree -I/home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work-shared/plnx-zynqmp/kernel-source/include -I/home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work-shared/plnx-zynqmp/kernel-source/arch/arm64/boot/dts/xilinx -I/home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work-shared/plnx-zynqmp/kernel-source/include -I/home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0 -o `basename ${DTS_FILE}`.pp ${DTS_FILE}'
| ERROR: Function failed: do_compile (log file is located at /home/sh-z440/TRD_HOME/zcu106_manual/build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/temp/log.do_compile.13780)
ERROR: Task (/home/sh-z440/petalinux2018.3/components/yocto/source/aarch64/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 6988 tasks of which 5639 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
ERROR: Failed to build project
Re: zcu106 petalinux build error
Can you check to see if the dtsi file mentioend above exists in your petalinux project?
