zcu106 trd 2019.1: self-hosted package enabled causes kernel crash
In xilinx-vcu-trd-zcu106-v2019.1-final peta project, I enable:
CONFIG_packagegroup-petalinux-self-hosted=y
During kernel boot:
[ 18.210266] Kernel panic - not syncing: Can not allocate SWIOTLB buffer earlier and can't now provide you with the DMA bounce buffer
[ 18.222170] CPU: 1 PID: 61 Comm: kworker/1:1 Not tainted 4.19.0-xilinx-v2019.1 #1
[ 18.229646] Hardware name: ZynqMP ZCU106 RevA (DT)
[ 18.234435] Workqueue: events deferred_probe_work_func
[ 18.239566] Call trace:
[ 18.242009] dump_backtrace+0x0/0x148
[ 18.245662] show_stack+0x14/0x20
[ 18.248970] dump_stack+0x90/0xb4
[ 18.252276] panic+0x120/0x268
[ 18.255324] map_single+0x0/0xa0
[ 18.258544] map_single+0x4c/0xa0
[ 18.261851] swiotlb_map_page+0x9c/0x158
[ 18.265767] __swiotlb_map_page+0x28/0x90
[ 18.269771] zynqmp_qspi_start_transfer+0x2b0/0x700
[ 18.274639] spi_transfer_one_message+0x128/0x478
[ 18.279335] __spi_pump_messages+0x35c/0x580
[ 18.283597] __spi_sync+0x234/0x298
[ 18.287077] spi_sync+0x2c/0x50
[ 18.290211] spi_mem_exec_op+0x2c4/0x418
[ 18.294126] m25p80_read+0x98/0x118
[ 18.297609] spi_nor_read_sfdp+0x58/0xc8
[ 18.301523] spi_nor_read_sfdp_dma_unsafe+0x50/0x90
[ 18.306394] spi_nor_init_params+0x218/0x6c0
[ 18.310655] spi_nor_scan+0xfc/0xe48
[ 18.314222] m25p_probe+0x194/0x1f0
[ 18.317704] spi_mem_probe+0x6c/0xa0
[ 18.321271] spi_drv_probe+0x7c/0xd8
[ 18.324839] really_probe+0x1c8/0x280
[ 18.328494] driver_probe_device+0x54/0xe8
[ 18.332583] __device_attach_driver+0xb8/0xe8
[ 18.336931] bus_for_each_drv+0x78/0xc8
[ 18.340760] __device_attach+0xd4/0x130
[ 18.344588] device_initial_probe+0x10/0x18
[ 18.348763] bus_probe_device+0x90/0x98
[ 18.352593] device_add+0x334/0x608
[ 18.356073] spi_add_device+0xac/0x168
[ 18.359815] of_register_spi_device+0x214/0x320
[ 18.364338] spi_register_controller+0x290/0x618
[ 18.368948] zynqmp_qspi_probe+0x3f4/0x530
[ 18.373036] platform_drv_probe+0x50/0xa0
[ 18.377037] really_probe+0x1c8/0x280
[ 18.380692] driver_probe_device+0x54/0xe8
[ 18.384781] __device_attach_driver+0xb8/0xe8
[ 18.389129] bus_for_each_drv+0x78/0xc8
[ 18.392958] __device_attach+0xd4/0x130
[ 18.396786] device_initial_probe+0x10/0x18
[ 18.400962] bus_probe_device+0x90/0x98
[ 18.404790] deferred_probe_work_func+0x6c/0xa0
[ 18.409313] process_one_work+0x1e4/0x340
[ 18.413314] worker_thread+0x248/0x488
[ 18.417058] kthread+0x124/0x128
[ 18.420277] ret_from_fork+0x10/0x18
[ 18.423846] SMP: stopping secondary CPUs
[ 18.427760] Kernel Offset: disabled
[ 18.431240] CPU features: 0x0,20802004
[ 18.434980] Memory Limit: none
[ 18.438023] ---[ end Kernel panic - not syncing: Can not allocate SWIOTLB buffer earlier and can't now provide you with the DMA bounce buffer ]---
I disable CONFIG_packagegroup-petalinux-self-hosted, recompile then kernel boots ok.  Is there something else I need to configure to get CONFIG_packagegroup-petalinux-self-hosted to work?  Thanks in advance.
Re: zcu106 trd 2019.1: self-hosted package enabled causes kernel crash
Hi @kallensf ,
Below is the steps you need follow.
  1. Set the Image Packaging Configuration -> Root filesystem type -> SD card
  2. Modify the bootargs in common.dtsi as shown below.
            chosen {
                    bootargs = "earlycon clk_ignore_unused consoleblank=0 cma=1700M uio_pdrv_genirq.of_id=generic-uio root=/dev/mmcblk0p2 rw rootwait";
                    stdout-path = "serial0:115200n8";
    &uart1 {
        status = "disabled";
  3. Run below commands.
    $ petalinux-build -c device-tree -x cleansstate
    $ petalinux-build
  4. Verify the decompile system.dtb
Sandeep
Hi @kallensf ,
What is your bootmode? Are you using QSPI mode?
When you enable self-hosted package it increase size of rootfs.
Sandeep
SD card
Hi @kallensf ,
Are you using INITRAMFS or SD EXT4 in petalinux?
Also if you can post complete boot log that will be great.
Sandeep
We use initramfs:
CONFIG_SUBSYSTEM_ROOTFS_INITRAMFS=y
CONFIG_SUBSYSTEM_UIMAGE_NAME="image.ub"
CONFIG_SUBSYSTEM_DTB_PADDING_SIZE=0x1000
I attached file boot_hosted_y.txt which is the kernel boot when selfhosted is enabled.
Hi @kallensf ,
When you enable self-hosted packages due to increase in rootfs size it is not recommended to use INITRAMFS hence you need to change the Image Packaging Configuration to SD
# Image Packaging Configuration
# CONFIG_SUBSYSTEM_ROOTFS_INITRAMFS is not set
# CONFIG_SUBSYSTEM_ROOTFS_INITRD is not set
# CONFIG_SUBSYSTEM_ROOTFS_JFFS2 is not set
# CONFIG_SUBSYSTEM_ROOTFS_NFS is not set
CONFIG_SUBSYSTEM_ROOTFS_SD=y
# CONFIG_SUBSYSTEM_ROOTFS_OTHER is not set
CONFIG_SUBSYSTEM_SDROOT_DEV="/dev/mmcblk0p2"
# CONFIG_SUBSYSTEM_COPY_TO_TFTPBOOT is not set
Note: In upcoming 2019.2 release we have renamed this option from SD to EXT4 where you can use SD/SATA/eMMC.
Sandeep
Thanks for the explanation.  It seems that I have to prep the sd card for SUBSYSTEM_ROOTFS_SD=y.
Are these instructions applicable to 2019.1?  If not, please let me know where to find updated instructions.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842385/How+to+format+SD+card+for+SD+boot
Thanks again
Sorry for double post, but I can't seem to edit a previous reply.
It seems https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842385/How+to+format+SD+card+for+SD+boot
only explains formatting but not what to do after.  My peta build finished and I have:
rootfs.ext3, rootfs.ext4
both 1.2 gb in size.  No wonder ramfs crashed...
I assume that I have to use ext4 and copy it to the 2nd partition, but the steps that I found are from older peta 2016/2017.  If you could point me to instructions closer to 2019.1, I appreciate it.
Hi @kallensf ,
Once you have FAT and EXT4 partition create follow below steps.
# Go to FAT partition
$ cd BOOT/
# Copy BOOT.BIN and image.ub in FAT partion $ cp <plnx-proj-root>/images/linux/BOOT.BIN . $ cp <plnx-proj-root>/images/linux/image.ub .
# Go to FAT partition $ cd ROOTFS/
# Copy rootfs.tar.gz in Ext4 partion using super user mode $ sudo cp <plnx-proj-root>/images/linux/rootfs.tar.gz . $ sudo tar -xf rootfs.tar.gz
# Exit from EXT4 partition $ cd
# Run Sync before you umount the SD card. $ sync
This is documented in 2019.1 UG1144 page 55, 64 and 65
Sandeep
The kernel boot fails and reports error:
[ 7.180740] VFS: Cannot open root device "(null)" or unknown-block(0,0): error -6
[ 7.188234] Please append a correct "root=" boot option;
It seems
isn't being specified in the "root=" boot option.  I tried
petalinux-build -x distclean
but the kernel boot still fails.
It seems like there is a step missing or the project isn't updating properly after petalinux-config.
I've attached the boot log.
Hi @kallensf ,
From your boot logs I don't see the root= option is parsed in your boot args.
[    0.000000] Kernel command line: earlycon clk_ignore_unused consoleblank=0 cma=1700M uio_pdrv_genirq.of_id=generic-uio
Can you share your project-spec/configs/config file?
Sandeep
Here's my config file.
Some google searches have a solution of disabling SD card write protect.  I tried adding to system-user.dtsi:
&sdhci0 {
status = "okay";
disable-wp;
But uboot reports
Hit any key to stop autoboot: 0
Card did not respond to voltage select!
ZynqMP>
Hi @kallensf ,
If you are using Class10 SD card then it should work out of box.
xilinx-zcu106-2019.1 $ cat project-spec/configs/config | grep "/dev"
CONFIG_SUBSYSTEM_BOOTARGS_GENERATED="earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait"
Still I don't see your config file.
Sandeep
So sorry, I tried a reply yesterday but didn't see this error:
The attachment's config content type (text/plain) does not match its file extension and has been removed
So the post attempt rejected config and then I just click Post again.
 I renamed it with .txt attached it with this post, so hopefully it works. At the end of config, I see:
To check where the SD card is mounted, I copied the prebuilt bin from rdf0428-zcu106-vcu-trd-2019-1_v2\images\vcu_hdmitx and check the dev for mmc:
root@zcu106_vcu_trd:/dev# ls mmc*
mmcblk0 mmcblk0p1 mmcblk0p2 mmcblk0p3
The SD card that I used was the one shipped with the zcu106: sandisk ultra sdhcI class 10. I do have 3 partitions tho.  Will the 3rd partition cause trouble?
Hi @kallensf ,
I'm not sure what does the 3rd partition contains. Do you still have the EXT4 mount issues?
Sandeep
The 3rd partition is empty.  I made the 3rd partition to test saving our database there.
Unfortunately, I still have EXT4 mount issues.  I removed the SD card write protect disable in my device tree since it causes an error in uboot.
Hi @kallensf ,
Can you run below commands and verify <plnx-proj-root>/components/plnx_workspace/device-tree/device-tree/system-conf.dtsi file is getting updated with right bootargs?
$ petalinux-config
$ petalinux-build -c device-tree -x cleansstate $ petalinux-build
Sandeep
system-conf.dtsi's bootargs are either ignored or overrided.  system-conf.dtsi has:
chosen {
bootargs = "earlycon console=ttyPS0,115200 clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait";
but components/plnx_workspace/device-tree/device-tree/system-top.dts has:
chosen {
bootargs = "earlycon clk_ignore_unused";
I decompile images/linux/system.dtb to get a dts:
dtc -I dtb -O dts -o system.dts system.dtb
system.dtb has:
chosen {
I found that common.dtsi in project-spec/meta-user/recipes-bsp/device-tree/files has:
chosen {
bootargs = "earlycon clk_ignore_unused consoleblank=0 cma=1700M uio_pdrv_genirq.of_id=generic-uio";
I delete common.dtsi and clean with -x cleansstate
After peta build, I check images/linux/system.dtb, but it still has:
Something is still overriding/ignoring system-conf.dtsi's bootargs.  If you have any suggestions on how to fix this, please let me know.  Thanks in advance!  I've attached system-conf.dtsi and decompiled images/linux/system.dtb
Hi @kallensf ,
            chosen {
    &uart1 {
    $ petalinux-build
Sandeep
I did as you suggested but the bootargs were still not modified, so I started a new project with the hdmitx hdf from rdf0428-zcu106-vcu-trd-2019-1_v2/pl/prebuilt. I follow all the steps that you told me and it booted successfully. To make sure that it really is using sd card partition 2 as the rootfs, I copied a text file _sdcard_rootfs_ to partition 2. After boot, I check and see that _sdcard_rootfs_ is there.
root@zcu106_vcu_trd:~# cd /
root@zcu106_vcu_trd:/# ls
_sdcard_rootfs_ boot etc lib mnt rootfs.tar.gz sbin tmp var
bin dev home media proc run sys usr
I marked your last reply as the solution but I'll summarize all your suggestions below.  Thanks for all the help!  Cheers!
It seems if the project was built with Initramfs before, it doesn't convert to SD card properly. I suggest starting a new project from scratch instead of reusing a project that had Initramfs.
SD card as Root FS on ZCU106 eval board, vcu bsp.
1) Start a new project and config for SD card as per 2019.1 UG1144 page 55, 64 and 65
project-spec/configs/config will have:
2) Modify the bootargs in common.dtsi to match CONFIG_SUBSYSTEM_SDROOT_DEV string with bootargs variable root= string
chosen {
3) Build
$ petalinux-build
4) While building, prepare a SD card with at least 2 partitions. Partition 1 must be FAT. Partition 2 must be EXT4. Any format tool is fine. Here is an example with fdisk:
5) After peta build is done, copy files:
$ cd BOOT/
$ cd ROOTFS/
$ cd
$ sync
Note that if Partition 2 is FAT, tar will report errors and symlinks will fail. Partition 2 must be EXT4.
6) Insert SD card and power up zcu106 board
