Observer cosminpanzaru1
zcu106 with ILA
I created  SD card bootable and loaded into my zcu 102 board. Using ILA i am trying to monitor some signals.But as soon as i turn the Hardware Manager on in order to record some data , UART interface gets stuck and nothing works. Does anyone  knows by any chance what effect will have ILA when using an SD card to boot ?
Kind regards,
Cosmin
Re: zcu106 with ILA
Hi Cosmin
Disable CPU idle in the kernel config and rebuild and try. This is a known issue and is described here
https://www.xilinx.com/support/answers/69143.html
Best Regards
Shabbir
Re: zcu106 with ILA
Hi Cosmin
Best Regards
Shabbir
Re: zcu106 with ILA
Thank you. It worked
