zedboard linaro OS crash
Hi Xilinx,
I am working on a DMA loop-back test on Linaro X-window with zedboard.
vivado 2015.4 outputs hardware of " HDMI + an extra DMA loopback " ;
then petalinux 2015.4 generates " BOOT.BIN + Image.ub ";
finally from SD card, zedboard boot-up with a linaro X-window desktop on 1920x1080 monitor.
However, the linaro X-window tends to crash. Looks just like log-out, and I have to input a password to login again.
The only thing I can catch is that, the source address and the destination address of the DMA loopback,
    dma_set(virtual_address, S2MM_DESTINATION_ADDRESS, 0x0f000000); // Write destination address
    dma_set(virtual_address, MM2S_START_ADDRESS, 0x0e000000); // Write source address
Zedboard has total 512MB DDR, while 0x0e00_0000 ~0x0f00_0000 is around middle ~~around 256MB.
The above code works fine in a petalinux project only (without Linaro), However, linaro tends to occupy/manage the whole DDR space.
Please advise how to setup a dedicate DDR memory area for DMA loopback test without interference to Linaro OS.
Thanks in advance
Mike
Re: zedboard linaro OS crash
