zynq and marvell dsa 88e6176 integration, device tree
We have custom board that based on zynq7000 SoC and petalinux is v2017.4. We have been trying to up ethernet solution for those zynq board.
The board has marvell PHY which are connected to PS MIO (gem0).
After some search on webs and device tree modifications, we just configure the device tree like this solution(https://forums.xilinx.com/t5/Embedded-Linux/zynq-and-marvell-dsa-88e6352-integration-device-tree/td-p/779400) and more data that we finded, that not help much.
We have a "no phy found" error.
Our board setup:
|     e000b000, GEM0—|———— RGMII ———|—port6 (0x16,act as MAC)        port1 —— PHY1
| Zynq-7000          |              |    mv88e6176 (switch1@addr=2)            |
|     e000c000, GEM1 |              | port5 (disabled)               port3 —— PHY3(other ports is not used)
Our device tree:
/include/ "system-conf.dtsi"
newmdio0: mdio0 {
compatible = "cdns,macb-mdio";
reg = <0xe000b000 0x1000>;
clocks = <&clkc 30>, <&clkc 30>, <&clkc 13>;
clock-names = "pclk", "hclk", "tx_clk";
#address-cells = <1>;
#size-cells = <0>;
&newmdio0 {
#size-cells = <0>;
switch0: switch0@2 {
compatible = "marvell,mv88e6176" ,"marvell,mv88e6085";
//compatible = "marvell,mv88e6085";
#size-cells = <0>;
reg = <2>;
dsa,member = <0 0>;
ports {
#size-cells = <0>;
port@1 {
reg = <1>;
label = "lan1";
port@3 {
reg = <3>;
label = "lan3";
switch0phy6: port@6 {
// compatible = "marvell,mv88e6176" ,"marvell,mv88e6085";
// device_type = "ethernet-phy";
reg = <6>;
label = "cpu";
ethernet = <&gem0>;
phy-mode = "rgmii-id";
fixed-link {
speed = <1000>;
full-duplex;
&gem0 {
compatible = "xlnx,ps7-ethernet-1.00.a";
xlnx,has-mdio = <0x1>;
clocks = <&clkc 13>, <&clkc 30>;
clock-names = "ref_clk", "aper_clk";
local-mac-address = [00 0a 35 00 1e 53];
phy-handle = <&switch0phy6>;
reset-gpios = <&gpio0 51 1>;
Our console:
Device: sdhci@e0100000
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes
reading image.ub
11985412 bytes read in 1005 ms (11.4 MiB/s)
## Loading kernel from FIT Image at 10000000 ...
Using 'conf@1' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@0' kernel subimage
Description: Linux Kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000d4
Data Size: 6029944 Bytes = 5.8 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: sha1
Hash value: 91e4aca35c2b019c93a312552a998f7c2bf385dd
Verifying Hash Integrity ... sha1+ OK
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@0' ramdisk subimage
Description: ramdisk
Type: RAMDisk Image
Data Start: 0x105c57cc
Data Size: 5932616 Bytes = 5.7 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha1
Hash value: 48708d751ba5dd9c1f138165f7ce3d55c5c91c31
## Loading fdt from FIT Image at 10000000 ...
Trying 'fdt@0' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x105c0440
Data Size: 21212 Bytes = 20.7 KiB
Architecture: ARM
Hash algo: sha1
Hash value: 1fec79160e0a90e0a5189ecdd7190a540bb7badf
Booting using the fdt blob at 0x105c0440
ZYNQ GEM: e000b000, phyaddr ffffffff, interface rgmii-id
mdio_register: non unique device name 'eth0'
Loading Kernel Image ... OK
Loading Ramdisk to 07a57000, end 07fff648 ... OK
Loading Device Tree to 07a4e000, end 07a562db ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.0-xilinx (shonz@Hisky) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #1 SMP PREEMPT Tue Aug 27 17:41:24 IDT 2019
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: xlnx,zynq-7000
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: Reserved 256 MiB at 0x10000000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] percpu: Embedded 14 pages/cpu @cfb4f000 s26316 r8192 d22836 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttyPS0,115200 earlyprintk
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 236572K/524288K available (8192K kernel code, 388K rwdata, 3100K rodata, 1024K init, 350K bss, 25572K reserved, 262144K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB)
[ 0.000000] .init : 0xc0d00000 - 0xc0e00000 (1024 kB)
[ 0.000000] .data : 0xc0e00000 - 0xc0e61280 ( 389 kB)
[ 0.000000] .bss : 0xc0e61280 - 0xc0eb8c10 ( 351 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=2.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] efuse mapped to e0800000
[ 0.000000] slcr mapped to e0802000
[ 0.000000] L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
[ 0.000000] L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
[ 0.000000] L2C-310 erratum 769419 enabled
[ 0.000000] L2C-310 enabling early BRESP for Cortex-A9
[ 0.000000] L2C-310 full line of zeros enabled for Cortex-A9
[ 0.000000] L2C-310 ID prefetch enabled, offset 1 lines
[ 0.000000] L2C-310 dynamic clock gating enabled, standby mode enabled
[ 0.000000] L2C-310 cache controller enabled, 8 ways, 512 kB
[ 0.000000] L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
[ 0.000000] zynq_clock_init: clkc starts at e0802100
[ 0.000000] Zynq clock init
[ 0.000010] sched_clock: 64 bits at 330MHz, resolution 3ns, wraps every 4398046511103ns
[ 0.007859] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4c1bad0b98, max_idle_ns: 440795207041 ns
[ 0.018875] Switching to timer-based delay loop, resolution 3ns
[ 0.024877] clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 542972910 ns
[ 0.033926] timer #0 at e080a000, irq=17
[ 0.038303] Console: colour dummy device 80x30
[ 0.042632] Calibrating delay loop (skipped), value calculated using timer frequency.. 660.00 BogoMIPS (lpj=3300000)
[ 0.053111] pid_max: default: 32768 minimum: 301
[ 0.057885] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.064393] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072126] CPU: Testing write buffer coherency: ok
[ 0.077049] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.082619] Setting up static identity map for 0x100000 - 0x100058
[ 0.258304] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.258403] Brought up 2 CPUs
[ 0.266935] SMP: Total of 2 processors activated (1320.00 BogoMIPS).
[ 0.273314] CPU: All CPU(s) started in SVC mode.
[ 0.278751] devtmpfs: initialized
[ 0.285954] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 0.293702] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.316127] xor: measuring software checksum speed
[ 0.417943] arm4regs : 1007.600 MB/sec
[ 0.517941] 8regs : 768.800 MB/sec
[ 0.617940] 32regs : 812.800 MB/sec
[ 0.622010] xor: using function: arm4regs (1007.600 MB/sec)
[ 0.627716] pinctrl core: initialized pinctrl subsystem
[ 0.634121] NET: Registered protocol family 16
[ 0.640315] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.688369] cpuidle: using governor menu
[ 0.701034] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.708908] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.714832] zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xe0840000
[ 0.721755] zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
[ 0.948520] raid6: int32x1 gen() 95 MB/s
[ 1.118150] raid6: int32x1 xor() 111 MB/s
[ 1.288473] raid6: int32x2 gen() 113 MB/s
[ 1.457946] raid6: int32x2 xor() 117 MB/s
[ 1.627959] raid6: int32x4 gen() 117 MB/s
[ 1.797971] raid6: int32x4 xor() 90 MB/s
[ 1.968424] raid6: int32x8 gen() 111 MB/s
[ 2.138261] raid6: int32x8 xor() 84 MB/s
[ 2.142421] raid6: using algorithm int32x4 gen() 117 MB/s
[ 2.147820] raid6: .... xor() 90 MB/s, rmw enabled
[ 2.152646] raid6: using intx1 recovery algorithm
[ 2.164173] SCSI subsystem initialized
[ 2.168701] usbcore: registered new interface driver usbfs
[ 2.174123] usbcore: registered new interface driver hub
[ 2.179495] usbcore: registered new device driver usb
[ 2.184786] media: Linux media interface: v0.10
[ 2.189274] Linux video capture interface: v2.00
[ 2.193886] pps_core: LinuxPPS API ver. 1 registered
[ 2.198848] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.207970] PTP clock support registered
[ 2.211967] EDAC MC: Ver: 3.0.0
[ 2.215655] FPGA manager framework
[ 2.219254] fpga-region fpga-full: FPGA Region probed
[ 2.224344] Advanced Linux Sound Architecture Driver Initialized.
[ 2.248559] clocksource: Switched to clocksource arm_global_timer
[ 2.254617] VFS: Disk quotas dquot_6.6.0
[ 2.258599] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.279756] NET: Registered protocol family 2
[ 2.284691] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 2.291680] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 2.298110] TCP: Hash tables configured (established 4096 bind 4096)
[ 2.304464] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 2.310302] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 2.316673] NET: Registered protocol family 1
[ 2.331440] RPC: Registered named UNIX socket transport module.
[ 2.337218] RPC: Registered udp transport module.
[ 2.342003] RPC: Registered tcp transport module.
[ 2.346679] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.353414] Trying to unpack rootfs image as initramfs...
[ 2.855319] Freeing initrd memory: 5796K (c7a57000 - c8000000)
[ 2.861371] hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
[ 2.870590] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 2.876607] audit: initializing netlink subsys (disabled)
[ 2.882036] audit: type=2000 audit(2.839:1): initialized
[ 2.887993] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 2.895245] NFS: Registering the id_resolver key type
[ 2.900278] Key type id_resolver registered
[ 2.904380] Key type id_legacy registered
[ 2.908435] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.915196] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 2.942876] io scheduler noop registered
[ 2.946685] io scheduler deadline registered
[ 2.951047] io scheduler cfq registered (default)
[ 2.958486] dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
[ 2.965086] dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
[ 2.974435] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 2.982829] e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 25, base_baud = 3125000) is a xuartps
▒[ 2.991876] console [ttyPS0] enabled
[ 2.998990] bootconsole [earlycon0] disabled
[ 3.008125] xdevcfg f8007000.devcfg: ioremap 0xf8007000 to e083c000
[ 3.014861] [drm] Initialized
[ 3.029254] brd: module loaded
[ 3.038730] loop: module loaded
[ 3.043408] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 3.052906] m25p80 spi0.0: found s25fl128s, expected n25q512a
[ 3.059080] m25p80 spi0.0: s25fl128s (16384 Kbytes)
[ 3.063903] 4 ofpart partitions found on MTD device spi0.0
[ 3.069433] Creating 4 MTD partitions on "spi0.0":
[ 3.074137] 0x000000000000-0x000000500000 : "boot"
[ 3.090123] 0x000000500000-0x000000520000 : "bootenv"
[ 3.106207] 0x000000520000-0x000000fa0000 : "kernel"
[ 3.122302] 0x000000fa0000-0x000001000000 : "spare"
[ 3.142054] libphy: Fixed MDIO Bus: probed
[ 3.151100] libphy: mdio_driver_register: xgmiitorgmii
[ 3.156210] tun: Universal TUN/TAP device driver, 1.6
[ 3.161217] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 3.167568] CAN device driver interface
[ 3.171549] libphy: mdio_driver_register: mv88e6085
[ 3.176714] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.182485] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.189830] libphy: XEMACPS mii bus: probed
[ 3.194870] xemacps e000b000.ethernet: pdev->id -1, baseaddr 0xe000b000, irq 28
[ 3.202964] usbcore: registered new interface driver asix
[ 3.208361] usbcore: registered new interface driver ax88179_178a
[ 3.214453] usbcore: registered new interface driver cdc_ether
[ 3.220289] usbcore: registered new interface driver net1080
[ 3.225917] usbcore: registered new interface driver cdc_subset
[ 3.231848] usbcore: registered new interface driver zaurus
[ 3.237414] usbcore: registered new interface driver cdc_ncm
[ 3.243581] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.250046] ehci-pci: EHCI PCI platform driver
[ 3.255018] usbcore: registered new interface driver uas
[ 3.260363] usbcore: registered new interface driver usb-storage
[ 3.266509] e0002000.usb supply vbus not found, using dummy regulator
[ 3.275720] ci_hdrc ci_hdrc.0: unable to init phy: -110
[ 3.280902] ci_hdrc: probe of ci_hdrc.0 failed with error -110
[ 3.288153] mousedev: PS/2 mouse device common for all mice
[ 3.294189] i2c /dev entries driver
[ 3.299315] usbcore: registered new interface driver uvcvideo
[ 3.304976] USB Video Class driver (1.1.1)
[ 3.310267] cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at e095c000 with timeout 10s
[ 3.318793] EDAC MC: ECC not enabled
[ 3.323278] Xilinx Zynq CpuIdle Driver started
[ 3.328163] sdhci: Secure Digital Host Controller Interface driver
[ 3.334279] sdhci: Copyright(c) Pierre Ossman
[ 3.338614] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.408616] mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
[ 3.471364] mmc0: new high speed SDHC card at address aaaa
[ 3.477257] mmcblk0: mmc0:aaaa SS16G 14.8 GiB
[ 3.481664] mmc1: SDHCI controller on e0101000.sdhci [e0101000.sdhci] using ADMA
[ 3.485847] mmcblk0: p1
[ 3.494906] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.501365] usbcore: registered new interface driver usbhid
[ 3.508934] usbhid: USB HID core driver
[ 3.524453] ad9361 spi1.0: ad9361_probe : enter (ad9364)
[ 3.545614] random: fast init done
[ 3.585818] mmc1: new high speed MMC card at address 0001
[ 3.601965] mmcblk1: mmc1:0001 Q2J54A 3.59 GiB
[ 3.616665] mmcblk1boot0: mmc1:0001 Q2J54A partition 1 16.0 MiB
[ 3.632795] mmcblk1boot1: mmc1:0001 Q2J54A partition 2 16.0 MiB
[ 3.638889] mmcblk1rpmb: mmc1:0001 Q2J54A partition 3 512 KiB
[ 3.787956] ad9361 spi1.0: ad9361_probe : AD936x Rev 2 successfully initialized
[ 3.816496] pktgen: Packet Generator for packet performance testing. Version: 2.75
[ 3.824245] Netfilter messages via NETLINK v0.30.
[ 3.829184] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 3.834505] Initializing XFRM netlink socket
[ 3.838811] NET: Registered protocol family 10
[ 3.844174] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 3.849623] NET: Registered protocol family 17
[ 3.853998] NET: Registered protocol family 15
[ 3.858425] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.871365] Ebtables v2.0 registered
[ 3.875181] can: controller area network core (rev 20120528 abi 9)
[ 3.881362] NET: Registered protocol family 29
[ 3.885724] can: raw protocol (rev 20120528)
[ 3.889999] can: broadcast manager protocol (rev 20161123 t)
[ 3.895623] can: netlink gateway (rev 20130117) max_hops=1
[ 3.901539] 9pnet: Installing 9P2000 support
[ 3.905745] Key type dns_resolver registered
[ 3.910228] Registering SWP/SWPB emulation handler
[ 3.915836] registered taskstats version 1
[ 3.920736] Btrfs loaded, crc32c=crc32c-generic
[ 4.795551] hctosys: unable to open rtc device (rtc0)
[ 4.800558] of_cfs_init
[ 4.802992] of_cfs_init: OK
[ 4.806041] ALSA device list:
[ 4.808968] No soundcards found.
[ 4.815775] Freeing unused kernel memory: 1024K (c0d00000 - c0e00000)
INIT: version 2.88 booting
Starting udev
[ 5.109730] udevd[1102]: starting version 3.2
[ 5.125178] udevd[1103]: starting eudev-3.2
[ 6.330890] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Populating dev cache
hwclock: can't open '/dev/misc/rtc': No such file or directory
Tue Aug 27 14:42:43 UTC 2019
Starting internet superserver: inetd.
Running postinst /etc/rpm-postinsts/100-sysvinit-inittab...
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
Removing any system startup links for run-postinsts ...
/etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... [ 7.478201] xemacps e000b000.ethernet: eth0: no PHY found
[ 7.483710] xemacps e000b000.ethernet: XEMACPS mii bus mii_probe fail.
ifconfig: SIOCSIFFLAGS: No such device or address
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDTJ4tpWFn54M/8hL4+4NrSyScmcBAvuFZJG+K/dKUUfslqZLXamzm5srIDrF0zgTRUBVIaYPA6kCJtH+/qBRTxvvuHK3S4QHYiSq9IYPXmmgt4CMUBTL3XegNjHisZLW2RVaBtBjxONNMeqxOy6nKFKS7TOHDwjskUEb8beRJoP3BwIXQ86HwzBNBVZEzDDMqXrBCrldsSaPW7awmR1q3oyLHC6jVAHLmxELAnUNUndeh1/sPbVNftgQKx/vxsdWYzpKEep+cfiZWZIfm7HA9UQ99NNdhTY73rMuAQN4z+ldT9f6VynN6jSjvPjIIvRUBuxQzKH8v+RQojsg1W7CGv root@pib_sau_project
Fingerprint: md5 16:f1:73:fd:5c:76:9a:db:cc:02:58:c1:99:e2:fb:e0
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2017.4 pib_sau_project /dev/ttyPS0
pib_sau_project login: root
Password:
root@pib_sau_project:~#
root@pib_sau_project:~# ifconfig -a
eth0 Link encap:Ethernet HWaddr 00:0A:35:00:1E:53
BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:28 Base address:0xb000
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1%1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
root@pib_sau_project:~# ifconfig eth0 up
[ 63.994541] xemacps e000b000.ethernet: eth0: no PHY found
[ 63.999905] xemacps e000b000.ethernet: XEMACPS mii bus mii_probe fail.
@idogan
