Visitor gionatha
zynq linux mutex sem_init
Hi!
I use PlanAhead 14.4 with Linux Ubuntu to develop a Linux application for zynq (ZC702 board).
I need to use mutex but I have some errors because semaphore.h file doesn’t have functions declarations.
I see that semaphore.h file used by compiler is a CodeSourcery file.
I suppose I need to use linux files in linux-xlnx directory that I have downloaded to rebuild kernel
Do you think the best way is to change PlanAhead-XPS configuration (I have tried without success)
or create a make file to build project outside XPS tool?
Has anyone experience in zynq + linux + sem_init function?
Thank you very much
Gionatha
Re: zynq linux mutex sem_init
You also have to link agains the pthread library. Try adding '-lpthread' to your link command line (and order matters, add it to the end of the command line).
Scholar milosoftware
"sem_init" is used in kernel code.
If you want to use a mutex in a (user space) application, use the "pthread" library. The man pages or a quick google gives you this:
http://www.xgc.com/manuals/xgclib/x5257.html
You can build and test your application on your ubuntu system. All you need to make it work on the Zynq is simply compile it with the ARM cross compiler.
If you're serious about building programs for Linux, I'd recommend something like OpenEmbedded to build the whole system, including your application and all the libraries you're going to need. No need to spend five weeks figuring out how to cross-compile and deploy the jpeg library if there's a system that'll do it for you.
Visitor gionatha
Thankyou very much for your answers.
I'will try tu use pthread_mutex.
Can I use it with processes created by fork() or only with threads?
In this moment I use fork to create a child process that wait on a socket.
I'm exploring zynq+linux possibility, so do you suggest to avoid xilinx-sdk and to use OpenEmbedded...
I have many years of experience about embedded systems but I'm newbie with Linux.
Thanks again
gionatha
Visitor gionatha
Thank you again for you help
Today I start a new simple program for testing thread and mutex
I have tried to complire it with Xilinx-SDK (I will read about OpenEmbedded, but I can't in this moment)
but compiler gives me an error for
pthread_create
and
pthread_cancel
The error is "undefined reference"
I have opened pthread.h and I see that functions are defined...
Where I'm wrong?
Gionatha
Sound like your problems aren't related to Zynq at all, it's just lack of Linux knowledge. If you want help with your code, post your code.
My advise: Put the board and the Xilinx SDK aside for a while and write and test some programs on your local Linux system. That will save you a lot of time and frustration.
Once you have your application running on your PC, then porting it to the Zynq is a no-brainer, it runs the same operating system and the same compiler.
Visitor gionatha
solved
I have 15 years of experience about micro and embedded software but only few months about Linux
I used always real-time operating systems.
I have added lpthread in project linker libraries and not pthread....
Sorry, and thanks for your helps.
I develop on Ubuntu Linux.
What can I use to develop on my PC?
I need a debugger if it's possible
There is someting, as Eclipse, configurated, ready-to-use?
Thanks again
Gionatha
